  1. Aug 3, 2023 at 11:32 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Feels like NorCal today here in the armpit of America :rofl:
    bmf4069 likes this.
  2. Aug 3, 2023 at 11:33 AM
    I searched cause I knew @the novelist put one up recently. Nothing came up. The search on this site sucks ass.
  3. Aug 3, 2023 at 11:34 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The novelist :rofl:
    bmf4069 and FirstGenVol like this.
  4. Aug 3, 2023 at 11:36 AM
    Guess what I get to do on my daughter's new sequoia! I guess the end tanks are leaking. Never saw it when we were looking at it. 35 minutes to the house and sitting idling and it started overhearing and steaming. Radiator juice on the front and back of the radiator.
    JasonC. and JakeJake like this.
  5. Aug 3, 2023 at 11:36 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    It looks like they have a $25-$75 rebate on power-stop brake kits through Aug 15th. I think I've seen some of you running them.
    Nicklovin likes this.
  6. Aug 3, 2023 at 11:37 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes crackie has powerstop
  7. Aug 3, 2023 at 11:37 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Buy crackie. Already done. Easy
    Nicklovin, JasonC., Sunnier and 4 others like this.
  8. Aug 3, 2023 at 11:38 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Aug 3, 2023 at 11:51 AM
    Oh, and the winshield wipers don't work. Didn't even think to check em there as we haven't had rain since the flood in early June.
  10. Aug 3, 2023 at 12:39 PM
    It's as easy as 1, 2, 3
    You just hafta know what the 1, 2 and 3 are...
    Results look good, here's the last couple codes I posted near the top. The real kicker is to use the 'Posted by member' box (2), and the 'search this forum only' toggle (3).
  11. Aug 3, 2023 at 12:56 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This is how I search for my posts and what not.
    https://youtu.be/4ldFV2-J6go
    danb and Sunnier like this.
  12. Aug 3, 2023 at 1:03 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  13. Aug 3, 2023 at 1:30 PM
    There it is. I skipped step 2.
    Nicklovin and Tundra2 like this.
  14. Aug 3, 2023 at 3:21 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Timing belt and water pump too? Knock everything out at once?
    Sunnier likes this.
  15. Aug 3, 2023 at 6:48 PM
    I've got a year before the timing belt is due so I'll wait till spring or possibly next fall to do that. It did have a sticker on it.
  16. Aug 4, 2023 at 4:49 AM
    Detroit axle sent me a discount code for 10% off. 10THANKYOU. Doent say when it expires.
    artsr2002 and JasonC. like this.
  17. Aug 4, 2023 at 5:41 AM
    Saw the most bizzare thing the other day.
    A 93-94 toyota pickup with a metal aluminum type cap mounted to a fiberglass cap to create a double cap. Wish I got a pic but they were driving in the opposite direction.
    They weren't even the same size. The cap on top was smaller in length and width.
  18. Aug 4, 2023 at 5:47 AM
    Not that bizarre but I've seen at least 5 FGT's here in town with a custom flat bed instead of a normal bed. Some look good, some don't.
    One guy works at the Toyota dealership with a white double cab flatbed. His passenger door is ripped open to the point that you can see the internal frame of the door. Another guy has some kind of mechanical lift gate instead of a tailgate. People do some strange things to these trucks.
  19. Aug 4, 2023 at 5:49 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Just a quick question about 4wd actuation. I saw in my Toyota manual that Toyota recommends about 10 miles a month in 4wd. I also saw this statement from Shifty in his thread about buying a 1st gen:
    • Also for 4WD trucks, Toyota recommends logging at least 10 miles per month in 4HI to keep things lubed, actuators firing, etc. Do it. 4WD is a pain to diagnose, actuators are expensive af and tend to get corrosion and pits on the contacts. Find an open, straight(ish) road once a month and throw it in 4HI before hitting 50MPH (you drop out of 4HI at any speed). In case you don't know, DO NOT turn sharply on pavement in 4HI on a Tundra (Sequoia is AWD/Torsen, so it's OK)."
    Problem is, I live in a large city and all the roads I drive on are paved. I wanted to ask how you all were doing this? Are you all driving on a paved road in 4HI? Should I wait until the road is at least wet from rain? I have a fairly straight road I drive everyday for my commute, was thinking that might be a good road to do it on.
  20. Aug 4, 2023 at 5:56 AM
    I have a dirt parking lot down the street from my house I go back/forth and turn around in using 4wd, but I don't come close to 10 miles. Usually after a snowstorm I'll get the opportunity to put 10-15 few miles on it.
    If you don't have snow and no dirt, I'd probably do as you recommend but incrementally (drive small distances) and on wet ground before getting to longer distances. My truck has the difficulty getting out of 4wd if I'm on dry pavement and drive long distances (over 1/2 mile). Seems to bind although I'm not sure what's causing it because my tread depth is pretty close all around the truck and I'm driving straight.
    FirstGenVol likes this.
  21. Aug 4, 2023 at 6:03 AM
    You can technically engage/disengage 4HI any time you want, as long as you're under speed - the speed cap to engage is like 57mph or some weird number like that, while there's no limit to when you can disengage.
    With the Tundra specifically (not Sequoia), on pavement, you want to avoid what I'll call "significant" turns, especially at slow speeds. Binding will happen. If you're doing 60mph on a dry highway and not moving the wheel past 11 and 1 on the clock to maneuver, you're not going to have any issues. And, say you had something come up that required you to make a significant turn, you can always tap the button to pop out of 4HI...
    I take advantage. Any time I'm driving and it's pouring down rain, I'm throwing on 4HI for a few minutes to drive around in it, regardless the surface. Often times when I'm in loose gravel or sand, I'm engaging it also. I mean, I've got it, the MPG impact is low, may as well use it, right?
    NUDRAT[OP] likes this.
  22. Aug 4, 2023 at 6:03 AM
    That should be fine. I flip mine into 4HI when it rains and I'm on a straight section of road. You can do it on dry pavement too. The main thing to avoid is sharp turns on pavement.
    I don't get close to 10 miles/month but I think it's fine.
  23. Aug 4, 2023 at 6:06 AM
    To this point, I know they say "10 miles" but I think the most important things are 1) You're engaging 4WD, forcing all the moving parts to move, 2) electrifying the actuators, which sweeps the contacts keeping them free of debris.
    Sure, sloshing around the fluid to lubricate everything is undoubtedly is a good thing, but I believe it's more about avoiding a freeze-up more than lubrication (not that you said it was either, I'm just saying)
    JasonC. and Jack McCarthy like this.
  24. Aug 4, 2023 at 6:14 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Idk you’re kind of in the middle, geographically, so it’s more like the pannis or FUPA of America.
    bmf4069 likes this.
  25. Aug 4, 2023 at 6:48 AM
    kentuckyMarksman
    @shifty` Thanks for the clarification!
    The RAM I had, the rear had a 3.21 ratio while the front had a 3.23 ratio. Engaging that on any type of pavement was not something you wanted to do. Sounds like they actually line up better on the Tundra.
  26. Aug 4, 2023 at 6:52 AM
    That's so RAM
    Sunnier and shifty` like this.
  27. Aug 4, 2023 at 8:53 AM
    This is wild headline. It sounds like this guy got a free house.
    Nicklovin, shifty` and Mr.bee like this.
  28. Aug 4, 2023 at 9:00 AM
    Score
  29. Aug 4, 2023 at 9:22 AM
    Planning to build yourself a new home with the profit if you make the sale?
  30. Aug 4, 2023 at 9:43 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Either moving to uruguay, lake baikal, or a houseboat. Might disappear & come back as an illegal.
    danb, Nicklovin, JasonC. and 3 others like this.
