Humm/grinding noise while turning right and hitting bumpps at 30 to 50 mph
Discussion in '2nd Gen Tundras (2007-2013)' started by Kienan, Jun 6, 2023.
  1. Jun 6, 2023 at 6:12 PM
    Kienan
    Kienan [OP] New Member
    07 tundra 4wd
    Hi guys first post I'm loosing my mind I have replaced front wheel bearings cv shafts and I replaced the needle bearing with the ecgs bushing what els could it be
  2. Jun 6, 2023 at 7:05 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Power steering system would be my next guess or steering components
  3. Jun 6, 2023 at 7:33 PM
    Kienan
    07 tundra 4wd
    It's a spining hum
  4. Jun 7, 2023 at 2:27 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Take a look at rear wheel bearing(s). I Just did em. Had same symptoms.
    Kienan[OP] likes this.
  5. Jun 11, 2023 at 1:33 PM
    Kienan
    07 tundra 4wd
    Just jacked it up and gave the tire the wiggle test and got nothing
  6. Jun 11, 2023 at 1:42 PM
    Larly5000
    NV
    07 Crewmax
    Yeah I tried wiggle test too. Same as you, got nothin’.
    I don't have a press so took it to a buddy at a local dealership. Diagnosed as a shot wheel bearing, replaced em both and back to normal.
  7. Jun 12, 2023 at 9:04 AM
    Kienan
    07 tundra 4wd
    So I went on a long drive and my front driver cv shaft was way hot idk what I could have messed up
  8. Jun 12, 2023 at 9:11 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Did you rule out a worn clockspring in the steering wheel?
  9. Jun 12, 2023 at 9:49 AM
    blenton
    blenton New Member
    Sticky brake caliper?
    Kienan[QUOTED][OP] likes this.
  10. Jun 12, 2023 at 7:11 PM
    Kienan
    07 tundra 4wd
    Yes is in drive train somewhere
  11. Jun 12, 2023 at 7:33 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I had a loud hum (whoo-whoo-whoo) also couple years ago. I thought it was driver side needle bearing also. I replaced it and still had same noise. I changed both rear wheel bearings, no more noise.
  12. Jun 14, 2023 at 4:55 AM
    Kienan
    07 tundra 4wd
    Getting quotes to do the rear wheel bearings hopefully can be done In the next few weeks and will keep you guys updated
    Tundrastruck91 likes this.
  13. Jun 21, 2023 at 7:25 AM
    Kienan
    07 tundra 4wd
    So it's not the driver side rear wheel bearing
  14. Jun 24, 2023 at 2:54 PM
    Kienan
    07 tundra 4wd
    Not the rear passenger wheel bearing either
  15. Jul 24, 2023 at 7:22 AM
    Kienan
    07 tundra 4wd
    Well also not the front diff guess its time to burn it
  16. Aug 3, 2023 at 6:27 AM
    Doris01TRD
    Doris01TRD New Member
    Oli
    2001 4.7L TRD 4x4 LMD AC
    Iron Man 4x4 1.5 in lift, 32" tires
    Hey y’all, I’ve got the same exact issue, just started randomly about a month ago, did a diff service and while I was down there I noticed rear axle seal leak. Popped off drum cleaned it up and put back together, installed diff breather kit, I’m hoping the noise is the rear wheel bearing, but this thread isn’t giving me much hope :rofl:any luck solving this issue??
