2017 has been great to my Tundra; 2018 will be even greater!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spvrtan, Dec 19, 2017.
  1. Dec 19, 2017 at 4:35 PM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    I recently bought a welder (Hobart 210) to learn on and one of my first projects is going to be building my own dual swing-out high-clearance rear bumper. The right swing will hold my spare while the left will be a tray for holding an extra cooler or storage container.
    Once I finish that.. I'm going to tackle an even bigger project: a custom trailer.
    Also planned: 4.88 gears, long-travel, and 42s.
    Build page:
    http://buildprint.io/mb/pluto
  2. Dec 19, 2017 at 5:15 PM
    Nickj619
    Nickj619 New Member
    San Jose, ca
    2014 tundra trd crew max
    Sounds awesome can’t wait to see how everything turns out
  3. Dec 19, 2017 at 5:18 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Right on Kris! Get you some!
  4. Dec 19, 2017 at 5:21 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    damn this should be fun
  5. Dec 19, 2017 at 5:46 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Damn son! Looking forward to seeing your projects in 18.
  6. Dec 19, 2017 at 5:53 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  7. Dec 19, 2017 at 7:45 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    :popcorn:
  8. Dec 19, 2017 at 8:33 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Nice. Curious to know if you can manage to get a high clearance rear bumper and still put the hitch somewhere and not mess with towing capability. Long travel is $$$$ and pair it with 42’s hahaha, you got ballsacks but I’m ordering popcorn
    Sunnier likes this.
  9. Dec 19, 2017 at 9:02 PM
    Sunnier
    Sunny
    San Diego, CA
    Forty-TWO's!!!
  10. Dec 19, 2017 at 9:10 PM
    42’s
    Open bidding starts on what goes first.
    TundraTss and Pudge like this.
  11. Dec 19, 2017 at 9:30 PM
    Spvrtan
    Kris
    San Diego, CA
    I think it'd be possible if you just mount the winch to the spare tire location instead of to the actual rear bumper (of course with the fairlead still on the bumper) ..or you could even get rid of the spare tire bracket itself to mount the winch up even higher, too. I gave it thought for a bit but I don't think I'd ever really need a rear winch on this rig.
    #cantlosewith42s
    Probably my steering rack but -- to be honest -- I'm quite surprised it hasn't broke on me yet with the 40s. I think having the steering stops to avoid full lock-to-lock pressure helps (at the cost of less turning radius).
  12. Dec 19, 2017 at 9:37 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Cool stuff. I thought you'd already re-geared for the 40s. :popcorn:
  13. Dec 19, 2017 at 9:43 PM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    :popcorn:
  14. Dec 19, 2017 at 9:46 PM
    :popcorn:
  15. Dec 19, 2017 at 10:32 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    Wait... you said "planned 4.88s" as in you are doing them in the future? Is this correct? If so, how is your trans still alive?!?!?! I'd save to have a spare one of them. I'm on 37s and running 5.38s on my jeep and still see trans temp sky rocket on longer type trails. Do you keep tabs on trans temp? Curious to know where yours hovers at?
    ColoradoTJ, Sunnier and csuviper like this.
  16. Dec 19, 2017 at 10:50 PM
    Sunnier
    Sunny
    San Diego, CA
    674.1°F
  17. Dec 20, 2017 at 1:02 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Might be time for new axles...
  18. Dec 20, 2017 at 7:09 AM
  19. Dec 20, 2017 at 10:38 AM
    Spvrtan
    Kris
    San Diego, CA
    Yes and yes.
    I've been watching the temperatures with my UltraGauge. They hover just above 200 when offroad and moving at a decent pace with some obstacle action -- while loaded down with gear (usually extra 40 gallons of gas in the bed, too, with my auxiliary gas tank). It's jumped to 210 a few times but not often. I haven't tried any tests with tow/haul on so I'm not sure if that'll affect temperatures. I know it's not the ideal temps but with how modified my truck is I'm taking it.
    Maybe I'm lucky or maybe what's going on in the engine bay is helping a bit to lessen load on the transmission.. I have the tow package (extra cooler), supercharger (and cooler), ram air hood scoop (plus heat extraction vents) for better circulation, and I have two 12" pusher fans up front (granted they're not right against the coolers but moving air is better than nothing when crawling slow with no winds). I also have an aftermarket grill that provides less air obstruction as compared to the stock and TRD Pro grill.
  20. Dec 26, 2017 at 9:44 PM
    the_midwesterner
    Luis
    None, yet....
    Tow haul mode won’t help keep temps in check. It’s basically just logic to hold gears longer, down shift less, etc while towing heavy loads. This also prolongs lock up on the converter and it stay in flex lock up longer, still generating heat. All the same work is still being done by the torque converter which is your #1 heat source.
    Also, why do you have pusher fans in front of your fan? You are effectively causing turbulent air in front of your radiator for the puller fan to have to sort through and then pull through. Fans are significantly more efficient in a pull method as opposed to a push method. Seems like you are doing more harm then good.
    TheBeast likes this.
  21. Jul 26, 2023 at 12:21 PM
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    I know this is an old thread but could you or someone else tell me what front bumper this is? Thanks
  22. Jul 26, 2023 at 1:29 PM
    AZBoatHauler
    So.Arizona
    Some IG digging says Relentless Fabrication but I don’t see it offered on their website.
  23. Jul 26, 2023 at 1:42 PM
    2TunGet1
    Thanks for your efforts. Dang, I’ve gone down the rabbit hole of finding a bumper that I like, a million to choose from…. I like the look of this one.
  24. Jul 26, 2023 at 1:50 PM
    AZBoatHauler
    So.Arizona
    Demello offers one that’s similar to that one.
  25. Jul 26, 2023 at 1:57 PM
    2TunGet1
    Thanks brother. I don’t want to hijack this thread so let me IM you.
  26. Jul 26, 2023 at 6:52 PM
    Pac12AfterDark
    Pac12AfterDark New Member
    So the 42s never happened? RIP, king.
    _none_ likes this.
  27. Aug 1, 2023 at 10:50 PM
    Spvrtan
    Kris
    San Diego, CA
    42s are coming. Just waiting for them to get stocked. This is also a really old thread and the truck has changed a lot since then. But as for what was called out in the first post.. the truck is on 5.29 ratio gearing now with the long-travel arms stacked with my lift. Semi-recent truck photo below..
    https://www.instagram.com/p/Cm1nCK6L4wg/
    2mchfun likes this.
  28. Aug 1, 2023 at 10:52 PM
    Spvrtan
    Kris
    San Diego, CA
    @AZBoatHauler is right. It's a Relentless Fab bumper but I guess they stopped making it. I sold mine a long long time ago. The Demello one is the closest one to the Relentless style of full plating.
    2TunGet1[QUOTED] likes this.
  29. Aug 2, 2023 at 4:08 AM
    Pac12AfterDark
    OP delivers
    HulkSmurf14 and 2mchfun like this.
