Changed wheels and lugs, will my spare wheel work with these nuts?
Discussion in 'Wheels & Tires' started by Bloomjtundra, Jul 29, 2023.
  1. Jul 29, 2023 at 5:29 PM
    Bloomjtundra
    Bloomjtundra [OP] New Member
    Josh
    2011 Tundra DC 4x4
    When I bought my 2011 SR5 it had the factory steel wheels. I bought a set of alloy wheels to replace them and sold the steel wheels. When I changed wheels I had to use proper lug nuts for the alloy wheels and now I don't have the old wheels or the lug nuts that they used.
    It occurred to me that the spare may not work with the lug nuts that the alloy wheels use. Will the lug from the alloy wheels work with the OEM spare wheel or do I need to buy the acorn style lug (shown on the left in this picture) to keep in the truck in case I need to use the spare at some point?
    Tripleconpanna likes this.
  2. Jul 29, 2023 at 5:33 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Yes... you can use alloy nuts on steel wheels, but not vice versa; if you look at the alloy nuts they have the same taper at the end that the steel wheel nut has :thumbsup:
    1lowlife likes this.
  3. Jul 30, 2023 at 10:14 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Can confirm. I haven’t done this on my Tundra, but I just helped a young girl change a flat on her Prius last Thursday on I-84. She had aftermarket 17” wheels with tapered nuts. They fit just right with the OEM spare steel wheel.
  4. Aug 2, 2023 at 1:37 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    Thanks! I was hoping this would be the case!
