110v outlets in bed and console (write-up)
Discussion in '2.5 Gen Tundras (2014-2021)' started by AlmightyCrash, Jan 7, 2019.
  1. Mar 28, 2020 at 10:23 PM
    AlmightyCrash
    AlmightyCrash [OP] Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    i used Duplicolor, but they have since changed their formula, and it’s not as black. It also doesn’t texture the same.
    I now use Krylon for everything.
    Bigolbaddy[QUOTED] likes this.
  2. Mar 30, 2020 at 9:43 AM
    lonelydriver
    lonelydriver New Member
    great write up, thank you will do this soon
  3. Mar 30, 2020 at 10:04 AM
    field8909
    field8909 New Member
    Austin Texas
    2020 Voodoo Blue TRD Sport
    This is a great idea...I will definitely be working on this
  4. Feb 10, 2021 at 8:51 AM
    akulo
    akulo New Member
    Arik
    2011 Tundra White TRD
    @AlmightyCrash do you have any instructions how to run 110Volt all the way to tailgate?
    vanthesupreme and marcelo73 like this.
  5. Feb 13, 2021 at 4:21 AM
    AlmightyCrash
    Crash
    San Leon, TX
    I just went through the floorboard with a rubber grommet, and followed the frame to the back.
  6. Feb 16, 2021 at 7:46 PM
    marcelo73
    marcelo73 New Member
    So Cal
    2016 Toyota Tundra Crewmax TRD PRO QUICKSAND
    295/70 18 Coopers
    Any chance we could see some photos when you have a moment. Texas as cold as the news is conveying???
  7. Feb 17, 2021 at 9:02 AM
    AlmightyCrash
    Crash
    San Leon, TX
    Here is the frozen water around the house...84A883CA-F36E-4FE8-8CDF-DC367FCFE0D7.jpg01FB9BB1-876E-483B-A2DD-91A8A40345D5.jpg
    and my dog’s bowl inside the house after he broke through the ice to drink
    this is pretty cool where the tide went out and left these shapes
    Not sure why it was requested for in this thread, but I’m happy to oblige.
    panicman likes this.
  8. Feb 17, 2021 at 9:10 AM
    marcelo73
    So Cal
    295/70 18 Coopers
    lmao, great photos thank you for sharing, but I was actually referring to photos of your mod. Stay warm my friend!
  9. Feb 17, 2021 at 9:12 AM
    AlmightyCrash
    Crash
    San Leon, TX
    oh. There are photos in the first post. That’s why I was confused.
  10. Feb 17, 2021 at 9:17 AM
    marcelo73
    So Cal
    295/70 18 Coopers
    Sorry for my riddles, I did see those photos of the receptacles installed, any chance for photos of the inverter install and maybe if possible how you ran the cables to each outlet. Again sorry for my lack of specifics.
  11. Feb 17, 2021 at 9:25 AM
    AlmightyCrash
    Crash
    San Leon, TX
    The inverter is under the drivers seat, so I can’t get photos without removing the seat and it’s just too cold right now. Lol.
    Both receptacles have your standard 3 prong plug and just plug into the inverter. I ran the console outlet cable out the drivers side of the console and plugged it in. There was really no tricky routing. The one in the bed required an 8ft extension cord. I ran it along the frame underneath, and up through the floor under the drivers seat to the inverter. I used waterproof tape where the outlet plugs into the extension cord.
    I hope I’m giving you the info you want. I have severe autism and sometimes have difficulty understanding people.
  12. Feb 17, 2021 at 9:43 AM
    marcelo73
    So Cal
    295/70 18 Coopers
    Thanks Almighty, that information will work. I am seeking this in a 800-1000w set up and i'm gathering ideas and options. Stay warm, sending some cali warmth to our brothers and sisters in Texas.
    AlmightyCrash[OP] likes this.
  13. Jul 30, 2021 at 7:22 AM
    browniemix33
    browniemix33 New Member
    New Hampshire
    2017 Metallic Grey Tundra Limited 4WD
    Great write up with pics! Hoping to do this project sooner than later :yes:
  14. Jan 3, 2022 at 1:26 PM
    Shadowfax1
    Shadowfax1 New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    Would you mind sharing what you ended up building or using for a cover? I'm putting together a plan for this install and want to be sure the socket in the bed has a cover over it.
  15. Mar 16, 2023 at 6:59 AM
    jcapcinco
    jcapcinco New Member
    Jon
    2010 Tundra
    What did you use to cut into the bed? How big a hole was required for those sockets?
  16. Mar 17, 2023 at 11:36 AM
    AlmightyCrash
    Crash
    San Leon, TX
    I used an angle grinder, if I remember correctly. I don’t recall the hole dimensions.
  17. Mar 18, 2023 at 7:17 PM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Any concerns with the inverter getting too hot under the seat? Also where did you run the 8ga positive to the battery? Along the door and through the firewall or in the floor and along the frame to the battery.
    I might just put the inverter under my hood and run a cord along the frame to the bed.
    Shadowfax1 likes this.
  18. Apr 5, 2023 at 11:29 AM
    AlmightyCrash
    Crash
    San Leon, TX
    No problems with heat. I went through the firewall to the battery.
  19. Apr 5, 2023 at 11:52 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I'd feel better having it in the cab (or under a cap/tonneau in the bed) and away from dust and moisture.
  20. Apr 5, 2023 at 2:38 PM
    #50
    itsZEUStime
    itsZEUStime New Member
    Paul
    2019 White Tundra SR5 Crewmax
    RCI Sliders RCI Skids Prinsu Rack AJT Chrome Delete Pop & Lock Power Tailgate Lock Super Pacific Camper Incoming
    Nice little project, great to have 110v power options around the truck!
  21. May 8, 2023 at 11:24 PM
    #51
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    If I missed please let me know what I can run off of this mod.
    Frigirator or a power tool?
  22. May 16, 2023 at 10:09 PM
    #52
    mikeychop21TrdPro
    mikeychop21TrdPro New Member
    Michael
    2021 Toyota tundra TRD Pro
    TRD intake, TRD radiator cap, TRD oil cap, JL oil separator, various interior upgrades, Pedal Commander
    @AlmightyCrash Just wanna say that I appreciate your write up on this! I will be doing almost the same exact setup on my tundra in the coming weeks and having this write up to reference is fantastic. Thanks for all your detailed information! Helping out the community even years later!
  23. Aug 1, 2023 at 8:08 PM
    #53
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    My '04 Taco had 120V in the bed. It was cool as hell, and I loved having it, but I think I only used it once in 350,000 miles.
    Still, I wish my Tundra had it. LOL
    AGSport likes this.
