2017 Tundra Transmission Fluid
Discussion in '2.5 Gen Tundras (2014-2021)' started by whoareyou4, Jul 30, 2023.
  1. Jul 30, 2023 at 3:31 PM
    whoareyou4
    whoareyou4 [OP] New Member
    2017 Tundra
    I understand that there is no tranny filter to change on this model/year.
    I have over a 100k on the truck and I was thinking of changing out the fluid ... the amount that I can anyways.
    Is there anything special I need to be aware of if I do this?
    There should be a drain plug, fill plug and a plug to check fluid level.
    in my mind it should be pretty straight forward ensuring that I put back in what drained out just looking for any thing that could go wrong.
    Thanks
  2. Jul 30, 2023 at 3:52 PM
    bflooks
    bflooks New Member
    Metrowest MA
    @whoareyou(5-1), you are not the first to inquire or to be believe it is a simple process There is a screen (not a traditional filter) and most don't replace it. Some drain/refill based on volume and some check level via Toyota guides. A search will yield you every variation of this discussion imaginable.
    2mchfun likes this.
  3. Jul 30, 2023 at 3:55 PM
    Black
    2014 Tundra Limited CrewMax
  4. Jul 30, 2023 at 4:36 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    There’s no transmission filter on the 2017 Tundras?
  5. Jul 30, 2023 at 4:44 PM
    Black
    Some call it a filter but it is actually just a strainer and really does not need to be changed.
    WILLINH likes this.
  6. Jul 30, 2023 at 4:52 PM
    Tsm503
    2021 DC SR5
    That’s with any 07-21, the way OP worded it sounded like there was nothing at all. Just a open pickup
  7. Jul 31, 2023 at 3:51 AM
    Bammer
    Monroe, CT
    Good info, not sure if I'd be laying under the truck while my "helper" cycles the trans between N & D ! :monocle:o_O;):burnrubber:
  8. Aug 1, 2023 at 12:43 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
  9. Aug 1, 2023 at 12:59 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Just measure how much it came out and pour the same amount back in
    Rob's Inferno and WILLINH like this.
