Can not remove OEM tonneau cover PK3B134H5H
Discussion in '2.5 Gen Tundras (2014-2021)' started by Reticuli, Jul 18, 2020.
  1. Jul 18, 2020 at 5:52 PM
    Reticuli
    Reticuli [OP] New Member
    sean
    2020 Green Tundra TRD Pro Crewmax
    I just had a tonneau cover installed at the dealer. It says it’s removable but I cannot get it off. It appears to be stuck to a strip of adhesive foam along the back of the bed under the back window. The whole reason I bought this one was because I need to haul my dirt bikes and it’s a crewmax so there is not enough room with the tri fold folded but still attached. I can get the pit bikes in but not my trail bike.
    https://parts.toyota.com/p/Tonneau-Cover/69549541/PK3B134H5H.html
    does anyone know if those are removable or am I going to have to take it back.
  2. Jul 18, 2020 at 5:54 PM
    Reticuli
    sean
    Here’s a photo
  3. Jul 18, 2020 at 7:07 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Did you remove the bolt under the plug on the passenger side at the front?
  4. Jul 18, 2020 at 7:10 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    When I take mine off I do one side at a time I fold it back I lay on my back and pull the string on the left and lift it lay it on the track then i pull the string on the right side then it comes off it’s a little PIA but not horrible once you do it the first time it gets easier
  5. Jul 18, 2020 at 7:20 PM
    Reticuli
    sean
    There is no plug. You mean on the top
    Outside? I saw some like that but mine doesn’t have one
  6. Jul 18, 2020 at 7:23 PM
    Reticuli
    sean
    Does yours look like this?
  7. Jul 18, 2020 at 7:29 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you dont have the plug then yours is a different style. Is yours a genuine Toyota cover?
  8. Jul 18, 2020 at 7:29 PM
    Reticuli
    sean
    I don’t see any strings but there are two cables
  9. Jul 18, 2020 at 7:30 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    My hardcover isn't a genuine Toyota cover.
  10. Jul 18, 2020 at 7:30 PM
    Reticuli
    sean
  11. Jul 18, 2020 at 7:31 PM
    Reticuli
    sean
  12. Jul 18, 2020 at 7:33 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Let me see if I can find the instructions from infostream.
  13. Jul 18, 2020 at 7:38 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Yea that’s it u need to pull 1 at a time and lift
  14. Jul 18, 2020 at 7:39 PM
    AZTundra
    Paul
    Phoenix, AZ
    NewImprovedRon likes this.
  15. Jul 18, 2020 at 7:44 PM
    Reticuli
    sean
    AZTundra[QUOTED] likes this.
  16. Jul 18, 2020 at 7:45 PM
    Reticuli
    sean
    eddie_773’s video should do the trick.
  17. Jul 18, 2020 at 7:46 PM
    AZTundra
    Paul
    Phoenix, AZ
    No problem. That video is the Tacoma, but appears to be the same factory tonneau cover you have. That video should guide you through the process.
  18. Jul 18, 2020 at 8:41 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Here is the Toyota instructions if you need them.
    NewImprovedRon and Reticuli[OP] like this.
  19. Jul 18, 2020 at 10:58 PM
    Reticuli
    sean
    Thx
    Ruggybuggy likes this.
  20. Mar 26, 2021 at 4:48 PM
    ncomeau35
    ncomeau35 New Member
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    I notice every time we get a heavy rain my cover leaks near the tail gate it appears it's coming in from the side where the small weather stripping is. Does anyone know of any ways to add additional weather stripping? Possible the entire length of the cover on each side?
  21. Jul 31, 2023 at 5:48 AM
    Jambully1
    Jambully1 New Member
    Does anyone know if this cover will fit a 2015 PRO? I have it on a 21 PRO currently but want to put it on my sons 15 PRO because I bought a bakflip for the 21 so I’d have extra space if needed. I thought I saw where this fit a 17-21 so I wanted to make sure. I thought the 15’s were the same.
  22. Jul 31, 2023 at 5:55 AM
    14-21 all have the same bed, so it should fit.
  23. Jul 31, 2023 at 6:06 AM
    Jambully1
    That’s what I was thinking. Thanks for your help.
