Any success stories painting your chrome?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kbo, Jul 27, 2023.
  1. Jul 27, 2023 at 2:46 PM
    Kbo
    Kbo [OP] New Member
    British Columbia
    2019 Double cab
    A bit of a lift, compressor, bags
    Hi all.
    I had a bird strike causing breakage of the grille surround. I am using this as an opportunity to order a TRD Pro style grille and have it painted. I will order a black one so that the body shop can paint it to the truck color. However, the hood bulge will also need to match, but the body man says painting the existing chrome doesn’t work and has never found success doing it. Even after scuffing it before paint he says he’s been down this road and it doesn’t work. I’m trying to avoid buying another hood bulge I black so it can be painted. Has anyone had the needed tenacity and experience to successfully paint this? Cheers
  2. Jul 27, 2023 at 2:58 PM
    It will always be prone to chipping and flaking. I've tried it all.
    NewImprovedRon likes this.
  3. Jul 27, 2023 at 2:59 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Same. Tried all methods and over time, doesnt work.
    Saltyhero13 likes this.
  4. Jul 27, 2023 at 3:04 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    We replaced our grille surround because of a deer strike, bulge wasn't covered by car insurance, so purchased on our dime.
    Just buy the matching bulge. You'll be way happier.
    Saltyhero13 and NewImprovedRon like this.
  5. Jul 27, 2023 at 3:06 PM
    Kbo
    Kbo [OP] New Member
    British Columbia
    2019 Double cab
    Done. Thanks all.
    BravoDeltaRomeo likes this.
  6. Jul 27, 2023 at 3:06 PM
    Plasti-dip held up the best. Looks meh. Plastidip with bedliner over top works too. Also looks meh. I've heard of some that use plasti-dip, then bedliner, then sand smooth, then paint. I can only imagine how meh that looks. Getting a paintable upper grill scoop-snoot thing that's paintable is the way to go. Or those Eco-shell painted cover thingys.
  7. Jul 27, 2023 at 3:09 PM
    chrispick
    chrispick New Member
    chris
    I had my chrome "wrapped" by a paint shop. all black front end now and looks great. They also confirmed that you can't paint over the fake chrome
  8. Jul 27, 2023 at 3:26 PM
    stogey420time
    stogey420time New Member
    Houston
    I plastidip'd my front and rear.. completing the chrome delete, here's a couple of pix.
    I was hesitant at first but finally went for it. I ordered my front grill with matching hood bulge and surroundings from sparks in April but sparks said it could be September before my grill ships. Fck that, too long of a wait So I bought the pro grill locally.
    My hood bulge was chrome and the surrounding was black... the outcome isn't isn't a perfect but I'm happy with it.
    I went the plastidip route because of my reasoning below, good luck on your decision.
    1) It's cheaper than getting it painted by a shop.
    2) I did not want to wrap it because I failed at wrapping a few interior pieces previously... not gonna happen.
    3) Buying end cap covers are quite expensive imo
  9. Jul 27, 2023 at 3:36 PM
    RobertD
    Robert
    DFW, Texas
    I'm the Blazing Blue on the left. That was a chrome bulge and surround I painted. Been on the truck (which lives outside) for about 1.5 years. Overall, it totally looks better than the chrome. But I do have some rock chips. I also have rock chips in other body panels so its not just my paint work. If I did it over, I would plasti dip then bedline and sand that smooth and then paint. Its more steps but it will be more durable and still beat chrome. If you can get the color match on Toyota painted parts (not chrome) that will be better but the costs to buy my blue from Toyota for those 2 parts is ridiculous.
    KNABORES likes this.
  10. Jul 27, 2023 at 4:34 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Maybe it's just me but, if you spray PlastiDip on as your first coat, and then bedliner and paint afterwards, I would think the PlastiDip would be the first coating to let go taking everything else with it. I don't know...
  11. Jul 27, 2023 at 4:36 PM
    RobertD
    Robert
    DFW, Texas
    Yes, but the plasti dip adheres to the chrome much better then paints. In my above picture I used plasti dip on the chrome bumper ends, followed by bedliner for a protective shell. I've had no adhesion issues and so far there has been no chipping.
  12. Jul 27, 2023 at 4:40 PM
    NewImprovedRon
    Ron
    NW Arkansas
    How long has the current set up been on?
  13. Jul 27, 2023 at 4:46 PM
    biebs96
    PA
  14. Jul 27, 2023 at 5:09 PM
    RobertD
    Robert
    DFW, Texas
    The bulge and surround about 1.5 years, the bumper black out has been just over a year. My truck is always outside so this has been thru hail, rain, ice, snow, negative temps and extreme heat.
  15. Jul 27, 2023 at 7:14 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    This hood bulge was done with plastidip, then bedliner, then sanded smooth and done with matte black. The bedliner was on there about three years before painting.
    My bumper caps had plastidip covered in bedliner for over 5 years, and held up phenomenally.
  16. Jul 28, 2023 at 5:54 AM
    NewImprovedRon
    Ron
    NW Arkansas
    Cool beans! That combination, in that order, would seem to be the ticket.
    BlueRibbon4x4[QUOTED] likes this.
  17. Jul 28, 2023 at 11:56 AM
    breynolds
    breynolds New Member
    Future Tundra owner
    The key for getting anything to stick to chrome is proper prep which means sanding until it's not shiny anymore then applying adhesion promoter, primer, base color coat then 2K clear coat. Guaranteed you'll get an OEM quality paint job as long as your base coat matches the body paint well enough.
  18. Jul 28, 2023 at 12:07 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    Mine is holding up okay except for a couple small rock chips where the paint seperated from thr primer. We did a light scuff of all the chrome, a self etching primer, a bake, then 3 coats of paint with a bake between each, then 3 coats of clear with a bake between each.
    20211229_163037.jpg 20220625_085133.jpg 20220625_094653.jpg 20220625_102020.jpg 20220625_122537.jpg
    A year later...
    BlueRibbon4x4 likes this.
  19. Jul 30, 2023 at 5:27 PM
    hillbillyhan
    hillbillyhan New Member
    2015 1794 edition
    Everything...
    I've stripped the chrome with a flapper disc wheel and powder coated mine. But I only had the car for year after that so couldn't tell you how it's still holding up. But I'm pretty sure it's still good.
  20. Jul 30, 2023 at 7:08 PM
    seydou
    seydou Distinguished Member
    The amount of time, money and effort people expend to eliminate chrome is mind boggling to me. Especially when sometimes it so obviously does not match the OEM color.
    To each his own, but I am so very glad I have not been infected with De-Chrome Disease.
    It does look good though. Carry on.
    yakeng likes this.
