2007 1 ton dually Tundra 11k mi $90k
Discussion in 'General Tundra Discussion' started by 2mchfun, Jul 29, 2023.
  1. Jul 29, 2023 at 9:33 PM
    2mchfun
    2mchfun [OP] Cool story, but did your new TTV6 tow a shuttle?
  2. Jul 29, 2023 at 9:41 PM
    18" TRD Off Road Wheels
    This has @ColoradoTJ written all over it. Could be back in a Tundra again.
  3. Jul 29, 2023 at 9:42 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  4. Jul 29, 2023 at 10:20 PM
    SC? It's gonna need it.
    Y0TA PR0, BTBAKER, T-Rex266 and 4 others like this.
  5. Jul 29, 2023 at 10:21 PM
    No reason you couldn't put one on. It's the 5.7 according to the info. It may have one, I just didn't look closely enough.
  6. Jul 29, 2023 at 10:35 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That has got to be the sketchiest piece of crap I have ever seen for 90k. “Made In Canada” “custom spec” “held up in customs” “LineX instead of paint” “1 ton truck built off a half ton frame”. 90,000 dollars!? I can, and did buy a factory new f-450 tow truck for quite a bit less than that and it was built for the job from a reputable manufacturer.
    NOPE
    I wouldn’t touch that with your 10ft pole.
  7. Jul 29, 2023 at 10:39 PM
    Funhater.
  8. Jul 30, 2023 at 6:57 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I would drive down just to look at that if I was still working in Tulsa.
    I wonder if it’s just a Tundra cab and engine on a 4500/5500 chassis from one of the big 3. It has 19.5” wheels on it.
  9. Jul 30, 2023 at 8:33 AM
    Mr Badwrench
    Mr Badwrench New Member
    The person who scabbed that thing together sure is impressed with himself. Not even a 4X4.
    On the other hand, if he can soak someone out of 90K for it then hey, it's a free country.
  10. Jul 30, 2023 at 8:14 PM
    Tbrandt
    Tristan
    Kansas City
    I asked for more pictures of the underside. From what I can see it’s nothing more than a double cab Tundra with heavier leaf springs and hub adapters for 8 lug wheels. Unless there’s some sort of custom full float conversion kit on there, it’s just a standard Tundra axle with stock brakes. No frame modifications.
    ColoradoTJ, 2mchfun[OP] and _none_ like this.
  11. Jul 30, 2023 at 8:19 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Holy crap.
    Cpl_Punishment likes this.
  12. Jul 31, 2023 at 2:04 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    post the pics
    ZappBrannigan and 2mchfun[OP] like this.
  13. Jul 31, 2023 at 3:13 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    How about a pic of the door jamb? He's characterizing it as a unique OEM one-off. The door jamb will reflect whether it's a Toyota "one-ton" or not.
    ZappBrannigan likes this.
  14. Jul 31, 2023 at 3:23 PM
    Someone please explain how you’re unable to exceed the GVWR by carrying a car on the flatbed?
    Or does the GVWR magically increase to handle a larger payload by putting on more leaf springs and a dual wheel configuration?
  15. Jul 31, 2023 at 3:25 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Saw that ad a while back and he got roasted in the comments.
  16. Jul 31, 2023 at 4:58 PM
    Tbrandt
    Tristan
    Kansas City
  17. Jul 31, 2023 at 5:34 PM
    centex
    centex New Member
    How’s a posi-track rear end work? It just does.
  18. Jul 31, 2023 at 5:48 PM
  19. Jul 31, 2023 at 6:25 PM
    centex
    centex New Member
    I see the joke was lost on you.
    texasrho83 likes this.
  20. Jul 31, 2023 at 6:57 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    hagrid and centex[QUOTED] like this.
  21. Jul 31, 2023 at 7:50 PM
    centex
    centex New Member
  22. Jul 31, 2023 at 8:53 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    So, correct me if I’m wrong, but is that a big standard tundra Open C channel frame with a 1ton axle and leaf springs presumably from a domestic.
    Terndrerrr likes this.
  23. Jul 31, 2023 at 9:09 PM
    Terndrerrr
    Music City
    6UR-FE
    Not even a 1 ton axle…that’s the original Tundra axle. Same shape pumpkin. And look at the shock mounts.
  24. Jul 31, 2023 at 9:45 PM
    Good lord. I was really hoping for at least an AAM axle out back.
    The only thing this truck is good for now that I seen the pictures is driving around with something unique.
  25. Aug 1, 2023 at 5:35 AM
    Tbrandt
    Tristan
    Kansas City
    I can’t imagine how bad that thing rebounds with stock shocks and that much spring rate. The other day I had ~1000lbs of brick in the bed and my bags at 50 PSI and it was reeeeally bouncy.
  26. Aug 1, 2023 at 5:45 AM
    I guess so. You had me believing you thought the payload could be infinitely increased through some bizarre logic like the owner of that $90k rig.
  27. Aug 1, 2023 at 6:11 AM
    PermaFrostTRD
    Northern NY
    "Line-X'ed it back to Red...":rofl:
    So in addition to not increasing the axles, upgrading brakes, using the ½ frame,... you added 400lbs of "paint" to it?
    What a deal.:spending:
  28. Aug 1, 2023 at 6:43 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
  29. Aug 1, 2023 at 7:04 AM
    Not the normal wordsmith comical comments. Must be on a Viking jog. :D
  30. Aug 1, 2023 at 7:54 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    It's been terribly hot, here.
    ColoradoTJ likes this.
