Engine running rough
Discussion in 'Performance and Tuning' started by treeguy, Jul 29, 2023.
  1. Jul 29, 2023 at 6:29 AM
    treeguy
    treeguy [OP] New Member
    206 Toyota Tundra SR5
    I have cleaned the throttle body and the mass air flow sensor and the engine is still running rough. I have no check engine light and when I check there are nor codes that show. I could use some help.
  2. Jul 29, 2023 at 6:32 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Sparkplugs & coils?
  3. Jul 29, 2023 at 7:57 AM
    treeguy
    I thought about that but in the past when a coil went out I got the check engine light and a code identifying the cylinder.
    Thanks for the response.
  4. Jul 29, 2023 at 8:57 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Lots of info still required.
    Engine air filter condition?
  5. Jul 29, 2023 at 10:02 AM
    treeguy
    Just replaced air filter. Only other work done was new radiator a month ago.
  6. Jul 29, 2023 at 10:11 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Temp sensors?
    do you park outside? Rain? Rodents?
  7. Jul 29, 2023 at 10:36 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Run enough NEW gasoline through it to eliminate water-in-the-gas??
  8. Jul 29, 2023 at 2:35 PM
    treeguy
    No garage so parked outside. No problem with rodents at this point. As soon as problem started I used a fuel treatment for moisture and since then have filled tank with fresh gas.
  9. Jul 29, 2023 at 3:22 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Staying with the simple. Pull the positive lead off the battery for 30 minutes fully draining all the electricity and "resetting" systems.
  10. Jul 29, 2023 at 3:33 PM
    xc_tc
    xc_tc New Member
    Sometimes it helps to replace the transmission fluid especially if it only runs roughly at idle and there are not misfire codes.
  11. Jul 29, 2023 at 4:37 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    When does it run rough? At idle? In gear? What does the idle do in gear vs idle?
  12. Jul 29, 2023 at 6:17 PM
    treeguy
    It runs rough mostly when I am pulling out from a stop or sometimes accelerating up a hill.
  13. Jul 29, 2023 at 7:44 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  14. Aug 3, 2023 at 5:55 PM
    treeguy
    Thank you. We ended up replacing the Mass Air Flow Sensor. I still don't have any codes we were just going down the list of possibilities. I drove it today and it was running pretty rough and for the first time I had codes. P0171 Bank 1 and P0174 Bank 2. System too lean. I don't know if I got a faulty sensor or there is something else not working properly. Any suggestions.
  15. Aug 3, 2023 at 6:16 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    you sure you have an O-ring on the MAF, an connection is all tight with no air leak
  16. Sep 15, 2023 at 9:25 PM
    TexRob713
    TexRob713 New Member
    2018 4.6 SR5
    Did you resolve your rough idle issue?
