285/75r17 with 2.25” Lift Question
Discussion in 'Wheels & Tires' started by nordicfreak, Jul 28, 2023.
  1. Jul 28, 2023 at 10:33 AM
    nordicfreak
    nordicfreak [OP] New Member
    2015 Navy Blue Tundra SR5 Double Cab
    Topper Decked Drawer System Katzkin Leather
    Hey All!
    I have a stock 2015 SR5 that I just picked up a set of Bilstein 5100’s for. The struts are set to the highest setting for 2.25” of lift. I’m running airbags in the rear and should be about level.
    I’d like to get some new wheels when I get my new set of tires and here’s what I’m thinking:
    Wheels (Method 703 Bronze 17x8.5, +35 offset, 5x150): https://www.methodracewheels.com/co...ucts/703-method-bronze?variant=39290141605949
    Tires (BF Goodrich AllTerrain KO2 285/75r17): These are about equivalent to a 33.8” x 11.2” tire.
    I’m hoping someone out there is running a similar setup and can tell me if they think it’ll work? I don’t want to do a body chop (no metal cuts), but would be okay bending or moving some plastic pieces.
    Thoughts?
    For additional reference, with stock suspension, I am running Goodyear Wrangler AT 275/65r18 tires and come close to rubbing on the front bumper but not in the rear against the cab/frame (at least an inch of clearance).
    Thanks everyone!
  2. Jul 29, 2023 at 4:01 PM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    I think you're gonna be fine with just some minor plastic pushing modding and removing your flaps. Plus 35 tucks in nice and should help with the rubbing.
  3. Jul 29, 2023 at 4:47 PM
    2mchfun
    Make sure that you will clear the upper control arms with the tire width at that offset.
  4. Jul 29, 2023 at 7:11 PM
    bmw345
    bmw345 New Member
    CT
    He will be fine with 285's, I'm currently on a plus 35 wheel with 37x12.5's and have plenty of clearance with the stock UCA!
    2mchfun[QUOTED] likes this.
