Want to swap out my sliders for a more kid friendly step/sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by drpheta, Jul 29, 2023.
  1. Jul 29, 2023 at 6:29 AM
    drpheta
    drpheta [OP] New Member
    Super White 2014 TRD Off-Road DC
    My kids slip off the ones that came with my truck. These are what's on the truck now. Looking for suggestions on a better set of sliders or steps that look good and aren't so slippery.
    I will say these current ones are really solid, because they mount directly to the frame instead of to the undercarriage like the OEM ones.
  2. Jul 29, 2023 at 6:53 AM
    Krewcial
    Krewcial So good with my rod, I make fish come!
    Don
    2010 DC (3UR-FE) & 2000 AC (2UZ-FE)
    -Kings 2.5’s shocks -JBA UCA -Wheelers front bumpstops -Torque air bags with Daystar air bag cradles -Alcans leaf’s +700 lbs 1” lift -Dobinson grease-able shackles -TRD front and rear sway bars -RCI Engine, Transmission/Transfer Case skid plate -RCI Catalytic Guard -RCI sliders -Magnum ICI RT series bumpers -Auxbeam 72W Amber 4" round spot off road lights -Morimoto XB LED headlights -Level 8 MK6 +12 offset 18" rims wrapped with 285/75/18R Falken AT3’s with TRD centercaps -TRD dual exhaust with black chrome tips -AFE Power Magnum FLOW Pro DRY S Air Filter -TRD air accelerator -WeatherTech floor mats -Aftermarket Sequoia Grill -MAX Modular bed rack with tonneau brackets -Diamondback HD tonneau -James Baroud Grand Raid XXL -OVS 270 awning -11” Alpine iLX-F511 media receiver
    I would just Linex them but that’s just me though. There’s many options out there but you shouldn’t have an issue reselling these.
    drpheta[OP] and 2mchfun like this.
  3. Jul 29, 2023 at 6:54 AM
    2mchfun
    Just get some diamond aluminum plate material, cut it to form some step plates about 20" long, drill it and rivet it on. Might want to refinish the sliders first though.
    BravoDeltaRomeo, ATV25 and Krewcial like this.
  4. Jul 29, 2023 at 6:56 AM
    Krewcial
    Don
    I just installed RCI sliders and the plate helps a ton. Way easier to wash the top of my truck.
  5. Jul 29, 2023 at 7:03 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Not sure if this is exactly what you're looking for but it's what I recently got.
    Rhino Dominator D6. Had them line-x (didn't have to), very sturdy, I would recommend them.
    wmsvol88, RustyShackle323 and ATV25 like this.
  6. Jul 29, 2023 at 8:16 AM
    drpheta
    Thanks, but that would cost just as much as replacing it for me.
  7. Jul 29, 2023 at 8:23 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Clean them off real well and place grip tape on the parts that are stepped on the most.
  8. Jul 29, 2023 at 8:24 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    Real sliders aren't cheap, so I would mod what you have unless you really don't like them. I imagine you could get top plates or expanded metal welded in for a couple hundred and hit them with some rattle can bed liner and be good for a few years.
    If you don't need the sliders or protection, flip them for a few hundred and get regular steps.
    Shanet421 likes this.
  9. Jul 29, 2023 at 8:25 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  10. Jul 29, 2023 at 8:52 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    As others have said - frame-mounted true sliders aren’t cheap ($1100 being the low end and $2k+ not being unheard of) and offer a lot more protection all the way around than cab-mounted steps. I wouldn’t get rid of them if it was my truck, but rather look for a way to add the grip you need where you need it.
    Safety tread grip tape, skateboard deck tape, and similar products are easy to apply (just clean/decrease the finish well first) and can be put just where you need them without covering the whole slider, and can be removed relatively easily down the road (or reapplied).
    Line-x or Rhino lining, or a DIY version like Raptor liner, can be applied to give more grip to the entire slider. Obviously more prep required and more cost. Also more work to repair if you ever scrape them.
    Next step up would be getting a local shop to make a top plate for them. I wouldn’t do “diamond plate” because that shit isn’t really any more grippy than smooth plate. 14 or 12 GA plate with holes laser cut and dimple punched the way RCI and others do then offers a lot of grip. Or get just the plates Line-X/raptor lined and attach using a variety of methods (drill and tap with button head screws, blind rivets, track welds, etc.).
    Hard to tell in the pictures, but those kind of look like Cali Raised sliders. They may offer bolt-on plates for them.
  11. Jul 29, 2023 at 8:53 AM
    clarkritchie
    clarkritchie New Member
  12. Jul 29, 2023 at 9:52 AM
    2mchfun
    Might be able to just make some rope grab handles that hang off the headrests for your kids to hang onto as they make their way up. I've seen some that are braided paracord and somebody here might even sell them.
  13. Jul 29, 2023 at 9:54 AM
    2mchfun
    Check Extreme Terrain website clearance section. I see steps in there frequently.
  14. Jul 29, 2023 at 10:08 AM
    drpheta
    Thanks guys. These are the sliders. They have AP embossed on them, and you can see how they're frame mounted here. Some chipping and rust on them, so do Line-X shops do the refinishing before spraying them?
    2mchfun likes this.
  15. Jul 29, 2023 at 11:29 AM
    SwitchThrottle
    This is what you have minus the top plate. You may be able to contact them and have the top plates shipped to you for a couple hundred, then get a local welder to attach them.
  16. Jul 29, 2023 at 11:33 AM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    GoRhino RB20, my 3 year old has zero issues getting into the truck on his own. Wife loves em and they look badass. I weigh 200# and zero flex. Best side step for the family imo
    2014 Black tundra likes this.
  17. Jul 29, 2023 at 11:40 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    How old are your kids?
    Sliders are much more durable, repairable and protectant than "steps".
    I'd consider lowering the truck over getting rid of sliders. That is extremely, but I have a feeling you will deeply regret switching to steps over sliders.
    Search out and talk to a local fabricator or welder. They will be able to put some top plates on them for you. They would even be able to just put them in the back if wanted and then remove when the kids are big enough.
    One thing to keep in mind with your current setup, they are not dog safe for jumping in and out of the truck. There legs can get hung up in the gaps. It's the reason I insisted on top plates and tight to the vehicle for mine.
    bulldog93 and Tripleconpanna like this.
  18. Jul 29, 2023 at 11:51 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I agree w/keeping the sliders and just installing some skateboard grip tape or something similar to those connecting bars between the 2 main rails...
    I don't know how this would be long term, but it's been great and has lasted several years on a few of my pistols....
    https://talongungrips.com/other-grips/diy-material/diy-5-x-7-material-sheets/
    I'd imagine 3 or 4 DIY sheets would handle both sides of the vehicle; this product is applied to the surface and then you heat w/hair dryer or heat gun to soften and activate the glue....
    Lastly something to consider before replacing them w/a standard step or nerf bar is the added rigidity to the frame; not sure if the sliders made a difference here, but it's amazing all the crunching stopped right where the sliders are:
    BravoDeltaRomeo and joonbug like this.
  19. Jul 29, 2023 at 11:52 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just slap on some skateboard tape and you’re done. Mine’s lasted a few years already.
  20. Jul 29, 2023 at 11:52 AM
    ohreary
    ohreary Party!
    2020 Platinum
    i have the amp research powered running boards on my truck. it’s way easier to get in and out because they are lower when extended. i got them when my wife was pregnant. she couldn’t get in an out after i had pulled off the stock running boards
  21. Jul 29, 2023 at 12:14 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I have grip tape as door sill protectors. Granted they are inside the truck, but stepped on daily and show no signs of wear after 3 years.
    It would be a cheap and easy trial.
    https://www.tundras.com/threads/10-grip-tape-door-sill-protectors.55042/
    joonbug[QUOTED] likes this.
  22. Jul 29, 2023 at 12:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah I thought it was going to be a pain in the ass to replace them often. But they’ve lasted 5-6 years already and they’re still on there like I put them on yesterday.
    Only spots the tape has come off is near the bottom from rock scrapes.
  23. Jul 29, 2023 at 1:22 PM
    drpheta
    I like the grip tape idea. I'll scrub these down and refresh them, then apply some grip tape.
  24. Jul 29, 2023 at 1:33 PM
    Shanet421
    San Diego,CA
    post some pics along the way…
    drpheta[QUOTED][OP] likes this.
  25. Jul 29, 2023 at 2:36 PM
    Tsm503
    2021 DC SR5
    Rock sliders are cool and functional, but if your kids are not able to get in/out of your vehicle. Best bet it to put some actual steps on until your littles ones are able. Then swap em out back out for the sliders later. Adding grip tape is just gonna rash em up real nice when they slip again.
  26. Jul 31, 2023 at 7:20 PM
    sstarkman
    sstarkman New Member
    2019 Tundra SR5
    Bilstein 8112 DSA+ +2.5” Front Shocks Dirt King BJ UCA Cooper AT3 XLT 285-75R18 Spidertrax 1.25” Alcan Custom Leafs +1” Fox TRD Pro 2.5” Rear Shocks Durobump Front and Rear Stock Airbox Mod AFE Filter OTT Rear Diff Breather Powertrax Grip Pro Frozen Rotors Front Hawk LTS Rough Country Speedo Cal Softopper Datin Fab Bed Cage CVT Mt. Hood Tent Total Chaos Bed Stiffeners Decked Drawers
  27. Jul 31, 2023 at 8:06 PM
    CTundraForMe
    CTundraForMe New Member
    I chose to get RCI sliders without the upper plate. I have 3 kids. They do fine.
    However I thought upfront if I lived in an environment where it was regularly muddy or icy/snowy, they'd be a problem.
    (I don't.)
    if that ever changes, I'd find some cheap way to get some grip on there. the tape looks promising.
    Tripleconpanna likes this.
  28. Aug 1, 2023 at 3:18 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    I have GORhino RB10. I picked these specifically for the family to get in/out. Kids have no issue.
