Expected mileage 5.7 tundra
Discussion in 'General Tundra Discussion' started by ifithaswheels, Jul 29, 2023.
  1. Jul 29, 2023 at 5:34 AM
    ifithaswheels
    ifithaswheels [OP] New Member
    Karl
    White TRD Supercharged
    Arb bar, arb air lockers, lift kit, wheels
    Hi all what is the expected mileage for a 5.7 tundra oil change every 6000miles with synthetic oil 5w20
    has anyone had an engine fail? What was the mileage? And what was the cause??thanks
  2. Jul 29, 2023 at 5:37 AM
    Taco-Spike
    Two Trucks
    Base 5.7 or super charged?
  3. Jul 29, 2023 at 5:41 AM
    ifithaswheels
    Karl
    Base non supercharge
  4. Jul 29, 2023 at 5:44 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Sounds like it was well taken care of, how many miles currently? Other PMs as well, depending on mileage swap out the other drivetrain fluids- transmission (drain/fill only), front/rear differential, transfer case, etc. A well maintained tundra can last as many miles as you're willing to put into it.
  5. Jul 29, 2023 at 5:47 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    On a recent trip to NH. from Pa. I got 16.6 on the highway set at 65 on cruise control. I thought that was pretty good. I get about 15.5 around town, but I'm easy on the pedal and stay within the speed limit whatever that might be. When it gets cold I usually see the 14 mile/gal range and way less if I use 4x4. 238K+ right now.
    ifithaswheels[OP] likes this.
  6. Jul 29, 2023 at 5:49 AM
    ifithaswheels
    Karl
    Current truck 2015 needed timing chains done at 150000 miles
    Was only one tensioner but deco to do the lot and new water pump too
    My mates in USA say 300,000 miles is not an issue for the 3ur 5.7?
  7. Jul 29, 2023 at 5:50 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    :anonymous: Did I gauge his question wrong. number of miles or mpg?
    Gene_in_FL likes this.
  8. Jul 29, 2023 at 5:52 AM
    ifithaswheels
    Karl
    Life expectancy of engine??
    Based on people’s experience
  9. Jul 29, 2023 at 5:53 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    :thumbsup:
  10. Jul 29, 2023 at 6:10 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    MY bad didn't read the question properly. I don't think 300k will be a problem with regular maintenance. Sorry about the previous response.
    Metro14536 and GODZILLA like this.
  11. Jul 29, 2023 at 6:16 AM
    18" TRD Off Road Wheels
    300K miles with good maintenance is readily achievable. Heck, 400k has been done often enough that I'd say it's not purely anecdotal.
    Metro14536, Terndrerrr and OHwendTrd like this.
  12. Jul 29, 2023 at 6:23 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Rarely, they throw a valve spring or have timing chain tensioner issues. Overwhelmingly, it is a low-stress engine that will keep noisily humming along for FAR longer than most people are willing to find out.
  13. Jul 29, 2023 at 10:37 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Change the oil every 5-7k, diffs every 30-40k and air filter every 10-15k.
    If you’re the drive it til the wheels fall off type (like me), you’ll have other stuff to worry about for a decade or two:thumbsup:
    dondino and Metro14536 like this.
  14. Jul 29, 2023 at 11:12 AM
    Mr Badwrench
    Mr Badwrench New Member
    With how stiff CAFE standards are getting, we'd better hope for 1 million miles. Trucks are going to cost as much as houses in 5 years.
  15. Jul 29, 2023 at 11:36 AM
    2mchfun
    Bump the oil to 5w-30 and it'll go longer. If it sits very much, add a prelube prior to start system such as Masterlube and you can expect even longer.
  16. Jul 29, 2023 at 3:35 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Most people say mine is just getting broken in. I haven’t had any engine problems yet. image.jpg
    ifithaswheels[OP] and dondino like this.
  17. Jul 29, 2023 at 5:28 PM
    ifithaswheels
    Karl
    has anyone used any liqui moly https://runautoparts.com.au/liqui-m...PZxTL53jh8CVxzibM2nFdNy_lIZv_r-BoC8G8QAvD_BwE
    Oil additives???!
    Some say they keep a film on all moving parts????? Stops wear? But I guess a good quality oil should have all that in it???
    look at my L/100 km on this trip…. It’s using Fuchs oil 5w20. After new timing chains
  18. Aug 12, 2023 at 2:58 PM
    doggunner
    doggunner New Member
    2014 Tundra Crew max White
    I have a 2014 with 612,000 miles or 984,000 Km
  19. Aug 12, 2023 at 5:25 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Awesome. I'm waaaay behind you at only 230K. ;)
    How is your driver's seat holding up, if I may ask?
  20. Aug 12, 2023 at 5:29 PM
    doggunner
    Not too bad. Has a wear spot from going in and out.
    Gene_in_FL and Y0TA PR0 like this.
  21. Aug 13, 2023 at 3:06 AM
    2014 Black tundra
    2014 tundra sr5
    I thought 105 k on my 2014 was getting up there. Looks like I’ll have mine for a long time.
  22. Aug 13, 2023 at 4:39 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    I am about to turn 300k on my 2013. Has seen 10-11k oci on toyota bulk oil for most of its life
    Gene_in_FL and dondino like this.
  23. Aug 13, 2023 at 5:50 AM
    ifithaswheels
    Karl
    Wow that’s truly amazing!
    What if any parts have you had to replace or re- build?
    Thanks
    TK1979, IsaiahCanada and ZPhilip like this.
  24. Aug 13, 2023 at 12:04 PM
    doggunner
    Not a whole lot. Usual up keep stuff. Original motor and drive train
    TK1979 likes this.
  25. Aug 13, 2023 at 12:27 PM
    TK1979
    TK1979 New Member
    TK
    Youngsville, NC
    2018 DC Limited
    Dual Exhaust and Side Steps
    Have a 2018 and shot past 113K with zero problems - hoping to make it to 500K :fingerscrossed:
    doggunner, Gene_in_FL and dondino like this.
