2023 1794 Stock Tires - More Aggressive
Discussion in '3rd Gen Tundras (2022+)' started by Makopower10, Jul 28, 2023.
  1. Jul 28, 2023 at 7:23 AM
    Makopower10
    Makopower10 [OP] New Member
    Hi all just bought a 2023 1794 black crewmax after a long hunt for inventory.
    Added a bakfip tonneau cover.
    Now I just want a more aggressive tire without going extreme. I'd like to stick with the stock size 265 60 r20. Anyone simply put an A/T on the 1794 (non trd) 20 inch rim? Id like ko2s but I'm not sure how the will look with such a thin sidewall. Any recommendations or photos to share? Coming from a 4runner with an aggressive tire to these passenger tires makes me nervous for mud and snow season up here in New England.
  2. Jul 28, 2023 at 9:14 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    I recommend 275/60/20. They fill the wheel opening much better and can be purchased in standard load range. This equals better ride, less weight and usually better price.
    i think you will like the look on your stock 1794 rims.
  3. Jul 28, 2023 at 9:33 AM
    Makopower10
    Those look nice. Will a 275 vs 265 add much height to the truck overall? I'm cutting it close height wise my garage already haha.
  4. Jul 28, 2023 at 10:17 AM
    PERRY1060
    Perry
    Indiana
    All Terrain style tire will make it look more aggressive than factory highway all season.
    cartage1 likes this.
  5. Jul 28, 2023 at 11:40 AM
    Mountainlord
    Mountainlord New Member
    I run the STT Cooper Pro tires… always had gotten really good mileage of them and they have a nice aggressive look
  6. Jul 28, 2023 at 11:53 AM
    Hugh_Jaynus
    Hugh_Jaynus New Member
    2023 Silver Tundra Platinum 4x4 Crewmax
    35"x11.5"r20 Nitto Recon Grapplers is what I went with. I had a 2" Ready Lift leveling kit installed and have no rubbing at all.
    They are a little heavier than the metrics so you could go with 275/65r20 (which are 34") if you want a lighter tire.
    I haven't seen a big difference in ride quality or gas milage but I just had them installed Monday.
    Hope this helps.
    Jorts, cartage1 and KClav like this.
  7. Jul 28, 2023 at 12:05 PM
    Erocaho
    Erocaho New Member
    Eric
    I put on 275/65/20 Nitto Recon Grappler 116T. No Lift and No Rub.
    cartage1, KClav and Jorts like this.
  8. Jul 28, 2023 at 12:08 PM
    Breathing Borla
    AZ
    I recommend Cooper AT3 4s 275/60/20
    https://coopertire.com/en-us/find-t...AQE2YwqQXLSjQ5ZVbXPkBXF3ayEzAU4xoCqEoQAvD_BwE
    These are P-rated, only weigh 6 lbs more than stock and are only slightly larger at .5" taller and made in the USA with a good warranty (65K), and also are very very quite on the highway and smooth.
    Don't go load E 35"s if your looking for stock ride quality and MPG, you just wont get it.
    Here is a couple shots on my platinum
    Whitatu19 and DMackler like this.
  9. Aug 3, 2023 at 9:56 AM
    Makopower10
    Thanks everyone super helpful to see photos!!
    Hugh_Jaynus likes this.
  10. Aug 6, 2023 at 8:12 PM
    cybertruck7
    cybertruck7 New Member
    Those Pirelli's look great
  11. Aug 6, 2023 at 8:21 PM
    Hella Krusty
    Hella Krusty New Member
    Its a struggle. I am in Canada so need a snowflake rated tire that I can run year round, I dont want E rated because of the ride. I dont want 2 sets of tires for the 2 seasons, I love my stock ride. And I will go to a 275/60/20. Maybe I should just go south for the winter
  12. Nov 14, 2023 at 2:21 PM
    ericscott21
    ericscott21 New Member
    Eric
    2023 Army Green Tundra
    If you don’t mind giving an update, what kind of gas mileage have you seen since installing the leveling kit and 35’s? I’d like to do the same to my Limited but drive quite a bit for work. Thanks!!
  13. Nov 14, 2023 at 7:53 PM
    Hugh_Jaynus
    15.7 according to the truck (I do a lot of city driving). I'm sure the mpg calculations are off slightly because of the bigger tires just like my speedometer.
