Payload variance
Discussion in '3rd Gen Tundras (2022+)' started by mtaylor7210, Jul 26, 2023.
  1. Jul 26, 2023 at 12:29 PM
    mtaylor7210
    mtaylor7210 [OP] New Member
    Does anyone else's door sticker not match what toyota has put out for payload capacity?
    I've got a 23 trd pro and everything on the internet says 1600 payload but the door sticker is 1350 which is worse than a raptor.
  2. Jul 26, 2023 at 12:33 PM
    No one’s door sticker matches the brochures. Those listed payloads are max available for any model. Usually based on the lowest and least equipped. Add any options (i.e. weight) and it all subtracts from payload.
  3. Jul 26, 2023 at 12:36 PM
    mtaylor7210
    yeah they installed a bedliner and threw on a sticker that stated it was lowered by 24lbs. But I'm specifically talking about the factory sticker that gives max payload.
  4. Jul 26, 2023 at 12:50 PM
    mtaylor7210
    Yeah it's just funny because the TRD PRO doesn't really have any options.
  5. Jul 26, 2023 at 12:53 PM
    Pic of your door sticker?
  6. Jul 26, 2023 at 12:55 PM
    Breathing Borla
    AZ
    it doesn't matter anyway, weigh it to find the real number
    Black Wolf and Mattedfred like this.
  7. Jul 26, 2023 at 12:58 PM
    I think in the case of a model not available with any options, it could matter. Why list a 1600# payload if it’s really 1350#? Seems like misleading advertisement
  8. Jul 26, 2023 at 1:05 PM
    Breathing Borla
    AZ
    I get that but nobody is going to hire a lawyer and sue Toyota over it to get it changed to my suggestion is move on and weigh the truck, CAT scales will tell you the real payload instead of some marketing BS
    most people who are weighing are finding several hundred pounds of extra capacity over the rating, I think toyota sandbagged the rating a bit
    anyways, just my .02
  9. Jul 26, 2023 at 1:06 PM
    I hear ya, but why the 1350# sticker?
  10. Jul 26, 2023 at 1:12 PM
    Breathing Borla
    AZ
    my guess, cost savings, it would be a increased cost to come up with a payload of just a Pro which is a small unit sales model.
    or marketing blows
  11. Jul 26, 2023 at 2:36 PM
    mtaylor7210
    I think someone didn't know how to work the scales I checked the gvwr and that matches toyota's site of 7615 so either the trd pro is heavier then they are saying or they can't do simple math. Either way I think i'll end up running it through a scale to get a better idea.
    Mattedfred likes this.
  12. Jul 26, 2023 at 2:41 PM
    Breathing Borla
    AZ
    ya run it through the scales empty as you can get it and report back, it would be interesting to hear.
    remember everything you add counts, tonneau , hitch, bed liner, mats, etc.
  13. Jul 26, 2023 at 4:18 PM
    Black Beauty 5.7
    Black Beauty 5.7 New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    I don't think that the optional hybrid battery and driveline system under the backseat is taken into account for payload capacity in lower trim levels... That's the only think I could think of. Because you got the trd pro with the hybrid they take off however much the battery weighs
  14. Jul 26, 2023 at 4:20 PM
    The TRD pro is only available as a Hybrid, which has the higher GVWR vs the non-hybrid.
    Breathing Borla likes this.
  15. Jul 26, 2023 at 4:25 PM
    Black Beauty 5.7
    Cannon
    It might have a higher GVWR but that doesn't mean it has a higher payload. Bigger battery = more weight = higher GVWR but lesser payload
  16. Jul 26, 2023 at 4:29 PM
    Op is saying it’s advertised as 1600# specifically for the TRD Pro which is only available in one cab config and one drivetrain with no available option packages. So why does his door sticker say 1350#. Shouldn't it say 1600#? Legit question.
    Alden, Mattedfred and Breathing Borla like this.
  17. Jul 26, 2023 at 4:33 PM
    Black Beauty 5.7
    Cannon
    oh I apologize I misread this forum. I think that's how every truck is tbh like someone else said. the sticker never matches what the dealership/advertisement says. Whether that be because they overestimated it before production or another unknown reason. It might also have something to do with the tires since the payload sticker is shared with tire pressure information?
  18. Jul 26, 2023 at 4:39 PM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    It was the same on my 2020. If you look at the brochure for a 4x4 crewmax it has its specific payload, and my door sticker was a few hundred pounds less than that, which is crazy. Payload sticker was around 1,250 or so.
  19. Jul 27, 2023 at 9:13 AM
    xc_tc
    xc_tc New Member
    The payload Toyota puts on the door jamb sticker is based on each model code’s GVWR. They’re conservative so the payload used the fully optioned vehicle for each model code. Many people have taken their trucks to the scales and found that their payload is higher than the sticker because their trucks are not fully optioned. I only have the table from the non-hybrid but I suspect the story is the same for the hybrid. Toyota advertises some different payload numbers online but they call it “Max Payload” which could mean the payload for the least optioned truck. They also make this disclaimer:
  20. Jul 27, 2023 at 9:19 AM
    xc_tc
    xc_tc New Member
    This is the load carrying capacity table. It should match the sticker perfectly for your given model code. If you have a hybrid, look in your owners manual.
  21. Jul 27, 2023 at 9:25 AM
    So the sticker on his door jamb is for a limited crewmax hybrid 4x4, not a TRD pro specifically?
  22. Jul 27, 2023 at 9:37 AM
    xc_tc
    xc_tc New Member
    Seems that way. If you look at the website specs, you can see that Payload = Base Curb Weight - GVWR for each spec. Base curb weight likely means least optioned spec.
  23. Jul 27, 2023 at 9:38 AM
    But the TRD PRO has only one spec. So it would seem they aren’t separating it from the others
