07-13 OEM Headlight Options
Discussion in '2nd Gen Tundras (2007-2013)' started by bdawson, Jul 26, 2023.
  1. Jul 26, 2023 at 12:25 PM
    bdawson
    bdawson [OP] New Member
    2012 Tundra
    I just bought a 2012 Tundra Crew Max and I want to replace the headlights with new OEM lights. When I search for OEM headlights I get 4 part numbers (per side) with a big price spread. Using my actual VIN, the dealer says that I need the most expensive one.
    My question is, does anyone know why there are 4 PNs and what is the actual difference? Basically can I buy one of the cheaper options and will it fit?
    Thanks guys. Sorry if this was covered elsewhere but I couldn't find it.
    All of these PNs show up for '07-'13 Tundra. However, dealer says my VIN calls for the top one.
    LH 81150-0C070 - $294
    LH 81170-0C070 - $247
    LH 81150-0C051 - $219
    LH 81170-0C051 - $173
  2. Jul 26, 2023 at 1:44 PM
    Some of the parts sites say that one set is a sealed beam and the other is a non-sealed beam. Both have leveling motors and either one will fit your truck.
  3. Jul 26, 2023 at 3:04 PM
    bdawson
    2012 Tundra
    I always thought sealed beam meant the old school style where you had to replace the whole headlight assembly. Maybe a different definition of "sealed"?
    It does seem like the cheaper PNs are non-leveling vs. leveling.
  4. Jul 26, 2023 at 3:05 PM
    clarks
    clarks New Member
    21 Tundra TRD Sport
    I was just researching this at my local dealership. Some parts come with auto leveling and the others don't. Also, some parts included the light assembly and all the bulbs/boots as pictured in the parts diagram. I think my dealer had 3 options for each side and prices ranged from 26x to 320; higher price had the bulbs and auto leveling.
  5. Jul 26, 2023 at 3:07 PM
    blenton
    blenton New Member
    I'm pretty sure this is correct. I had to get new headlights for my '13 recently and that is conclusion I came to. I have headlight leveling on my tundra, but not on my sequoia; the cheaper parts number came up for my sequoia, but the more expensive part came up for my tundra. I found some websites to describe as much - manual leveling vs non leveling headlights.
  6. Jul 27, 2023 at 8:39 AM
    bdawson
    2012 Tundra
    Ok yeah that must be it. I hadn't noticed but there is a switch inside the truck to electronically adjust the headlight height. I assume this is for when you are towing and the trucks nose points up. I suppose the mounting is the same but the harness will be different, etc.
    And the two PNs "with leveling" seem to be one has bulbs and one is just the lens and housing.
    LH with leveling 81150-0C070 - $294 (includes bulbs)
    LH with leveling 81170-0C070 - $247
  7. Jul 27, 2023 at 9:13 AM
    clarks
    clarks New Member
    21 Tundra TRD Sport
    Let me know how the install goes. My son's truck leveling headlights seem to be not going low enough and he wants to put a level kit on so we may have to replace the headlights to make sure they adjust all the way.
  8. Jul 27, 2023 at 9:22 AM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
  9. Jul 27, 2023 at 12:17 PM
    bdawson
    2012 Tundra
    Any recommendations for where to order OEM parts on the west coast (California)? Seems like all the distributors are in Texas or the east coast and then shipping is high.
  10. Jul 27, 2023 at 1:17 PM
    clarks
    clarks New Member
    21 Tundra TRD Sport
    I order parts from Camelback Toyota in Phx, AZ. If ordering online, they seem to be cheaper than most places but sometimes I find cheaper by using ebay.
    https://parts.camelbacktoyota.com/v-2010-toyota-tundra--limited--5-7l-v8-gas
    bdawson[QUOTED][OP] likes this.
  11. Jul 27, 2023 at 3:15 PM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    Before you decide to replace them, make sure that there is not a manual adjustment to get them withing the range of the leveling adjuster. I would look at mine, but I'm not near my truck at the moment.
  12. Jul 27, 2023 at 3:50 PM
    bdawson
    2012 Tundra
    Not sure I follow. I did see the word "manual" in the vague PN description. "HEADLAMP LEVELING DEVICE-WITH(MANUAL)".
  13. Jul 27, 2023 at 8:45 PM
    blenton
    blenton New Member
    If I'm understanding what CTB Mike is trying to say, the headlights should have some manual adjustment at the headlight itself - usually with a screwdriver. I honestly haven't looked at mine since my buddy is an auto body guru and has taken care of them for me. Anyways, you should be able to aim the headlights from the front of the vehicle; pull up to your garage or side of the house where you can be on level ground and turn your headlights on. You will see where the headlights are aimed. You should be able to adjust them to compensate for a lift, for example, back to where they should be stock.
    Once the headlights are aimed correctly, you can use the leveling adjustment in the cab to adjust for heavy loads or a trailer. Hopefully that makes it a little clearer.
  14. Jul 28, 2023 at 4:11 PM
    CTB Mike
    Southern Arizona
    Yes, thank you for explaining it better than I did.
