Long gun storage? 2017 Crewmax with camper shell
Discussion in '2.5 Gen Tundras (2014-2021)' started by convex, Jul 27, 2023.
  1. Jul 27, 2023 at 7:59 AM
    convex
    convex [OP] New Member
    Robert
    Columbia SC
    ARE Topper Yakima rack Dual Dash Cams
    My kid is wanting to join her schools sporting clays team.
    For those of you that hunt/shoot with shotguns and rifles, where do you secure your firearms?
    At one point, I think there was someone who did some sort of bracket modification so the back of the rear seat could be more easily lifted out for storage behind the rear seat. This would be preferred, but I'm also looking at tool boxes for the back of the truck
    I'm also looking looking at a locking box, over the wheel, tool box sort of thing. This one hangs off the rail.
    https://www.du-ha.com/humpstor.html
    Anyone use similar products? What do you do? TIA
  2. Jul 27, 2023 at 8:11 AM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Patch999 and convex[OP] like this.
  3. Jul 27, 2023 at 8:21 AM
    PermaFrostTRD
    Northern NY
    This would be the only option I would consider "secure". I wouldn't trust a rifle/shotgun in a truck bed unless you're removing the rifle any time you're leaving the truck for longer than a quick run into the gas station.
  4. Jul 27, 2023 at 8:23 AM
    convex
    Robert
    Columbia SC
  5. Jul 27, 2023 at 11:28 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    I slide 'em in one of my Decked drawers ;)
    convex[OP] likes this.
  6. Oct 24, 2023 at 5:29 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Just curious if you ended up buying this?
  7. Nov 21, 2023 at 12:49 PM
    convex
    Robert
    Columbia SC
    I did. The guns we shoot don't fit. It's good for smaller stuff I guess. Looking into making some taller drawers for the bed and covering it with some black carpeting. My bed has a camper shell on it and a deck with a couple of drawers under it might work better.
    Leo's first likes this.
  8. Nov 21, 2023 at 2:38 PM
    bfunke
    bfunke Tundra Curmudgeon
    Longing for the old days when pickups in the HS parking lot had racks with rifles in the rear windows. It was a simpler time.
    Haint, WFD473, Leo's first and 3 others like this.
  9. Nov 21, 2023 at 6:37 PM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    I took my trap gun to school every week in the trunk of my car. They were simpler times with less nonsense and more accountability from kids.
    I do like the deckd drawer method. Seems solid.
    Tripleconpanna likes this.
  10. Sep 23, 2024 at 2:34 PM
    wtofd
    wtofd New Member
    ID
    2024 Tundra TRD OR
    Moving blanket over rear seat
    Did they remove the bolts for the day or just the ammo?
  11. Sep 23, 2024 at 3:19 PM
    kevine0001
    kevine0001 New Member
    Kevin
    I ordered an ESP for under the rear seat, but it's the three box one. Not one long storage compartment. A few months after, I found a guy who used small steel containers (think high school cafeteria pans) and inserted it into the openings. Smart and way cheaper.
    Flash forward and this idea would work only if you can do some light welding. Cut the rectangle hole, use 1/8" plate steel and make the box. Weld hinges and drill hole for lock. Add foam from a gun case to the bottom and top. It's not that hard. Especially when the ESP one is over $800. Might not be as pretty, but it'll be as secure depending on the lock you use. There's several out there. As far as fitting a long gun, not sure about a rifle, but for a shotty, just remove the barrel if it's too long.
  12. Sep 24, 2024 at 4:12 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    Where I'm from they didn't even lock the doors. Different times.
    2mchfun and Leo's first like this.
  13. Sep 24, 2024 at 4:49 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Yep 1985 I drove a 1970 J3000 room in the cab for two people and three rifles one being my 22 that lived in the truck on the back window rack
    WFD473 likes this.
  14. Sep 24, 2024 at 8:50 AM
    seydou
    seydou Distinguished Member
    LOL Guess you had to be there(then) to understand.
  15. Sep 26, 2024 at 4:30 PM
    ohreary
    ohreary Party!
    2020 Platinum
  16. Sep 27, 2024 at 1:21 PM
    aggiec05
    aggiec05 New Member
    Kyle
    Feels like this would block a lot of the rearview mirror. How much does it actually block it? I go back and forth on replacing my diamondback with a nice camper top.
  17. Oct 1, 2024 at 4:28 AM
    ohreary
    ohreary Party!
    2020 Platinum
    visibility out the back isn’t that great with the camper top, but it’s not bad with the reverse camera. i can see most things using just the side mirrors.
    wtofd likes this.
  18. Oct 1, 2024 at 8:02 AM
    wtofd
    wtofd New Member
    ID
    2024 Tundra TRD OR
    I don't like anything in the rearview mirror but this solves a bigger problem of maintaining bed space. It's a great solution; maybe not for everyone, but really smart.
  19. Oct 1, 2024 at 7:58 PM
    jmanscotch
    jmanscotch New Member
    Jake
    2020 Tundra TRD OR CM
