2015 SR 4.6 2WD to 4WD conversion
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mehnock, Jul 25, 2023.
  1. Jul 25, 2023 at 2:14 PM
    Mehnock
    Mehnock [OP] New Member
    Tundra 2015 SR 2WD
    Leather Seats, leather wrapped steering wheel + audio controls, auto folding mirrors with turn signal, Android auto 10in head unit, working on 2wd to 4wd conversion
    So I have a 2015 SR 2WD and I bought a [not running] 2008 Limited 4WD; I'm planning to convert the 2015 to 4WD and need to know if anyone can confirm the 5.7 tranny will work on the 4.6 engine and ECU.
    My plan is the following:
    Move the tranny and transfer case
    Move the Front ADD, CV joins and wheel knuckles
    Install a 2015 4wd ECU and wire it for the transfer case actuator and ADD actuator
    Reset the main body ECU so it "learns" about the new components installed
    Possibly move the rear diff gears from the 08 to the 15 to match tranny, ADD gearing.
    I'm keeping the 2015 for the rest of my life so trading is not an option for me but I want a 4WD.
  2. Jul 25, 2023 at 2:18 PM
    I'm gonna go with no. It will not "learn" the new hardware. It's been programmed with parameters for specific hardware and specific combinations. The transmissions were not the same between the two engines either. Can you get all these parts to work together somehow? Maybe. Gonna take interface modules and lots of repining harnesses. Not worth it.
  3. Jul 26, 2023 at 5:39 AM
    Mehnock
    Tundra 2015 SR 2WD
  4. Jul 26, 2023 at 5:41 AM
  5. Jul 26, 2023 at 5:47 AM
    Are they both 6 speeds? Yes, same. Are they identical and can be interchanged Willy nilly? Nope, not same. They share many parts and construction, but not all.
  6. Jul 26, 2023 at 5:55 AM
    Mehnock
    Tundra 2015 SR 2WD
    Ok, plan B; if I cannot move the 5.7 tranny into the 4.6 truck, does anyone have info on the A760E/F differences?
    Is it just the extension housing that is different or is there a different output shaft to connect to the transfer case/drive shaft, depending if it's 2WD or 4WD?
    If the output shaft is different, does anyone know if it can be swapped without taking apart the whole transmission?
  7. Jul 26, 2023 at 8:59 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Wow, that's pretty ambitious... Good luck.
    So I'm curious... "I'm keeping the 2015 for the rest of my life so trading is not an option for me but I want a 4WD."
    Is there a sentimental attachment to the 2015?
  8. Jul 26, 2023 at 9:37 AM
    Mehnock
    Tundra 2015 SR 2WD
    Well I really like it, but the main reason is I know it's in good condition. You can't but a V8 new anymore and I've had mine for three years and 50K miles and no problems. I looked around for a 4wd and they all looked beaten up under $20k and I didn't want to spend more than that.
    The conversion is simply bolting parts that could have come on it from the factory!
  9. Jul 26, 2023 at 9:52 AM
    Well, not that simple, but doable. Better off with a proper donor vehicle with appropriate matching parts though.
  10. Jul 26, 2023 at 10:04 AM
    SD Surfer
    Bruce
    So Cal
    Ahhhh, gotchya.
    I used to enjoy wrenching on stuff from the old days when you had room to work and could see the stuff you're trying to get to. (and I could lay under a truck without needing to go to the chiropractor the next day)
    I look under the hood of modern vehicles now and go :eek2: "Nope, I'll pay my guy to do that while I go surfin'!" :rofl:
    If you do it, take lots of pictures and post a write up!
    Slag_Dynamics likes this.
  11. Jul 26, 2023 at 10:06 AM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    I’m sure this is doable, certainly not plug and play, and I’m glad I’m not the one undertaking it, but I’m along for the ride!
  12. Jul 26, 2023 at 10:35 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I have done motor swaps when I was younger. Nissan 240sx with sr20det. I've help do 2jzgte swap into a Lexus GS300. I also helped friends do automatic to manual conversions. To be honest, I have never looked into doing a 2wd to 4wd conversion in a Tundra. But I don't think it's as simple as plug and play and bolting on 4wd parts. The ECU will not "learn" the new parts. I'm not saying it's impossible. While 2007-2021 share a lot of the same parts, some are different. I would try to find donor parts from another 2015 Tundra 4.6 (or at least a 2.5 gen)...the tranny, ECU, all 4wd front end parts , etc. You may also need the electronic on inside...dash, gauge cluster, switch, wire harness, etc If you're trying to use the parts from the 2008 5.7 it will make it more difficult. The wire harness may be also different in the 2008 5.7 vs 2015 4.6 I applaud you for wanting to attempt it. Please keep us updated.
    KNABORES likes this.
  13. Jul 26, 2023 at 10:38 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Look up Cruzer’s rubicon build thread. Lots of great info you need about the front diff, t case, and transmissions. The 4.6 trans has different rations than the 5.7 trans I believe so they aren’t identical
  14. Jul 26, 2023 at 10:52 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    While I have no doubt you can swap everything around, another option you might want to consider is you could do a divorced transfer case and then install the front components. Then your transfer case and differential will be their own isolated unit and not talk to the truck (either as a fully manual setup, or an electronic "manual" setup). It would require some fabrication skills to mount the tcase, though that might be inevitable with either path you go down. But you would drastically simplify everything else since you don't have to screw with the stock electronics, and your 4WD would not be based on what the truck wants to do (which anyone that has driven stick shifted tcase knows is far superior than the annoying electronic shit of modern tcases). Additionally you could customize the tcase to what you want specifically and get a much stronger one, lower gearing, more gear options, front dig, etc. if you wanted. And it doesn't necessarily have to be divorced, but if it was divorced you wouldn't need to attach to the transmission at all. Functionally it would be the exact same either way.
    Food for thought.
    SD Surfer likes this.
  15. Jul 26, 2023 at 11:07 AM
    Mehnock
    Tundra 2015 SR 2WD
    Yeah, I looked into a divorced setup but I came across this non-running [bad ecm] 2008 Limited 4WD and I bought it. The engine has good compression so I'll sell it and recoup most of what I spent on the truck so the conversion is essentially free.
    The ADD and TCase are the same parts and so are the front drive shaft and the cv joins.
    I looked at the 4WD ecu diagrams of both the 2008 and 2015 and the 2015 is way more simple so I will use it and wire it to drive the actuators (tcase and ADD).
    From what I've read, once I plugin the 4wd ecu to the CAN bus [and] reset the main ECM, the truck will be "converted" electronically to a 4WD, the dash will light up the 4wd lights to signal something is wrong with the tcase and ADD and once I plug them in, it will see them and use them based on what I command them to do with the 4wd switch on the dash -- still to be installed.
    It's all theoretical though.
  16. Jul 26, 2023 at 11:21 AM
    Slag_Dynamics
    Arizona
    Gone
    I think this is going to be one of those things you’re just going to have to dive in and troubleshoot as you go. I haven’t seen anyone doing this specific swap, so I doubt anyone on here has first hand knowledge of compatibility, but hopefully it works out for you and you can do a write up to help others navigate similar swaps.
    Mehnock[OP] likes this.
  17. Jul 26, 2023 at 11:42 AM
    Mehnock
    Tundra 2015 SR 2WD
    It is all theory but if you shop for the main ECU for my 2WD and shop for a 4WD, you get to the same part number (896610CP13). If you look at the what fits section of the Toyota parts website for this PN, you see all models 2014 to 2018 both 2wd and 4wd use the same ECU.
    Here is where resetting the ECU comes into play; when reset or installed new, it learns what is connected in the CAN bus and makes use of it.
    Now can someone confirm this theory?
  18. Sep 14, 2023 at 5:19 AM
    Mehnock
    Tundra 2015 SR 2WD
    Update: It seems Toyota has customized the bellhousing of both the AB60 and A760E/F and they are both interchangeable. I got confirmation from another fellow Tundras.com member and he swapped a 4.6 engine into a 5.7 truck successfully and everything bolted right on and worked just fine.
    So now I'm going to help my son fix up a 5-series he bought so he can lend it to me while I take my Tundra offline for a few weeks to install the front ADD, rear diff, transfer case, front and rear drive shafts, front CV joins, new front wheel bearings, electronics, etc.
    Stay tuned!
