Tow Mater
Discussion in '2.5 Gen Builds (2014-2021)' started by Mater, Apr 24, 2020.
  1. Jul 20, 2023 at 8:21 PM
    #271
    Mater
    Mater [OP] New Member
    SD
    2016 MGM Platinum
    One 4awg into the cab for amp, two 6awg to the bed for dc-dc, One 16/4 to the bed from switchpro for lights, arb compressor power cable, and pass ditch light. Fits it all with room to spare.
  2. Jul 20, 2023 at 8:22 PM
    #272
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    dang, that is a lot of ish.
  3. Jul 21, 2023 at 5:20 AM
    #273
    Hipmatt
    Hipmatt New Member
    kern County
    2015 Tundra 5.7 Crewmax SR5
    Remote start
    Very sweet ride!
    Saw your build and started looking up Valhalla's Cat Plates on Amazon.....not disappointed at all lol
  4. Jul 21, 2023 at 9:18 AM
    #274
    Mater
    SD
    2016 MGM Platinum
    Thanks :hattip:
    Those kitten plates are pretty sweet tho! Bet if you tacked a few of those to the undercarriage it’d do the job. Thieves would think you’re :crazy:
    And I probably wouldn’t recommend ordering from Valhalla at this time. They’ve had a hard time keeping up with orders and some people have waited for over a year. Unless you really need the 3/16 steel then not much sense in going Valhalla. Talons garage whips them out pretty quickly and makes a nice 1/4 aluminum plate which should be more than adequate for most vehicles. Plenty of other cat shield manufacturers too.
    Welcome to the forum!! Glad you’re here
    Talon2006 and RainMan_PNW like this.
  5. Jul 25, 2023 at 10:07 PM
    #275
    Mater
    SD
    2016 MGM Platinum
    Finally have onboard air. The arb went on sale so figured I’d switch out to that. There was no way the Morrflate was fitting under the cowl and I was getting sick of lugging it around and taking it in/out of the truck when needed. While I will miss the speed (and price) of the TenSix, I think this was the right way to go. One major bonus factor for the arb is that parts are available and they’re fairly easy to rebuild. B87B5D6B-A1DB-4242-A75C-ADA5E3420A2C.jpg 11969219-1983-4FEF-982F-2D4E7DCA866D.jpg016E9C57-1329-45C7-A54E-D081A4132206.jpg5E2C35E0-4BAB-4829-BE8F-0664070E53EE.jpgD9ABA196-205B-4145-8A0B-A7C519E24DB7.jpg
  6. Jul 25, 2023 at 10:13 PM
    #276
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  7. Jul 25, 2023 at 10:16 PM
    #277
    Mater
    SD
    2016 MGM Platinum
    BiggHertz[QUOTED] likes this.
  8. Aug 11, 2023 at 2:56 PM
    #278
    Mater
    SD
    2016 MGM Platinum
    After a quick text message consultation with @RainMan_PNW on cutting margins, I trimmed up the tetanus bumper to hopefully prevent any rubbing.
    I was on the fence about fabricating a spare tire swingout after reading pros/cons of them, but after these 4 cuts I quickly realized that metalwork may not be my calling in life. Although, it is amazing how a flap disc can make your work look a hell of a lot prettier.
    0E0A5D62-2DDE-45F6-810A-61D8384EABD7.jpg D1B02335-78B7-4615-9840-86459E06CC42.jpg
    RainMan_PNW, SAGE63, des2mtn and 3 others like this.
  9. Aug 13, 2023 at 9:15 AM
    #279
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Time for a sandblast and recoat!
    BiggHertz and Mater[QUOTED][OP] like this.
  10. Sep 1, 2023 at 4:25 PM
    #280
    Mater
    SD
    2016 MGM Platinum
    After a quick consultation with @BiggHertz on how to mount the Icom speaker in the dash I decided to give it a whirl. Pretty sure he downplayed it because it was a lot tighter than expected and the light sensor plug gets in the way. Anyways, so I had to adjust the setup and tuck it under the dash a bit. Jason suggested I use abs but that’s a little too expensive for my taste so I decided to use an old AZ license plate I had laying around instead. Seems to be pretty solid #AZspec
    F29B6526-375E-45D1-9539-A2C2B0969613.jpg AD5CC9A6-B118-4960-B271-8DEAEF1916CD.jpg 92A85B4A-2B5B-447D-BFA8-E0246295A2CE.jpg
    After that I focused on the overhead center console and relocated my switch pro and also moved my radio to the old switch pro location while I was in there.
  11. Sep 1, 2023 at 4:39 PM
    #281
    RainMan_PNW
    Casey
    Clark County, WA
    Nice idea
    Mater[QUOTED][OP] likes this.
  12. Sep 1, 2023 at 5:09 PM
    #282
    SAGE63
    San Diego County
    Way to much for me...8>)
    BiggHertz and Mater[OP] like this.
  13. Sep 1, 2023 at 6:26 PM
    #283
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    NOICE!
  14. Oct 10, 2023 at 4:53 PM
    #284
    Mater
    SD
    2016 MGM Platinum
    To give some people a sense of the level of :crazy:
    Traction boards < solar panel < surfboard
    1DD1C009-850C-4B60-841A-C7461721CB68.jpg 3ED96345-11A0-4977-98CE-051E7AB78F84.jpg 16BB0AC7-84CA-4BE7-8EA4-FDF573C9C6AB.jpg
    should fit as-is. Can always lift the board if needed. Panel will be on hinges and Clevis pin
  15. Nov 15, 2023 at 8:23 PM
    #285
    Mater
    SD
    2016 MGM Platinum
    Bumperpox bumper doesn’t look too bad does it @memario1214
    A77FA649-1F8D-4056-A999-729F7D6CBB80.jpg 5291A3C4-0F8A-43EB-9B52-D3F2ED9E052F.jpg
  16. Nov 15, 2023 at 11:57 PM
    #286
    SAGE63
    San Diego County
    What did you coat the bumper with?
  17. Nov 16, 2023 at 7:36 AM
    #287
    Mater
    SD
    2016 MGM Platinum
    LineX. Adds quite a bit of girth. Just hope it fits :fingerscrossed:
  18. Nov 16, 2023 at 9:14 AM
    #288
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    IT'S ALIVE!!!
  19. Nov 16, 2023 at 9:16 AM
    #289
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  20. Nov 17, 2023 at 6:34 PM
    #290
    RainMan_PNW
    Casey
    Clark County, WA
    Like a tuna can
  21. Nov 20, 2023 at 11:29 PM
    #291
    Mater
    SD
    2016 MGM Platinum
    Alright, so a quick update on this bumper. I have a few photos that i'll upload later.
    The bumper went on with plenty of snags (all of them my own doing). The first issue and I saw this one coming a mile away was due to the thicker line-x compared to powder coating or even just a rustoleum bedliner rattle can job. Second issue was that the BSMs from 2014-2017 don't work with this bumper. I knew this, and musta read it at least 4 times, but still bought the bumper anyway. We'll blame that on sleep deprivation. Third issue (and this goes alongside #1) is that with this extra line-x, the bumper still slightly rubs against the tailgate even though I clearanced for it to fit. Corners near BSM pockets fit great though. Final issue was that after I had buttoned everything up for the day.. the rear parking sensors didn't work. This one was a big blow to the ego because they literally swap over from one bumper to the other. Parked the truck, put my tools in a pile and went inside for a drink. After thinking on it, here were (are) my solutions:
    For problem 1 with the line-x, had to mount twice with a dismount in between to hit the mating surfaces with an orbital sander. Bumper went on fine after that.
    Problem 2 (and this one is still TBD), but a quick EWD check shows the connectors for the BSMs from 2014-2017 and 2018-2021 are the same. The wiring for the slave (driver side) BSM is the same and there is a difference of 2 additional wires on 2014-2017 passenger BSM. Both old and new BSMs have 10 pins so I began wondering if the only difference is the shape. Old BSMs mount horizontally while new are vertical. I started looking at the BSMs on ebay and they range around 100 bucks a pop. A little pricey but I was willing to pay that to bring the feature back. While searching on ebay I found about ten different toyota product codes for what looked to be the same BSM. I knew that the BSM part numbers are the same regardless of mounting on the driver or passenger side, so how different could they be. Then, randomly, a Subaru BSM fell into my search. It looked identical to the toyota product. Then I noticed every one of the new BSMs said model SRR3A - toyota, subaru, mazda. I looked at my old BSMs and their model is SRR2A. This gave me a little hope that maybe it's the same BSM but just in a different configuration. Finally, I punched in SRR3B.. same BSM as SRR3A just different mounting holes. When I saw this, I said why not. The expansion of BSMs to include subaru and mazda dropped the price point from 100 to 40 per sensor. We'll see if it works, to be continued..
    Problem 3 will be solved by putting on some edge trim. If the tailgate gets scratched up bad enough I'll have it repainted or go find another one
    Problem 4 was dealt with the next day. While the kiddos were napping/having quiet time I snuck under the truck and pushed all the connectors in. Heard the SR1 connector click and thought that was it. Went back into the truck.. nope. Crawled back underneath and made sure to push each wire on each connector in as well. I also relieved some stress on the sensor wires and flattened out the sensor connectors as best as I could. That worked. I don't really use this feature but if it continues to give me trouble I'll either completely remake (and break out) the BSM, parking sensor, license plate light harnesses or just go without.
  22. Nov 21, 2023 at 6:28 AM
    #292
    RainMan_PNW
    Casey
    Clark County, WA
    Good find on the sensors. I have found similar things in the past on many parts for Japanese rigs. :fingerscrossed: That they plug in and fire just fine
  23. Nov 25, 2023 at 10:06 AM
    #293
    Translucent
    Translucent New Member
    Black 2020 SR5 Sport
    Where is that plate from that holds the buttons?
  24. Nov 25, 2023 at 10:49 AM
    #294
    Mater
    SD
    2016 MGM Platinum
  25. Nov 25, 2023 at 10:54 AM
    #295
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ve got the thru bolt version that I messed up on when sanding, but it could probably be cleaned up pretty easily with some filler primer and light sanding. Should be pretty cheap to ship if you want to try it @Translucent
  26. Nov 25, 2023 at 4:34 PM
    #296
    Translucent
    I'll dm you
    TRDFerguson[QUOTED] likes this.
  27. Nov 26, 2023 at 3:55 PM
    #297
    Mater
    SD
    2016 MGM Platinum
    Seeing this brought back some memories..
    Wife saw me snapping the photo and said “looks a hell of a lot nicer without all the crap mounted on it..”
    Also, don’t have stats pretty sure Maui is the 2.5 gen capital of the world. Something like 160k ppl on this island and I’ve easily seen 200+ ‘14-‘21s just in my travels
  28. Nov 26, 2023 at 3:58 PM
    #298
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :eek: (shock)
    :( (disbelief)
    :mad: (anger)
    resolution:
    :rofl::rofl::rofl:
  29. Nov 26, 2023 at 4:00 PM
    #299
    Mater
    SD
    2016 MGM Platinum
    :rofl::rofl::rofl:
  30. Nov 26, 2023 at 4:44 PM
    #300
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    But are they all running around on 33x13.5s looking like skateboards?
