  1. Jul 25, 2023 at 11:00 AM
    Aaaand the water shut off valve for the toilet doesn't work. :censored::censored::censored:
    I'd rather take a beating than do plumbing, because what should be simple and easy NEVER is when it comes to water.
  2. Jul 25, 2023 at 11:06 AM
    Turn off the water for the entire house and then troubleshoot. Maybe just a faulty valve
  3. Jul 25, 2023 at 11:22 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Apparently, he doesn't want his tractor door dinged :laugh:
  4. Jul 25, 2023 at 11:30 AM
    NWPirate
    Zach
    WA
    Yep, valve took a shit.
    A plumber buddy of mine told me to exercise the toilet valves once a year to keep them free, excellent advice I have yet to do. :anonymous:
  5. Jul 25, 2023 at 11:31 AM
    Tripleconpanna
    @Green Thunder
    I think if the top plates are ordered w/them they are not welding on at the factory; they get bolted on by the consumer as part of the install process :notsure:...
    Anyhow, I was in the middle of trying to get everything buttoned up yesterday; noticed the holes and after I was done w/the install I forgot to even check to see how/if they drain out, so I'll definitely be doing that today...
  6. Jul 25, 2023 at 11:32 AM
    Tripleconpanna
    I'm hoping it's totally open... and the powder coating and finish are nicely done throughout the inside of that area; if not :mad:
  7. Jul 25, 2023 at 11:35 AM
    Tripleconpanna
    This is what you hope for, but in reality what happens is they conspire...
    next thing you know you're paying full MSRP, plus market adjustment, plus dealer add-ons... wait, this sounds familiar :spy:
  8. Jul 25, 2023 at 11:37 AM
    Tripleconpanna
    Not anymore... that copyright has since expired, and it's now a 'global' process ;)
  9. Jul 25, 2023 at 12:19 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    We give ours to the town sports booster club. Helps out a good cause and I don't have to do anything but drop them off. We do rinse ours out though because we're those people.
    :thumbsup:
  10. Jul 25, 2023 at 12:21 PM
    SwitchThrottle
    So the same people that make Toyota 4wd actuators make toilet valves?
    o_O
  11. Jul 25, 2023 at 1:04 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
  12. Jul 25, 2023 at 1:12 PM
    NWPirate
    Zach
    WA
    Almost 40 years old with no rust, in WI? The stars have aligned
  13. Jul 25, 2023 at 1:17 PM
    Blue Thunder
    Washington
    Yeah, both are finding a few hundred but that’s it. Think I’ve reached the rock bottom price. Grrr
  14. Jul 25, 2023 at 1:30 PM
    Tripleconpanna
    @Green Thunder @NWPirate
    NWP was correct... completely open on the bottom; it's not a 'full bar' of steel just a connecting top plate welded on and pre-drilled to ease the top plate install for those that opted for them.
    Not the best option in terms of aesthetics, but much better than that opening being boxed in :thumbsup:
  15. Jul 25, 2023 at 1:31 PM
    Tripleconpanna
    Or the rust has been painted over :spy:
  16. Jul 25, 2023 at 1:31 PM
    Tripleconpanna
    Depends on your urgency...
  17. Jul 25, 2023 at 1:36 PM
    The redneck stupid f**k-wits that put this place in didn't do a shut off to the house. So I have to flip a breaker to half the house.
    I called it quits when the bolts to the toilet started free spinning. If the flange in the floor is shot it's outside my willingness to play because it needs to be done quickly with the water situation.
    With frustration mounting, I decided to tag a plumber. Pisses me off that something as simple as a toilet swap gets effed all to hell because the dipshits who put the house in were half asses about it.
  18. Jul 25, 2023 at 1:50 PM
    NWPirate
    Zach
    WA
    Wow, you can't catch a break man.
    You must be on a well; killing power to the pump?
  19. Jul 25, 2023 at 1:52 PM
    Yup. On a well.
    It's all good though. For all the headache, frustrations, and struggles I just have to remember one thing. Someday, I'll die and won't have to mess with plumbing anymore.
  20. Jul 25, 2023 at 1:53 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    All I'm hearing is my :nuclear: was correct
  21. Jul 25, 2023 at 1:53 PM
    Always a safe bet when plumbing is involved.
  22. Jul 25, 2023 at 2:03 PM
    NWPirate
    Zach
    WA
    There is an upside! :woot:
  23. Jul 25, 2023 at 2:11 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Buy it now! Those things are collectibles. The shorter ones are the most desired ones. (Definitely not TWSS)
  24. Jul 25, 2023 at 2:21 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I saw an ad for this and figured why not. It's pretty good, Tastes like Dew and no alcohol flavor, which could be bad.
  25. Jul 25, 2023 at 2:25 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If you don't need to buy right now, you can always walk away and see if either dealer blinks.
  26. Jul 25, 2023 at 2:49 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    So I put on my roast beef today aand it's pretty damn good
    I think this shit might even make hotdogs half way palatable
    I don't think they're that bad at least the ones they tell you about
    It's a brown mustard with flavoring, there's a Honey Chipotle one I'm going to try next
  27. Jul 25, 2023 at 2:52 PM
    NWPirate
    Zach
    WA
    It's criminal how much shit has canola oil in it
  28. Jul 25, 2023 at 2:56 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Monsanto is going to get theirs one way or another.
  29. Jul 25, 2023 at 2:58 PM
    OK, picking the brains of our electricians. Flipped 4 breakers to kill the water. Flipped them back on and one won't stay. It's not the water breaker at least, but dome outlets snd lights are on it.
    Blue Thunder and T-Rex266 like this.
  30. Jul 25, 2023 at 3:01 PM
    NWPirate
    Zach
    WA
    Try turning it off again with a little more pressure, what brand of panel?
