37" inch tires , CV axles upgrade? '17 tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by BatmobileT, Jul 24, 2023.
  1. Jul 24, 2023 at 10:44 PM
    BatmobileT
    BatmobileT [OP] New Member
    Levi
    Metallic Gray 2017 Tundra 5.7 4×4
    Off roading specific mods: 4" lift Billstein bypass/ reservoir 8112 shocks 37"×18" wheels TRD cold air intake TRD front sway bar Ironman custom front bumper Rough country rear bumper Cali raised rock sliders
    Went from 35" to 37" tires.
    What do I need to upgrade?
    Cv axles..?
    Thanks!
    2mchfun likes this.
  2. Jul 24, 2023 at 10:51 PM
    18" TRD Off Road Wheels
    2mchfun likes this.
  3. Jul 25, 2023 at 8:49 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    You can if you want. Most people dont upgrade CV axles. Tires (even as big as 37s) aren't going to cause issues. Thats more dependent on your lift height
  4. Jul 25, 2023 at 8:59 AM
    2mchfun
    Differential gears is the "almost a must" and a speedometer calibration if you want proper function of everything
  5. Jul 25, 2023 at 9:03 AM
    2mchfun
    Depending on your lift, front cab mount chop for clearance when turning.
