  1. Jul 24, 2023 at 9:54 AM
    AZBoatHauler
    So.Arizona
    No doubt smaller rigs are easier to navigate through tough terrain but I will say wheeling full-size often simplifies the choice of line and can keep you out of trouble with its larger / wider wheelbase and generally lower COG.
    here is a popular spot on a trail we run in Sedona - bad Jeep drivers have been known to roll down this chute - novice Tundra drivers will find it easy because the truck barely fits and is not tippy in comparison at all. If you’re @Cruzer, you drive up instead of down. There is video out there somewhere…
  2. Jul 24, 2023 at 10:23 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    That is freakin sweet. Also the best mod you can do to help wheelin full size rigs is to lose any major attachment you may have to the factory shape of your body panels. Then the fun really starts
  3. Jul 24, 2023 at 11:47 AM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    Looks great! Which product did you use?
  4. Jul 24, 2023 at 11:58 AM
    GCanuck
    Gary
    BC,Canada
    I didn't think a kicker would fit under the seat. I went will the cheaper Blaupunkt. Only 8" but good enough if it's married with the stock system.
    RobertD and drpheta[QUOTED] like this.
  5. Jul 24, 2023 at 11:59 AM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Yeah, I measured the space under before ordering it.
  6. Jul 24, 2023 at 12:41 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  7. Jul 24, 2023 at 3:02 PM
    Mcdqpr
    Mcdqpr New Member
    Is there a way to use current key or aftermarket mod to allow all windows to power down remotely or from outside the truck, similar to newer models? I’m not seeing anything for the ‘20 SR5.
  8. Jul 24, 2023 at 3:26 PM
    Taco-Spike
    Two Trucks
    WFD473 and HulkSmurf14 like this.
  9. Jul 24, 2023 at 3:58 PM
    Stanky10
    Stanky10 New Member
    Stanky
    W Columbia SC
    2019 MGM Tundra TRD Sport
    3/1 leveling kit with 295/60/20 Nitto Ridge Grapplers, Go Rhino Dominator D6 step rails, Husky X-Act floor liners (front and back).
    Looks good, welcome from West Columbia SC
    KILLINTIME[QUOTED] likes this.
  10. Jul 24, 2023 at 4:32 PM
    SAGE63
    San Diego County
    Hey who said driver....
  11. Jul 24, 2023 at 4:37 PM
    centex
    centex New Member
    It’s generally my fault when it doesn’t run.
  12. Jul 24, 2023 at 5:00 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Mine ran fine except when they didn’t. They also never stranded my wife on the side of the road except for the two times they did.
  13. Jul 24, 2023 at 5:26 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    First real voyage for the parentals with the new setup. They’re out in Idaho if anyone sees them on the road. Some interesting things on the trailer needed to be addressed recently. They just don’t make stuff like the used to. We will see how they like it after this trip
  14. Jul 24, 2023 at 5:26 PM
    AZBoatHauler
    So.Arizona
    I had a Suburban that would randomly go into limp mode without warning. No codes, no check engine light, just loss of power and like 5 mph foot to the floor. After a bit of time and cycling the ignition it would eventually “fix” itself. Doing things like driving over Coronado Bridge or climbing a mountain passes was always like playing Russian roulette.
  15. Jul 24, 2023 at 5:26 PM
    bfunke
    bfunke Tundra Curmudgeon
    Gave my newer one an oil change, bath and wax
  16. Jul 24, 2023 at 5:44 PM
  17. Jul 24, 2023 at 6:05 PM
    KILLINTIME
    KILLINTIME Like a Villain
    What up stanky! I have a fair amount of family in Columbia!
  18. Jul 24, 2023 at 7:16 PM
    Stanky10
    Stanky10 New Member
    Stanky
    W Columbia SC
    Nice, what part of SC you in
  19. Jul 24, 2023 at 8:02 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    That's a dissapointment. For the money those things command, I hope it's piddly shtiff and nothing major.
  20. Jul 24, 2023 at 8:10 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea just small annoying things but one very major thing was the valve stems. They came un glued cheap China units all the tires were flat. Luckily this didn’t happen during the drive it could’ve been real bad. Happened while it was parked and stored. So we let them know to recall all the other rigs to replace.
    HulkSmurf14 likes this.
  21. Jul 24, 2023 at 8:24 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  22. Jul 24, 2023 at 9:49 PM
    MattAK
    MattAK Headin' for the hills
    Alaska and Utah
    '19 SR5 DC White
    Valhalla Cat Plates, GCS Cooler, Dobinsons, RAS
    Tried to DIY the front brake pads today. Of course with pretty much all my projects something has to go wrong. I was careless and let one of the pistons fully extend and didn't have anything to push it back down without taking the caliper off, which I did with much effort as they were ON there, I have to think someone gave the bolts some extra ugga duggas with the impact. Well, turns out the threads on the caliper bolts are so badly damaged that I can't get either of them to fully seat any more. To top it off this is my only vehicle so I'll have to uber around to find new bolts and a tap to chase the threads in the caliper hoping that they aren't also damaged. I have a tap and die set but it doesn't go large enough and I'd rather new bolts than try to repair these. I'm the second owner and don't have super complete maintenance records from the first owner.
    I'm also supposed to be leaving to move up to Alaska this weekend. Can't help but think I should have just paid someone to do this with the time crunch but the job is usually easy. Grumble grumble.
  23. Jul 24, 2023 at 9:58 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Installed RCI sliders on my '21 Pro today :D
    RCI did a really nice job on the powder coating; these things are heavy and well built :thumbsup: Install was not too bad...
  24. Jul 24, 2023 at 11:10 PM
    Wahayes
    Will
    2017 tundra limited
    Towed too much with it lol after trailer weight and all our crap , was right around 9000 lbs and some change. With passengers and the furry passengers, I was probably a tad over tow rating. Definitely max towing for my rig.
    BR73, silverhack, Tundra-XP and 9 others like this.
  25. Jul 25, 2023 at 3:41 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Nice! Those look killer without the top fill plates.
  26. Jul 25, 2023 at 4:38 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Wow and I thought I had a big trailer haha
  27. Jul 25, 2023 at 5:06 AM
    Taco-Spike
    Two Trucks
    Agreed.
    the Main product picture isn’t even there product :anonymous:
  28. Jul 25, 2023 at 6:31 AM
    1UP
    1UP Truck Gang
    You might be a tad over tow rating but I'd bet dollars to donuts your severely over your payload number.
    Be careful out there.
    reywcms likes this.
  29. Jul 25, 2023 at 8:57 AM
    drpheta
    drpheta New Member
    Slapped on some 6112s at #3 setting, Beck Arnley inner and outer tie rods, Beck Arnley LBJs, and JBA UCAs. What was a slightly sloppy front end is now nice and solid. Truck's all levelled out and looking fantastic.
    Unfortunately, my rear 5100s are on back order until November. So, do I pay the difference to get 5160s now or do I wait until November and save myself some cash along the way?
  30. Jul 25, 2023 at 9:14 AM
    The way things have been, I wouldn't be surprised if the prices go up by then.
