Double Tow Questions
Discussion in 'Towing & Hauling' started by kenomouth64, Jun 14, 2018.
  1. Jun 14, 2018 at 7:49 AM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    So I am in the market for a trailer and boat combo, that my truck would be able to pull and still meet my states double towing regulations as well as match my truck's capabilities.
    The trailer will have to be a bumper pull and will need to be able to have a 3-5k boat hooked onto the back of it. The total length of the truck, Travel trailer and Boat cannot surpass 65ft.
    I am thinking something along these lines:
    Truck length = 19ft
    Boat Towing length = 22ft
    Trailer length = 22ft
    Truck's GVWR = 7200 lbs
    Truck's weight (loaded) = 6100 lbs
    Boat Towing weight (loaded) = 4100 lbs
    Travel trailer (loaded) = 5000 lbs
    Tongue weight = 0.1 * 9100lbs = 910 - 1100lbs
    7200 (GVWR) - 6100 (Loaded truck) = 1100lbs (remaining Payload capacity)
    1100 (remaining payload capacity) - 910-1100 (tongue weight) = A remaing payload of 0lbs to 190lbs.
    So in theory it is possible, I already checked the legal requirements for my State.
    Does anyone have some recommendations for the trailer and or boat I should get for this?
    I am thinking a fish and ski boat (16-19 ft hull).
    I need the TT to be capable of hooking up to a 4k boat, so it needs a high GVWR as well and the trailering equipment.
    Here is another posting to reference: http://www.tundratalk.net/forums/tundra-towing-hauling/338690-double-towing-9-000lbs-5th-wheel.html
    I feel like he overdid it...
  2. Jun 14, 2018 at 8:34 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    You wanting a brand new boat? Glass I assume. Check out Ranger's Reata and Angler line of boats if you are looking to buy new.
  3. Jun 14, 2018 at 8:43 AM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    That isn't something I'd want to be doing with a 1/2-ton pickup, even if it is a Tundra.
    GODZILLA, ColoradoTJ and Y0TA PR0 like this.
  4. Jun 14, 2018 at 8:44 AM
    kenomouth64
    Tetrus
    I am actually thinking used for both.
    I have set an 18k limit on both. I don't like buying new stuff, the depreciation makes me angry/resentful
  5. Jun 14, 2018 at 9:08 AM
    15whtrd
    15whtrd Mr. Blonde
    I wonder what changes with the tongue weight onto the tundra once you add tongue weight to the back of the trailer for the boat? I would assume you hook the trailer up to the boat first then take the tongue weight off the tongue of the tundra, hook up weight distribution and sway then drop the trailer back down on the back of the tundra?
    kenomouth64[OP] likes this.
  6. Jun 14, 2018 at 9:12 AM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Are you planning for brakes on both trailers? Most states require trailer brakes when weight greater than 3,500 lbs
    Greg
  7. Jun 14, 2018 at 9:28 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I'm generally not comfortable exceeding 80% of my truck's towing capabilities.
    If you do it, definitely use extended tow mirrors, and I recommend a Furion FOS48TPK-BL, always on, works great on the back of our TT. I'd practice pulling the trailer only for a bit. Turning radius would kill me, I'll be honest I wouldn't do the combo myself.
  8. Jun 14, 2018 at 9:43 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Not sure about the 2007, but I know my '13 CM max towing capacity is only 9,000 lbs.
  9. Jun 14, 2018 at 10:13 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I would look for a TT in the 4000 lb range and boat that is close to 3000. You can easily find a 16' boat that totals 3000 and maybe even an 18. Motor choice on the boat will have a big impact. The regular 2 stokes are lightest followed by a Optimax type then 4 cycles & lastly I/Os. My Optimax weighs 100s more than my Black Max did. Best choice in a TT/boat situation is to get a small 5th wheel TT. You will need a TT with a fairly stout bumper. Don't forget that most TT have a 2-5/16' ball and your boat will have a 2". So have both sizes on hand.
  10. Jun 14, 2018 at 10:19 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Personally I wouldn't attempt this. Even with a bigger pickup. One thing is what if you get in a pinch and need to backup? Then what?
  11. Jun 14, 2018 at 10:27 AM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    I would get an in the bed camper and supertruss hitch for the boat.
  12. Jun 14, 2018 at 10:37 AM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    You dead set on bumper pull trailer?
  13. Jun 14, 2018 at 10:47 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    If this is going to be something you do a few times a year go for the 5th wheel if possible. Just like the OP in the thread you linked, once you experience the difference it's almost impossible to go back. With a 5th wheel the TT seems so much more connected to the truck. This is so important if you're going to add another boat trailer to the back.
    Me personally I wouldn't attempt this with anything less than a dually
  14. Jun 14, 2018 at 10:48 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    f001bc09abde7635cbcfe139ad78ff07.jpg This ^ only one trailer needed lol.
  15. Jun 14, 2018 at 10:50 AM
    kenomouth64
    Tetrus
    I hope it has enough motor to pull a skier!
    duece292[QUOTED] and D1227 like this.
  16. Jun 14, 2018 at 11:00 AM
    kenomouth64
    Tetrus
    Yes, I plan on having trailer brakes for both.
    I definitely will be using extended tow mirrors and likely a few cameras as well.
    It was downgraded from 2010 to 2011.
    http://news.pickuptrucks.com/2010/08/toyota-lowers-trailering-ratings-gains-credibility.html
    https://www.youtube.com/watch?v=k0VHFK7Njps
    Well, I was, but it seems that stability and sway might be a factor that leads me toward a 5th wheel. I was not aware that you could use a 5th wheel with the crewmax...until I saw the other poster.
    D1227[QUOTED] likes this.
  17. Aug 16, 2018 at 7:58 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    @ColoradoTJ figured this was right up your ally. :boink:
    I actually can't believe this is legal in any state without a CDL.
    Just because it is POSSIBLE and LEGAL does not mean it's WISE.
    With the Tundra? Never, I wouldn't even consider it.
    Tundra+ 5th wheel =:deadhorse:
  18. Aug 16, 2018 at 8:42 AM
    Not even going to comment on it.
    Looks like the OP wants a new truck.
    OBXTundra[QUOTED] likes this.
  19. Aug 27, 2018 at 10:50 AM
    TTCrewmax
    TTCrewmax New Member
    I do this same thing with a bumper pull and another trailer with my SXS on it and it's stable and legal. I don't go over 65 MPH when towing and get 7-9 mpg's.
    I don't have a recommendation on a boat or trailer. But wanted to chime in and let you know it's possible. I'm at exactly 65 Ft with truck/trailer/sxs. I have air-bags, load e tires and find it really long and stable.
    At first I was dead set against it and wanted a toy hauler instead. But wife hated all the toy haulers we looked at so...
    Watt maker likes this.
  20. May 8, 2023 at 3:53 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Arizona Revised Statutes 28-1095.G.3 -
    A recreational vehicle may pull two units if all of the following conditions are met:
    (a) The middle unit is equipped with a fifth wheel and brakes. The middle unit may be a farm vehicle or a horse trailer and shall have a weight equal to or greater than the rear unit.
    (b) If the rear unit has a gross weight of three thousand pounds or more, it is equipped with brakes.
    (c) The total combined gross weight of the towed units does not exceed the manufacturer's stated gross vehicle weight of the towing unit.
    Check the laws for your state and any state that you plan to travel through for legality.
  21. May 8, 2023 at 5:38 PM
    snoope
    snoope The Old Man
    WOW,
    Ok, my question list
    1) Experience pulling ANY trailers, never mind 2 ??
    2) BRAKES; how are you going to control ABS braking of truck with missed matched trailer braking systems ??
    3) When the "WHIP" starts , do you even have a CLUE why it started and HOW you can regain control without damage & harm to everything around
    4) WHY ??
    Enough said :cool:
    Cpl_Punishment likes this.
  22. May 9, 2023 at 2:45 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    This thread is nearly 5 years old... :D
  23. May 19, 2023 at 4:41 AM
    Retired...finally
    Is it just me or are the tongue weights figured using fuzzy math? I'd think the boat would put 410 # on the rear of the trailer and the trailer put 500 # on the Tundra.
    Good luck finding a travel trailer capable of having that kind of weight placed on the rear bumper and having a fresh water tank in the front big enough to offset the boats tongue weight. Maybe take the outboard off and stow it in the trailers pass through compartment. :confused:
  24. Jul 23, 2023 at 6:57 PM
    Pac12AfterDark
    Pac12AfterDark New Member
    Fwc and an aluminum 18 footer.
    Or
    BP toy hauler loaded with a drift boat :)
