  1. Jul 23, 2023 at 10:29 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Happened to us too. Ppl dumped animals near our house since we lived just outside the town limits. Cats were nearly always pregnant. The kittens sometimes crawled up into the fan shroud of the Oldsmobile.
    I'll never forget what one incident looked like...the kitten wasn't dead either. Sticks in my mind to this day.
    bulldog93 likes this.
  2. Jul 23, 2023 at 11:03 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  3. Jul 23, 2023 at 11:32 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    We have feral cats at work I always honk my horn before I start my engine, so far it has seemed to work. Our office manager has got three or four over the past year I don't know why she refuses to just honk before she starts.
  4. Jul 23, 2023 at 12:00 PM
    bfunke
    bfunke Tundra Curmudgeon
    Yup. Cats like warm places. Recommend you tap the horn before starting.
  5. Jul 23, 2023 at 2:27 PM
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    Added 285/65 18 wildpeak rt after level kit.
    BC50EB00-0D52-4B56-9184-F66051F07348.jpg45A3E94C-12E8-4E26-9232-27E65F38C851.jpg 33A2F3D3-02A7-419D-A8E2-125349254975.jpg
  6. Jul 23, 2023 at 3:31 PM
    dsotm
    dsotm New Member
    2016 SR5 Crewmax 4x4
    Added Startx remote start and car link cell module. 30 minute install but still brutal in this AZ heat. At least the truck will be cooler after work going forward.
  7. Jul 23, 2023 at 3:46 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd like to know how it ends up working out for you. I'm looking for something with longer range and won't shut off when I open the door. What's the app that it uses?
  8. Jul 23, 2023 at 3:52 PM
    dsotm
    dsotm New Member
    it’s just called carlink on Apple or Google, takes about 15 seconds to start up, maybe 5 seconds or so to lock the doors. Used it inside the grocery store while checking out to get the AC going before heading outside.
  9. Jul 23, 2023 at 3:56 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Thanks. Has good reviews on Amazon.
  10. Jul 23, 2023 at 4:43 PM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Gross. Previous owner probably forgot this existed and needed to be changed. That's the cabin filter, and that square mass of leaves is what came out of it when I dropped it on the ground.
    Now I need to figure out if I can spray cleaner on the evaporator directly with the blower fan removed.
  11. Jul 23, 2023 at 4:48 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
  12. Jul 23, 2023 at 5:32 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    my used 2017 (with physical key) came with a remote start by “code alarm”. It works pretty well, truck starts and keeps running no matter what until you tap the brake.
    you hit the fob- It’s running, you get in, turn the key to on and it just stays running. You can press the remote three times while it’s running and pull the key out and it will keep running as well. image.jpg
  13. Jul 23, 2023 at 5:39 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Appreciate the info. Mine was installed at the port. It's been fine all these years but I primarily want more distance to start it.
    Cl8NL[QUOTED] likes this.
  14. Jul 23, 2023 at 5:43 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    yeah, on second thought I can’t find much about codealarm on google. Seems like a janky fly-by-night company or a Chinese Amazon special. I actually was mulling over removing it but the internet points to me having to pay >$100 to have that done, ugh. I tried it once mashing the button in different combos because it came with no instruction -truck wouldn’t turn over. Even with the key for a short time after. Engine was trying and making noise. No other instances at all. truck is dead reliable so know it had something to do with the remote start system. That’s only happened once so I’ll keep it for now.
  15. Jul 23, 2023 at 6:18 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Took the fam up Mt. Herman here in COS. Hitting the dirt again has the mod bug sinking its teeth in DEEP UNADJUSTEDNONRAW_thumb_e6.jpg
  16. Jul 23, 2023 at 7:35 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    What's next on the list?
  17. Jul 24, 2023 at 3:23 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    C4 Fabrication Hybrid front bumper so I can have a winch. Then sliders, belly pan, two lockers with 5.29's, 37s, etc. I always though this truck was too large to build into a wheelin rig, but it proves me wrong every time we take it out
    PomDad and AZBoatHauler like this.
  18. Jul 24, 2023 at 6:05 AM
    MadMaxCanon
    Ask @Cruzer about wheelin' full size lol.
    Nice list. A front bumper helps alot, even without a giant lift, it feels like the truck is lifted significantly more with the clearance and the angle improvement.
  19. Jul 24, 2023 at 6:53 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Plenty of ppl wheel in full size rigs
    https://youtu.be/RT4_yQ7wc-I
  20. Jul 24, 2023 at 6:55 AM
    KILLINTIME
    KILLINTIME Like a Villain
    Long time TW member. First post here:
    Over the weekend I installed 5100s on middle setting. .5” CB shim on each side. 285/75r18 Toyo r/t trail. Removed mud flaps. Plenty of clearance on the front. So far lost less than 1mpg. Can’t really tell a diff in power. Dropped off At the shop for an alignment today. So far so good.
  21. Jul 24, 2023 at 6:56 AM
    KILLINTIME
  22. Jul 24, 2023 at 6:57 AM
    KILLINTIME
  23. Jul 24, 2023 at 6:58 AM
    Welcome from NY.
  24. Jul 24, 2023 at 7:46 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Yeah I’ve been gobbling up full size content like it’s going out of style. Once the credit card cools off from buying a new house it’ll be all aboard the trail whale train
  25. Jul 24, 2023 at 7:47 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I’m originally from the same area as him and wheeled many of the same trails on his build thread in my old FJ and Tacoma. I thought it was rowdy in those rigs :anonymous:
    MadMaxCanon[QUOTED] likes this.
  26. Jul 24, 2023 at 7:57 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    BR73 and KILLINTIME[QUOTED] like this.
  27. Jul 24, 2023 at 8:04 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I think it's entirely more challenging to do it in a full sized rig.
    BreyTundy[QUOTED] likes this.
  28. Jul 24, 2023 at 8:08 AM
    centex
    centex New Member
    Yup. I wheel my 85 k5 quite often when it runs.
  29. Jul 24, 2023 at 8:26 AM
    AZBoatHauler
    So.Arizona
    #GMlife
    centex[QUOTED] and RainMan_PNW like this.
  30. Jul 24, 2023 at 9:33 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Without a doubt. But now I’m a big kid with a family and dogs, so I’m more than happy to have a little extra size on the trails if the whole gang can pile in.
