Gen 3 VS 3/4 Ton for towing TT
Discussion in '3rd Gen Tundras (2022+)' started by Jamesausman, Jul 16, 2023.
  1. Jul 22, 2023 at 1:28 PM
    #121
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Absolutely. Staying in a hotel is just not the same as camping, even camping in a trailer.
  2. Jul 22, 2023 at 1:53 PM
    #122
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Agreed on all points. That said, those trucks are also 1200 to 1700 lbs heavier so when you crunch the numbers and compare power to weight ratio of a 6k lb tundra and a 7.5k lb f250 with the 7.3 pulling the same 7,000 lb trailer and the power to weight ratio of the combined weight is pretty much the same with both trucks. Power to weight ratio is what all feeling of brisk acceleration comes down to at the end of the day.
    RostamD[QUOTED] likes this.
  3. Jul 22, 2023 at 1:56 PM
    #123
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Why toyota can’t just build us a hybrid max HD with bigger axles, brakes and beefier suspension + more cooling to get 2,500lbs payload in a loaded trim. They would sell like crazy for an additional $5k- only make it on limited and up.
  4. Jul 22, 2023 at 2:43 PM
    #124
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
  5. Jul 22, 2023 at 3:15 PM
    #125
    mass-hole
    mass-hole New Member
    Toyota of all people should be the ones offering an HD half ton. Ford, GM and Ram all have an excuse not to, they sell 3/4 and 1 tons. Even then, Ford still does with the heavy payload package which can be 2400-2500 lbs of payload in high XLT or low Lariat trim.
    The problem is, if they get too heavy with the truck like Nissan did with the XD, it gets you just barely over half ton capability with 3/4 ton efficiency and cost. The XD makes my 2014 steel body 157" F150(6200 lbs bone stock) look light and is approaching 3/4ton gas engine weight. The 5.0 diesel only has 330hp and yet offers the same efficiency and cost as a 450 hp powerstroke or duramax.
    Cpl_Punishment likes this.
  6. Jul 22, 2023 at 8:05 PM
    #126
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Those Nissans had that bad Cummins in them didn’t they? I do think it would be interesting if GM Duramaxed a 4.8 or 5.0 similar to their 3.0 (which is light years better than either the light duty diesels Ram and Ford tried) and made a 5/8ths type truck………
  7. Jul 22, 2023 at 8:13 PM
    #127
    Breathing Borla
    Northern Illinois
    Yes, the Nissan tried but the motor was like 600 lbs dry or something like that alone and it was better just to get a 3/4 ton and get a powerful diesel and better capacity than the heavy half titan xd
    ColoradoTJ and Cpl_Punishment like this.
  8. Jul 22, 2023 at 8:43 PM
    #128
    Don't forget better:braking, frame, and long term axle strength. All what makes a better tow rig.
    I towed with a couple 6.0L GM motors (not at all impressed). They get the job done, but that's something you get a landscaping or snow removal crew. Anyone serious about towing weight doesn't go the "gas" route until recently with the 6.6L GM or 6.8/7.3L gas motors. I have towed with the 7.3L and was impressed. I haven't towed with the 6.6L gas motor yet, but some of the forum members that have went larger from their tundra's say it's night and day differences.
  9. Jul 22, 2023 at 8:53 PM
    #129
    305 Hp/555 tq for a heavy ass truck that cost as much as a domestic 3/4 ton diesel. It just didn't perform and the overall price just killed it. I remember the Titan 5.6L beat the diesel version in the Ike Gauntlet testing. That's embarrassing to say the least.
  10. Jul 23, 2023 at 6:34 AM
    #130
    Silver17
    Eastern PA
    Agreed on the frame, brakes axles etc. The 6.6 L8T and 7.3 are definitely greatly improved offerings over the past HD gas engines. For their size and being a modern design I would expect more though. Hp and torque per liter are both worse than the 5.7 Toyota engine designed in 2006! 13% worse for the 7.3 and 10% worse for the 6.6. I was expecting the L8T to be a powerhouse with a little boost. I saw dyno results with the new 3.0 gen 5 Whipple at 8psi and the damn thing only made 521hp and 505 tq at the wheels. A 5.7 with a 1.9 liter blower makes that at the wheels on the same boost, not to mention the 2.6 and 2.9 liter blower offerings. No doubt you could crank the boost and make more reliable power, but I was disappointed as that is what I’d want to go with for the next rig. Power per liter (naturally aspirated) the 5.7 is still a beast after all these years. What it could really use is a 10 speed and to be bored out to a 6.8 like the XAT racing offering and it would be a towing machine in an HD truck if Toyota would actually make one.
  11. Jul 23, 2023 at 7:02 AM
    #131
    I was hoping for a bit more as well. Seems like everything else is getting a SC or Turbo. It's either get a gas motor and be fine with it (and totally void all warranties) or buy diesel (which is a horrible choice for DD duties). The 6.6L doesn't have many options for aftermarket (the last I checked) and the 7.3L the sky is the limit.
    Is a 450-475 HP turbo V-8 with a 8-10 speed transmission that hard to produce?
    Eurodriver and Silver17[QUOTED] like this.
  12. Jul 23, 2023 at 7:41 AM
    #132
    Silver17
    Eastern PA
    Agreed and I’d say not, they just won’t. NA these big V8s are making close to that. They’re pretty much making that power with turbo 6s. A 550+hp turbo/SC v8 out of the box is what I’d like to see in an HD, but I think it’s more of a niche market since most people don’t look at things the way a few of us do. It would give diesel towing performance but would require 93 octane and would slug down the gas. That’s totally fine with me of course to pay more for gas for awesome power without being subject to the diesel emissions equipment problems and maintenance, but most people don’t look at it that way. They either want a relatively easy and cheap to operate NA gas V8 making mediocre power, or decide to go all in on the expensive to purchase/operate/maintain turbo diesel.
    Maybe they don’t want a high performance gas offering to cut into their diesel sales? It also may be asking too much for them to invest in the design, tooling and production requirements of a 3rd likely less popular engine option. For now, as long as the gas engine options are built to live half decent on boost I would continue to choose that route via aftermarket SC kits and voided warranties (in some not all cases).
  13. Jul 23, 2023 at 7:49 AM
    #133
    Dodges new Hurricane I-6 TT is the way. Buttery smooth straight six with gobs of smooooth torque. And lots and lots of main bearings.
    ColoradoTJ likes this.
  14. Jul 23, 2023 at 8:07 AM
    #134
    centex
    centex New Member
    I’d look at the ford 7.3 gas engine. 450hp//475tq with a ten speed auto. Everything I’ve read says so far it’s a great engine. Otherwise, I’d grab a Cummins ram and never think twice.
    digitalwiz likes this.
  15. Jul 23, 2023 at 8:25 AM
    #135
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Agreed. I have nearly convinced myself that I "need" more truck several times. I keep staying put because nothing checks as many boxes for me as my '21.
    If I were in Muley's situation, I would probably look into gears. Or do nothing at all. These trucks have tons of life left at 133k miles.
    I think I’d do the 7.3L if I went HD. My grandpa would do cartwheels for joy, and it would be half worth it just to see that.
  16. Jul 23, 2023 at 9:25 AM
    #136
    mass-hole
    Im sure that is because of the camshaft and heads on the L8T. None of the gm motors make a whole lot of power with just a blower installed. Throw a blower cam in it with the correct intake/exhaust timing and I bet it would pick up a lot of power. When I had my LS2 GTO it was pretty popular to install a blower and swap to an LS9 cam from the zr1 vette
    The 5.7 is DOHC with variable valve timing so it probably can make some decent gains without any other mods because the valve timing can be adjusted via the pcm
    Silver17[QUOTED] likes this.
  17. Jul 23, 2023 at 9:54 AM
    #137
    I will be very interested in how these work out for Ram. Back in the day the inline 300's did very well in a 1/2 ton. I'm willing to bet it will be pretty awesome.
  18. Jul 23, 2023 at 10:20 AM
    #138
    mass-hole
    My only worry with the hurricane is the specific power output. Its like 420 hp and 470 tq out of a 3.0L in the standard trim and like 500+ hp in the HO. I just dont see it being capable of sustaining those outputs doing truck stuff.
  19. Jul 23, 2023 at 10:51 AM
    #139
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    And absolutely pointless. . .
  20. Jul 23, 2023 at 2:31 PM
    #140
    I don't know. Lot's of high Hp I-6 power plants in vehicles these days. Time will tell.
  21. Jul 23, 2023 at 6:07 PM
    #141
    mass-hole
    Not in trucks though.
  22. Jul 23, 2023 at 6:12 PM
    #142
    The 5.9 Cummins was an I-6. Just saying
    Breathing Borla likes this.
  23. Jul 23, 2023 at 6:16 PM
    #143
    Very true.
  24. Jul 23, 2023 at 6:20 PM
    #144
    Ford 300ci I-6 is another one that was great.
  25. Jul 23, 2023 at 6:22 PM
    #145
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    Yet GM is equipping lots of trucks with a 4-banger…
  26. Jul 23, 2023 at 6:23 PM
    #146
    mass-hole
    I guess you seriously missed the point. The quote was high hp. The 5.9 made 325 hp out of a 5.9L. Not 420 hp out of a 3.0. Literally less than half the specific output of a hurricane.
    A cummins is also like a $10000 upgrade over the gas engine in a ram.
  27. Jul 23, 2023 at 6:30 PM
    #147
    not sure why the output is concerning. No one is concerned with a 380hp V8 in the Tundra. 5.7 V8 engines used to make 200hp. They seem to hold up fine.
  28. Jul 23, 2023 at 6:59 PM
    #148
    centex
    centex New Member
    That’s like saying a turboed 2jz is the same as a turboed ford 300 i6. Not even close to the same league.
  29. Jul 23, 2023 at 7:00 PM
    #149
    centex
    centex New Member
    What’s the mileage like?
  30. Jul 23, 2023 at 8:10 PM
    #150
    I wouldn't laugh. It did a perfect time up the Ike Gauntlet.
