2023 Strut Top Hat
Discussion in '3rd Gen Tundras (2022+)' started by blee15, Jul 22, 2023.
  1. Jul 22, 2023 at 11:40 AM
    blee15
    blee15 [OP] New Member
    Can anyone confirm if a 2021 strut top hat will fit on a 2023? Looks to be the same size to me. Got a set of dobinson IMS coilovers and want to get them assembled before installing them so I dont have to swap mine over from my OEM struts. Thanks in advance!
  2. Jul 22, 2023 at 12:11 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    might check in the Forum/Tundra Garage/Suspension thread - likely find an answer there. Also if the part number for the '21 is the same as the part number for the Gen 3 then it is likely that they are the same. GL.
  3. Jul 22, 2023 at 12:24 PM
    blee15
    just checked sparks and 2021 - 2023 are the same part number on the top hat. Thank you for the suggestion!!!
    303Gen3[QUOTED] likes this.
  4. Jul 23, 2023 at 6:46 AM
    303Gen3
    Golden Colorado
    no problem. Glad I could help. LMK how the install goes and if the upgrade makes a significantly improvement.
