  1. Jul 21, 2023 at 3:42 AM
    We still idolize him here.
    BubbaW and DJenerated[QUOTED] like this.
  2. Jul 21, 2023 at 4:42 AM
    FirstGenVol and Jack McCarthy like this.
  3. Jul 21, 2023 at 5:12 AM
    x2 on the Moogs. I did mine a while back; easy peasy; just don't twist the steering rack in the process of tightening the new tie rod onto it with a pipe wrench.
  4. Jul 21, 2023 at 5:44 AM
    I think tie rods are one of those there's universal agreement on being OK. https://www.tundras.com/threads/corner-of-shame-oem-minus-or-plus.122591/
    bmf4069[QUOTED] likes this.
  5. Jul 21, 2023 at 6:13 AM
    You have to get an alignment after doing the inner tie rods or no?
  6. Jul 21, 2023 at 6:24 AM
    I never did; maybe I should have but I don't recall it having a drastic effect on my tire wear.
    I do advise getting an ultra thin crescent wrench to hold the steering rack in place while you loosen or tighten the new tie rod onto it. There's a small flat spot on the steering rack adjacent to where the inner tie rod attaches and you can hold it from there. Maybe about 1/4" thin or slightly larger. Trick is finding one where the jaws open that wide.
    Sunnier, Mr.bee and shifty` like this.
  7. Jul 21, 2023 at 7:00 AM
    Sunnier
    Sunny
    San Diego, CA
    I don't feel comfortable that they'd all do this correctly. There are 2 I had zero doubts about. But after seeing the quotes from one, I have trust issues.
    So that leaves one, or I can meet and greet 'til I find another shop with truck photos everywhere and customer ratings supporting good service.
  8. Jul 21, 2023 at 7:09 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Or... get some gear marking compound & hop into the deep end. I dont know how the solid bushings work, but crush bushings on a diff that comes out like ours would be easy breezy getting proper engagement on a workbench.
  9. Jul 21, 2023 at 8:11 AM
    Sunnier
    Sunny
    San Diego, CA
    This morning I worked through pics of a gear install that Brent shared. It was pretty far outside of my "stretch" zone.
    I'm considering Rusty's suggestion that I pull out everything and deliver it to a shop off the truck. But I don't have a flat place to jack, stand, and store the truck, so probably not.
  10. Jul 21, 2023 at 8:41 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Luckily i've got these handy dandy inspection 'windows' it's just a little play in the rack.
    Holding the driver tire in my legs i can feel the play. Felt tight with the wheels off, but at the tire circumference it's 1/4-3/8" play. Doesnt rattle, it'll be fine. Planned to replace steering bushings & tre's, and maybe the rag joint when i do the suspension.
    now to close the windows...
    artsr2002 and FirstGenVol like this.
  11. Jul 21, 2023 at 9:00 AM
    Meh, just throw some black duct tape around it, it'll be fine.
    bmf4069 likes this.
  12. Jul 21, 2023 at 9:18 AM
    I think a lot of the play comes from the rag joint or the rubber coupler plate. I get tons of bump steer while off road
  13. Jul 21, 2023 at 9:18 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Should i get silicon bellows?
    & cool to know the steering stays unlocked if the key is left in the ignition.
  14. Jul 21, 2023 at 9:20 AM
    Is bump steer where you can feel it in the steering wheel? I get that off-road.
  15. Jul 21, 2023 at 9:23 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Bump steer is actually a product of the tie rods and control arms not being parrallel, like the amount the tire steers through the suspension stroke. Those thing you feel in the steering wheel are just bumps. The play of the linkage while the steering wheel is locked is wear.
    Sunnier and FirstGenVol like this.
  16. Jul 21, 2023 at 9:28 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Good as new.
    bmf4069, txagg, Sunnier and 3 others like this.
  17. Jul 21, 2023 at 9:32 AM
    What the hell kinda texture paint is that thur?
  18. Jul 21, 2023 at 9:36 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    krylon truck bed coating. I'm out of flat black.
  19. Jul 21, 2023 at 9:41 AM
    I have a $25 gift card from Mobil1, pre-paid Visa card, can buy anything I want. What are some things I should spend it on?
  20. Jul 21, 2023 at 9:44 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  21. Jul 21, 2023 at 9:50 AM
    Mr.bee[QUOTED] likes this.
  22. Jul 21, 2023 at 9:54 AM
    Beer then
  23. Jul 21, 2023 at 9:54 AM
    It's a virtual card though, so not something I can carry into a store.
    I think I might get these. I need some magnetic portable lights. Garage is dark af.
    https://www.amazon.com/dp/B088D8DMXQ/
    EDIT: Meh, maybe not. "works well ... for a hour or so (at high) wouldn't use it for long term"
  24. Jul 21, 2023 at 9:56 AM
  25. Jul 21, 2023 at 10:00 AM
    I like the way you think! (But I don't know any places around here who do that)
    I'm also on Doxycycline right now.
  26. Jul 21, 2023 at 10:28 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Good pics and info over at gearinstalls.com
    You could always buy a spare 3rd & front diff and have those built.
    Put that $25 towards an Icon light at harbor freight. Natural white LED and it lasts like 10-12 hours on it's 'low' setting, which is plenty bright.
  27. Jul 21, 2023 at 10:48 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  28. Jul 21, 2023 at 10:51 AM
    Lowball this guy.
  29. Jul 21, 2023 at 10:55 AM
    Awesome, same light available on the 'ol fleaBay with free shipping for ~$20 less. I got it for $38.10.
    But I didn't end up using the damn card. They make you sign up for some shit with lots of legal jargon, so I passed it. I'm happy to cough up my code from Mobil1 if you or anyone else cares about their privacy from marketing folks slightly less than I do. Will cough up the link, along with a screencap of the email so you know I'm not full of shit.
    Sunnier likes this.
  30. Jul 21, 2023 at 10:57 AM
    Oh, and if anyone else is looking, I got the top one, but there's still a couple more in the low 40s w/free shipping...
    Nicklovin and Sunnier like this.
