Center support driveline bearing
Discussion in 'General Tundra Discussion' started by brooksbluff8, Jul 20, 2023.
  1. Jul 20, 2023 at 8:58 AM
    brooksbluff8
    brooksbluff8 [OP] New Member
    Keith
    2008 tundra
    None
    I replaced the center support "carrier" bearing and all 3 u-joints yet I still get the loud noise at around 50 miles per hour. Anyone know if I need a better quality bearing or do I need to have the driveline re balanced? Please help. Keith
  2. Jul 20, 2023 at 9:06 AM
    bfunke
    bfunke Tundra Curmudgeon
    Did you use Speicher or OEM carrier bearing? That all I would use. Could it be a wheel bearing. Finally could be pinion or differential carrier bearings. Rather than throw parts at it find a good garage or 4WD shop that can assess
