Outside air temp display is blank
Discussion in '2nd Gen Tundras (2007-2013)' started by BullsTundra, Mar 23, 2021.
  1. Mar 23, 2021 at 5:30 PM
    BullsTundra
    BullsTundra [OP] New Member
    New member here. Looking forward to learning from this forum.
    My outside air temperature display is now blank upon restoring from an aftermarket radio install. 07 Tundra Limited, crew cab. No I didn’t disconnect the battery:(. The AC light flashes until I push to acknowledge it. Otherwise, AC and heat still work. I checked all fuses, all wiring. There is no voltage at the temperature element. Did I fry the AC Amplifier? If I knew the circuit I could do a little more troubleshooting. The AC amplifier is a 88650-0C070. Thanks in advance!
  2. Mar 23, 2021 at 6:29 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    My ac light was flashing in my 4Runner the other day- it was a bad ac relay. Not sure how that would correlate to the temperature reading, probably doesn’t. You might have two problems or maybe the temp blanks when there is an ac problem as well as the ac light flashing.
    Edit... temp sensor wouldn’t really show voltage. Disconnect and check resistance to see if it’s good.
    BullsTundra[OP] likes this.
  3. Mar 24, 2021 at 6:20 AM
    BullsTundra
    I will check the resistance on the temp element. I found a drawing online that showed there was a few volts to the element. I check both leads to ground and nothing that’s why I think there is a signal issue. I’m not sure if the outside temperature is part of the logic for the AC Amplifier. Anyone?
  4. Mar 24, 2021 at 7:01 AM
    PurpleTech
    PurpleTech Toyota Master Technician
    2019 1794 Edition 4X4 2001 SR5 AC 2WD
    Leveling kit SCS SR8 18" wheels Chrome 95% removed
    I would try disconnecting the battery for 30 minutes before doing any additional diagnosing. Wiring diagram may or may not help you.
  5. Mar 24, 2021 at 8:15 AM
    BullsTundra
    I tried the battery disconnect for 10 minutes. I will go longer. Thanks for the drawing.
  6. Mar 24, 2021 at 8:27 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Hit the wiring diagram link in my signature and you can pull down the full EWDs for your model year, which will be useful for other things.
  7. Mar 24, 2021 at 6:06 PM
    BullsTundra
    The drawings were exactly what I needed. Thank-you! My troubleshooting narrowed the issue down to what appears to be an open between AJ3 connector and the temperature sensor. I did a hand over hand of the wiring and didn’t find any corroded or faulty wiring. I tested the element and its resistance is ~1.5K Ohms and varies with heat (measured disconnected of course). Not sure where to go next other than running a fresh wire from AJ3 to the element?
    1lowlife likes this.
  8. Mar 25, 2021 at 4:49 AM
    BullsTundra
    Battery was disconnected overnight. Display still out.
  9. Mar 25, 2021 at 7:50 AM
    Dalandshark
    Northwest
    Did you try a jumper wire between the connectors you identified?
  10. Mar 25, 2021 at 7:59 AM
    BullsTundra
    Not yet. That is my next step. I will update after I test this.
    Leo's first likes this.
  11. Mar 25, 2021 at 7:00 PM
    BullsTundra
    Jumper wire worked! Now I can run a wire and be done with this and relax about it. I wish I knew where the open is to inspect and repair. Maybe it will roar it’s ugly head with additional faults but oh well. Thanks all for the help.
    PurpleTech and 1lowlife like this.
  12. Mar 25, 2021 at 7:10 PM
    BullsTundra
  13. Mar 25, 2021 at 8:25 PM
    Dalandshark
    Northwest
    Great! Good job and thanks for the update.
  14. Mar 25, 2021 at 9:47 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ This is what this forum is about.
    Helping each other out.....
    Glad you got it fixed..
    Welcome to the forum from Dallas....
  15. Jul 19, 2023 at 9:55 AM
    Teline
    Teline New Member
    2011 Tundra
    Where did you find sensor AJ3 and A15?
  16. Jul 19, 2023 at 7:48 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    AJ3 is a junction connector for the wiring. Generally for when wiring comes in from the engine bay to the cab, it passes through a connector.
    A15 is the connector plug for the temp sensor. It is on the front grill area drivers side I think.
    The sensor reads the exterior temp from the grill area, the data is passed along to the wiring into the cab of the truck to the AC ecu behind the glove box. The AC ecu processes the temp signal and sends it out to be displayed.
    The original posted is saying the wire from one side of the sensor of the grill to the firewall of the truck had a bad connection. The wiring on the inside from the firewall to the AC ecu was good, he had a break in the section in the engine bay.
  17. Jul 20, 2023 at 6:24 AM
    Teline
    Teline New Member
    2011 Tundra
    So, I just need to trace the wire from A15 to the firewall and then place a jumper back to A15?
  18. Jul 20, 2023 at 6:45 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    That is what he had to do to fix his, If I was you I would be looking over the whole circuit to see where your problem is. Techstream can read trouble codes out of the AC Ecu, could be very helpful in this situation.
