Courtesy lighting under mirrors on platinum
Discussion in '2.5 Gen Tundras (2014-2021)' started by Boatmoney, Jul 5, 2023.
  1. Jul 5, 2023 at 4:10 PM
    Boatmoney
    Boatmoney [OP] New Member
    Mark
    2019 black platnum tundra
    I have a 2019 tundra platinum with courtesy lights under the side view mirrors. Is they anyway to adjust the time they stay on they only stay on about 15 seconds and it drives me crazy. I want them to stay on for at least 1 min or 2. Wonder if anyone has adjusted the duration they stay on.
  2. Jul 5, 2023 at 4:18 PM
    2mchfun
    Not sure about the computer settings, but one can always rewire a circuit and add in a timer without too much effort.
  3. Jul 5, 2023 at 4:19 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that there's a setting that you access via your dash cluster that gives you the option to set how long the dome light stays on. I think that is tied to the time the puddle lights stay on.
    Boatmoney[OP] and 2mchfun like this.
  4. Jul 5, 2023 at 4:30 PM
    Boatmoney
    Mark
    The dome light stays on but the courtesy lights turn off strangely enough.
  5. Jul 5, 2023 at 4:34 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I can't remember how long mine stay on, I set it so long ago that I'm not even positive how to access the setting. It might be in your Owner's Manual.
    Edit: Manuals here https://www.toyota.com/owners/resources/warranty-owners-manuals.tundra.2019
    Look in your stereo settings....
  6. Jul 5, 2023 at 4:39 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Your puddle lights run off the mirror control ECU.
    Although there is a connection to the main ECU.
    They are powered off the brown wire of the #6 pin in the mirror plug (M6 and N5) if you wanted to make a modification.
    bulldog93, Boatmoney[OP] and 2mchfun like this.
  7. Jul 5, 2023 at 5:05 PM
    Boatmoney
    Mark
    Thanks for the info looked in the stereo setting and get this the max time is only 30’s ‍♂️
    bulldog93 and Wynnded[QUOTED] like this.
  8. Jul 5, 2023 at 5:08 PM
    Boatmoney
    Mark
    This is great info thanks, it looks like this seems to be the only option I seriously can’t believe Toyota doest offer a way to adjust this longer than 30’s ‍♂️
  9. Jul 5, 2023 at 5:16 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    So it appears. I think that the headlamp can be set to stay on for something like two minutes, but I'm guessing that's not the area you're wanting to have light.
    Boatmoney[QUOTED][OP] likes this.
  10. Jul 17, 2023 at 5:51 PM
    JustKJ
    JustKJ New Member
    Allan
    Northern VA
    2021 Mesquite Brown 1794 Crew Max TRD
    3 -2 inch TRD lift, TRD Exhaust,
    This great info - thanks
    ...another question on these courtesy lights under the mirrors.
    Does anyone have a number for the bulb/light to swap it for an led? I'm currently swapping out all of my interior lights and have all of those but can't find a bulb number or part number for these.
  11. Jul 17, 2023 at 8:38 PM
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
  12. Jul 18, 2023 at 11:45 AM
    JustKJ
    JustKJ New Member
    Allan
    Northern VA
    thanks - will give them a try - cheers
  13. Jul 27, 2023 at 8:40 AM
    JustKJ
    JustKJ New Member
    Allan
    Northern VA
    Kaymonster - thanks again for the info - order them/received them/installed them. Definite improvement. Cheers
    kaymonster likes this.
