Can Toyota get Brakes right? EVER?!
Discussion in '3rd Gen Tundras (2022+)' started by Tilt-up Tundee, Apr 10, 2023.
  1. Apr 10, 2023 at 6:23 AM
    Tilt-up Tundee
    Tilt-up Tundee [OP] New Member
    Moe
    22 Tundra SR5 Army Green
    Here's my dilemma....
    Purchased the truck July of 22'
    @ 9K miles started experiencing rotor warp symptoms - dealership was not very helpful at first
    @14K miles during my oil change etc - dealer offered to cut front rotors (didnt want to do that but need my truck for work)
    @22K miles - Rotors again shake violently over 65 mph
    I understand that rotors and pads are a wear item...however seems odd since I commute 98% highway. I do not drive the truck hard at all, and avoid thermal shock (hot brakes cold water puddles etc)
    I am at a loss, new truck should not need damn rotors @ 9K. Did I just get a bad set or are others experiencing this?
    Would you push for more from your dealer/Toyota?
    If I am out of luck and need to replace out of pocket would you go OEM or aftermarket?
    Love this truck and this brake issue is my only sour grape with it...
  2. Apr 10, 2023 at 6:36 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    I don't have warped rotors as of now but my rear brakes do squeal a lot when they are cold and the weird brake stutter when coming to a full stop, my service manager told me they will replace the set when Toyota comes out with a fix and I think the same applies to you. You shouldn't have to worry about rotors at 9k and you don't seem to abuse your truck so it's fair to say your rotors are likely to be defective hopefully they make it right.
  3. Apr 10, 2023 at 6:46 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    I've heard that overtorqued lug nuts can damage the surface of the rotors. Maybe that's leading to them getting off balance. Are you running stock wheels and tires still?
    NickBrewer and Hella Krusty like this.
  4. Apr 10, 2023 at 6:48 AM
    Tilt-up Tundee
    Moe
    Yes truck is fully stock and I did hear that as well so when rotors were cut, Wheels were put back on and TQ to spec.
    crikeymike[QUOTED] likes this.
  5. Apr 10, 2023 at 6:52 AM
    crikeymike
    Hmm. I wonder how the hubs are then. Maybe that surface was compromised at some point. New hubs, rotors and calipers from the dealer perhaps are in order to get it all new and isolate the problem.
  6. Apr 10, 2023 at 6:59 AM
    Wonder if you have a stuck caliper?
    Another option is new rotors/pads. I'm dealing with something similar on my wife's Subaru. OEM brakes lasted 77k miles. I put stoptech rotors and pads on from rockauto and have not been impressed. Personally, I don't think I received stoptech anything. The rotors were .010 out on the back side and had them machined. They are a little better now, but still have a little pulsation in the brake pedal. From now on I will not be purchasing any performance brakes from rockauto (or any part's distributor). They will come directly from the manufacturer.
    It seems hit or miss with Toyota brakes. The braking system itself is damn good. My 2012 tundra went 65k on original pads/rotors and I tow on the heavy end. Now on all my Tacoma's and 4Runners the rotors and pads lasted 15-30k miles. My Lexus IS350 (same calipers as tundra) are excellent. You stab the brakes on that car...hold on.
    texasrho83 likes this.
  7. Apr 10, 2023 at 7:54 AM
    Tilt-up Tundee
    Moe
    I also own a 13 GS 350 F sport. Nothing but issues on the OEM pads and rotors ( front oem rotors on that car use to run me 330 a piece!) After about 900 bucks in OEM shit the brakes last 10K miles.
    Switched to aftermarket and been on that set for 20K miles with plenty of life and no signs of rotor warpage or any brake issues for that matter.
    Brakes on the truck feel solid, id really wouldn't expect a stuck caliper but I will check and confirm.
  8. Apr 10, 2023 at 8:07 AM
    nodak67
    nodak67 New Member
    JR
    <looks left> ..... <looks right> ..... still on oem everything on brake system on my 14 4runner @ 95k (including pads)
    plan on doing brake flush, spark plugs, acc belts this summer
    edit: just remember i only driv 4 days a week (garaged thursday nite until monday morning to goto work)
    and if there is a holiday, then its only 3 days that week and 4 days garaged. after work we drive the tundra
  9. Apr 10, 2023 at 8:17 AM
    I don't use factory parts either on Toyota vehicles.
    Jthawks likes this.
  10. Jul 4, 2023 at 5:16 AM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    I have this identical issue. I run about 600 miles per week commuting on mostly highway. Brakes heat up after one or two firm pedal events (not slamming on, just higher speed passing and then braking to get back to 9mph over) and the rotors shake and shudder badly until they cool back down.
    Very frustrating and have been unable to find any aftermarket rotors yet. Pleas share if you find anything. I’ve emailed PowerStop, PowerBrake, Dynamic Friction, and DBA (Disk Brake Australia). Love the truck. Very disappointed with the brakes.
    RastaMan69 likes this.
  11. Jul 4, 2023 at 11:18 PM
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    On my 2nd gen Tacoma I sold it at 106k miles with the original pads and rotors and I lived in Colorado and frequented mountains. Granted I used engine braking a fair amount but it's still up and down mountains a bunch. No issues on my Tundra so far, 10k miles.
  12. Jul 10, 2023 at 10:43 AM
    aoteri983
    aoteri983 New Member
    2022 TRD Sport
    I have the same problem on my 22 SR5. Brake pedal started with a slight pulsation around 16k, and just took it in to my dealer for the 20k service today. Service advisor said that they would resurface the rotors under warantee since it was less than the 3yr/36k on the truck. He said that as a condition of the warantee, they will not let them replace the rotors until they have tried to resurface first, but that resurfacing will likely only be a band-aid fix and the problem will come back in a few thousand miles. When that happens, he said if I take it back it will be a continuation of the same issue, and they will replace all 4 rotors and pads under the basic warantee.
    spigatelli, Tundrastruck91 and Kap1 like this.
  13. Jul 16, 2023 at 10:43 AM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
  14. Jul 16, 2023 at 10:44 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    I found on my last 2012 tundra, same warped rotors low milage and replaced them myself. I found the the colling channels clogged with rust peel so no air could flow through them.
    My past f150 lariat had ceramic from the factory- paint(white)sprayed on them and no rust developed and rotors were good past 30k.
    See 3 coated hat and edge.....
  15. Jul 16, 2023 at 11:44 AM
    BrianRogers
    BrianRogers New Member
    Sitting at 9k and brakes squeal like a pig. Hoping to address at 10k service.
  16. Mar 4, 2024 at 6:32 PM
    RastaMan69
    RastaMan69 New Member
    Ley
    2019 Tundra TSS Cement Grey
    Flowmaster-Super 44, BDS 7" lift with Fox shocks, 22's on 35's, Oh S&*t bar mod, Console safe...wireless charger, ADD Stealth Fighter bumper, Rigid lights
    I have a 2019 and been going through the same thing. My truck is lifted with 22's and 35's but every variation of rotors and pads that I've tried end with the same result. I now have EBC rotors and pads from a dude I saw on YT that claims to be the fix-all...nope...dont get me wrong...it isn't as bad but it's there and these give me a lot more dust. Didnt want to pull the trigger on a big brake kit but thinking it's my last option.
  17. Mar 4, 2024 at 7:42 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    OEM rotors 146,355 miles..
    Hella Krusty and Mattedfred like this.
  18. Mar 4, 2024 at 9:41 PM
    Tom976
    Tom976 New Member
    Tom
    Two words.... Thermal Shock...... Hot rotors and cold water = Thermal Shock Do that a few times and those rotors wont be true anymore.
  19. Mar 4, 2024 at 11:27 PM
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    My coworker told me a story about a guy with one of those street legal race cars Mercedes makes…the owner needed a break job, turned out to cost like 20 grand.
    So the guy gets on the phone and calls Germany to ask if there is anything they can do to help. They said, sir, we can’t technically tell you to do this, but drive about 180mph and slam on the breaks…that should do it
    maybe trying to baby the breaks in a truck designed to tow 10k lbs. is not good for them :notsure:
    Kap1 likes this.
  20. Mar 5, 2024 at 3:56 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    ALCON roup buy one on nowtill 3-15-24
    reywcms likes this.
  21. Mar 5, 2024 at 4:41 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Confessional time: are you a tail gater? At high speeds in all traffic conditions? To include driving in a high traffic city? If you live near me then you are as 70% of people ride the bumper and hit those brakes hard constantly. I can't even make a right had turn into my driveway without the clown behind me locking it down despite me signalling well in advance.
    I am have not replaced pads in 30 years on any vehicle to include several over 100k miles. My wife tailgates, so her vehicles usually gets at least one set of pads before we trade them in.
    I had a mid 90s Ford which were infamous for consuming rotors. Everyone that bought one that I knew had issues. If you buy a vehicle and you are one of a few with issues consider how you use the vehicle as a possible problem.
    j-utah and MTRock like this.
  22. Mar 5, 2024 at 5:31 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    ALCON website doesn't list any products for 2022+ Tundra?? Only Toyota model listed is Tacoma??
  23. Mar 5, 2024 at 6:06 AM
    JohnWhicker
    JohnWhicker New Member
    My 2013 and 2021 brakes are just fine LOL
  24. Mar 5, 2024 at 7:05 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    31K miles, half with Four Wheel Camper loaded in the back and on oversized tires. Zero brake issues and I'm sure I've tortured them a couple times in sudden highway braking situations. Seems something out of wack is causing this if it isn't a driving behavior.
  25. Mar 5, 2024 at 7:39 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    They have a kit for the new gen.
  26. Mar 5, 2024 at 9:52 AM
    jdietrich
    jdietrich New Member
    Kansas City, Mo
    2023 Platinum Wind Chill Pearl
    TRD Pro Grille, Diodedynamics light bar & fog lights, Talon Cat guard, RCI Skid, Suntek Paint Protection, Century Topper, Paint match mustache, GG Off-road Re-Locator
    Any experience / thoughts on upgrading brakes to something like Wilwood?
  27. Mar 5, 2024 at 9:55 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Do they have both a front and rear kit? Ideally you want front and rear done
  28. Mar 5, 2024 at 9:58 AM
    jdietrich
    Kansas City, Mo
    Agreed. Unfortunately only front for now. Would have to have the rear painted to settle my OCD.
  29. Mar 5, 2024 at 12:22 PM
    19PlatinumCrew
    Dave
    22+ I think is front only give Chris a shout at Alcon kits . Com he will set you up
  30. Mar 5, 2024 at 5:39 PM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    Do you use the dynamic cruise OP? that can be a brake killer...especially in any traffic
