  1. Jul 14, 2023 at 2:43 PM
    That's why they call it a 'slip yoke' bro :rofl:
    It slips in and out on splines. Visualize what would happen if your rear axle engaged the suspension over a speed bump and it didn't slip in/out ...
    JasonC.[QUOTED] likes this.
  2. Jul 14, 2023 at 3:14 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Confucius say….dentists have been known to give wayyy to much laughing gas to their patients !
  3. Jul 14, 2023 at 3:19 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If I had known this, we could have traded my good leather wheel for the shocks lol
    des2mtn[QUOTED] and FrenchToasty like this.
  4. Jul 14, 2023 at 4:45 PM
    daveeasa
    Since 'drew is in the house, any chance you know if it's possible to clear the airbag code via techstream?
  5. Jul 15, 2023 at 10:05 AM
    Maybe my memory is wrong but I don't remember having to remove timing covers to get the serpentine belt tensioner out when we replaced @jpink 's
    At least I know the belt still looks good.
    Voss and metalpete like this.
  6. Jul 15, 2023 at 10:08 AM
  7. Jul 15, 2023 at 10:28 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Dude, I've done that job before. Absolutely insane how much has to come out before you get to it. I had a shop do some work and shortly after, my truck sounded like it was coming apart. Long story short, the bolt was mostly sheared off and seized, so I had to replace the whole thing. I love how the Haynes book says "remove the bolts holding in the assembly" and that's it.
    Did you take the radiator out or work around it?
    oscardog86 and txagg like this.
  8. Jul 15, 2023 at 10:57 AM
    Absolutely. I knew better than to attempt it with the rad in place. I'm also replacing the alternator too.
    Voss and metalpete[QUOTED] like this.
  9. Jul 15, 2023 at 11:09 AM
    metalpete
    ID
    Nice! I had a similar thought of, "well shit, I could just replace the alternator and ps pump while I'm here", but was one of those 11th hour jobs.
  10. Jul 15, 2023 at 11:40 AM
    Thankfully the power steering pumps seem to last forever. I've only seen a few members have to replace theirs. :fingerscrossed:
  11. Jul 15, 2023 at 11:57 AM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4
    :anonymous: Guess I’ll be one of the few haha. Mine isn’t there yet but it’s pretty weak.
    Do y’all have to pull the radiator for that job?
  12. Jul 15, 2023 at 12:15 PM
    Yeah, just tends to moan slightly regardless what it has going on. Never understood that, but I've heard it on almost every 1st gen.
  13. Jul 15, 2023 at 12:23 PM
    Will moan a lot more (continually) if the fluid level mistakenly gets low due to a leak.
  14. Jul 15, 2023 at 1:59 PM
    Totally, that's what spooked me the first couple of days I had the truck. I was, like, "how tf is the power steering pump moaning already, and it's barely got 60k on the clock?!"
    Then I listened to a few more online, and I've since put my hands on other people's, and ... it's rare not to hear one that's got it. I wish there was an additive or something that would help... maybe the pump just isn't over-beefy like some others make theirs? Going for Longevity vs. Power?
  15. Jul 15, 2023 at 2:00 PM
    Almost done here. Replaced the alternator, upper radiator hose, serpentine belt(Gates HD) and belt tensioner. Trying to get 3 gallons of coolant back in it after draining almost exactly 3 out of it.
    So shiny!
  16. Jul 15, 2023 at 2:03 PM
    May as well keep the old one, rebuild it. It's really, pretty simple to rebuild them if you never have (I can't remember), and always good to have a spare on-hand. I see your green!
    Congrats on finally getting this done!
  17. Jul 15, 2023 at 2:22 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I’ve had great success with Lucas Power Steering Stop Leak for groaning power steering. I haven’t really used it to stop leaks even, just noises and they go away and don’t come back.
    I’ll just suck out as much as I can from the reservoir and top it up with the Lucas, good to go.
    I try and avoid fixes in a bottle type stuff, but it really has worked well and I can’t see how it could do any harm like some crankcase additives could.
    oscardog86, bmf4069, NUDRAT and 2 others like this.
  18. Jul 15, 2023 at 2:58 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Just throw a spoon or two of fabric softener in the PS fluid, problem solved. Did it to mine and it fixed the whine. I'll keep preaching it until you all do it. And that tensioner job is complete bullshit, did it a couple of months ago. I usually do some recon before a job, but figured its just a tensioner and it should be a piece of cake. Total PITA. Anyone considering doing this, might consider just changing the pulley. Pretty sure that was the culprit on mine, as the tension was still good on the old one. Would have been cheaper and saved a ton of cursing.
  19. Jul 15, 2023 at 3:22 PM
    Yes it is. I've had this one sitting around since 2019 when I replaced my radiator. I went to install it back then and tapped out. Since I was replacing the alternator today it was the best time to do the tensioner.
    Voss, txagg[QUOTED] and metalpete like this.
  20. Jul 16, 2023 at 10:41 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Using it today… frame swap begins on my 98 taco
    Voss, hammeron, oscardog86 and 14 others like this.
  21. Jul 16, 2023 at 4:55 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Fun little trail by my house. Ended up finding some sun
    Voss, oscardog86, bmf4069 and 8 others like this.
  22. Jul 16, 2023 at 7:38 PM
    empty_lord
    05 rollover special
    It is now towing the remnants back home [​IMG]
  23. Jul 16, 2023 at 8:02 PM
    969C7BFD-1E41-4C50-BACE-0FBD88F4CDF0.jpg D54F095E-C506-4CD6-83F8-D052B0ADEBEA.jpg 13AB313C-A1BD-44C2-9EC0-2CF59D67FCA1.jpg Ran a trail with some of the local boys today to escape the heat.
    @Sunnier, Eman asked if you were going to be there, and was kinda disappointed you weren’t. “Are our friends going to be here? What about sunny?”
    Voss, NUDRAT, shifty` and 9 others like this.
  24. Jul 16, 2023 at 8:09 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Nice
  25. Jul 16, 2023 at 8:23 PM
    Sunnier
    Sunny
    San Diego, CA
    Aww, I am smitten! :) Love that Boy!
    I hope to see y'all in a coupla weeks!
    P.S. I'm actually stunned I got a mention. @Cruzer is his (mine, everybody's) actual favourite.
  26. Jul 16, 2023 at 8:25 PM
    Hahah I feel like he blurted out “Cruz?!” And I’m like what? He’s like oh nothing
    DJenerated likes this.
  27. Jul 16, 2023 at 8:26 PM
    Sunnier
    Sunny
    San Diego, CA
    Lol! I edited my post. Check again.
  28. Jul 16, 2023 at 8:26 PM
    Sunnier
    Sunny
    San Diego, CA
    We were both thinking the same. I mean, #facts.
  29. Jul 16, 2023 at 8:28 PM
    It’s no fault of Cruz either which is hilarious!
    Sunnier[QUOTED] likes this.
  30. Jul 16, 2023 at 8:28 PM
    Sunnier
    Sunny
    San Diego, CA
    Nope. He just naturally fabulous.
