  1. Jul 14, 2023 at 6:56 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Hmm. I cleared mine once before by checking that box. I have noticed that old numbers stay in the boxes sometimes. I just change them and try again.
    coTony[QUOTED] likes this.
  2. Jul 14, 2023 at 7:06 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Thanks.
    Wash/iron remover, clay, took the most time.
    Taping sucked.
    Stage 1 was the most labour and arm intensive.
    Stage 2 wasn't bad.
    Stage 3 (wax) was fun as it showed us the results for our work and was pretty quick.
    Now I have to go back and clean all the windows again.
    BR73, PlaysARobin, cartage1 and 4 others like this.
  3. Jul 14, 2023 at 7:17 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    I’m almost caught up. Might put on like 1k next week.
  4. Jul 14, 2023 at 8:46 PM
    BeachTundra19
    BeachTundra19 New Member
    Zak
    2019 Tundra Platinum "Silver Sky Metallic"
    None Yet
    IMG_8362.jpg IMG_8357.jpg Finally got around to wiring up my bed lights Homemade solution mounted to the bed cover that rolls up so it can always be used Tapped into the cargo light switch so the lights on with that… Struggled there and big thanks to the forum for all the research as I suck with electrical but learning. IMG_8358.jpg
  5. Jul 15, 2023 at 5:00 AM
    niedejb
    niedejb New Member
    Sumter, SC
    '17 Platinum
    Love the look... Any pics of the whole truck with the new wheels?
    BR73 and Tundra Dude 45 like this.
  6. Jul 15, 2023 at 6:04 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    what style blanks are guys running. Seems like there are a few options for r1.
  7. Jul 15, 2023 at 6:06 AM
    Finished up the trim on the rear AC addition.
  8. Jul 15, 2023 at 8:11 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Even with E-load tires and 5w-30 oil, sometimes the wind direction is just *chef's kiss*
    Tundra-XP, Terndrerrr, ATV25 and 9 others like this.
  9. Jul 15, 2023 at 8:50 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I did a similar mod for my M3. Ended up hating how thick the new sporty carbon fiber flat bottom wheel was.
    What are your thoughts? Does this one feel like your holding a pool noodle when driving?
  10. Jul 15, 2023 at 9:04 AM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Not today, but about 3 weeks ago. For a few weeks I had this popping, creaking sound. Was scared it was my suspension or something else bad. Finally narrowed it down to my skid/cat plate. I had installed it back in Feb I think so was surprised that it had just started. Mine is from @Talon2006 garage. Finally isolated it to the seam below (not my pic - but mine is the same). So about 3 weeks ago I hit the seam with a bunch of WD40 Specialist. I didn’t loosen it or anything … just put the spray tube right up to it. Maybe it had gotten some grit or something between. I guess the truck flexes just enough to cause some movement. I don’t know, but it’s been 3 weeks and still quiet.
  11. Jul 15, 2023 at 9:06 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    We did the wash one day, however long your normal wash takes. Then an iron remover, which was about an hour.
    Clay bar next morning. That took an hour or so, with two people, so 2 hrs. We did it with a spray bottle full of car wash soap each.
    Next day we started the 3 step with the Griots G9. A quick touchless wash and dry before hand as we park outside and have gravel roads in our area, although they are pretty much paved feeling.
    The actual 3 step process, with two people, took about 4 hours, so 8 man hours. Maybe 1 more hour later that day, as I applied a second application of wax and buffed.
    Add 30 minutes at the end for missed hand buffing spots, and to Windex/beadmaker the windows as they had lots of gunk from the polisher splatter.
    We are NOT experts and it was our first time.
  12. Jul 15, 2023 at 9:09 AM
    Experimented with a permanent ScanGauge 3 mount. Two options that I came up with. I think I may stay with the 2nd one.
  13. Jul 15, 2023 at 9:32 AM
    1UP
    1UP Truck Gang
    Just purchased the OFFROAM phone mount. 85 bucks!
    Hopefully it works for me as well as it has for others. I have a Note Galaxy and someone in here specifically said it worked great for their Note.
    texasrho83 and AGTundra like this.
  14. Jul 15, 2023 at 10:06 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Looks great!
  15. Jul 15, 2023 at 2:15 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    That’s right where I have my boost/AFR gauge. You have to take your eyes off the road but it’s not being obnoxious mounted up by A pillar. Compromise.
  16. Jul 15, 2023 at 2:22 PM
    I like keeping things out of site as much as I can.
    French Avocado, fuzzamungus and 1UP like this.
  17. Jul 15, 2023 at 3:05 PM
    centex
    centex New Member
    7.8mpg with this load of ~3600lbs. 65mph in 4th gear because it won’t hold it in 5th gear. Time for some 5.29’s because that’s ridiculous.
    HulkSmurf14 likes this.
  18. Jul 15, 2023 at 5:22 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    I think it is a really solid mount …was one of the first things to go in the truck!
    Can’t speak on your fitment ( think I have a 13 plus iPhone) but hopefully it will work well for you
    1UP[QUOTED] likes this.
  19. Jul 16, 2023 at 8:45 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Put on a set of Dobinsons L59-121-R HD leaf kit. These provide 2.5" of lift, so I put the stock shackles back on and removed my Coachbuilder +3 s. It was a tough job by myself with how heavy they are and of course it was one of the hottest days of the year so far.... The heavy ass leaf pack on the drivers side accidentally ripped the abs wheel sensor on one side so now I need to splice it or replace that soon :facepalm:
  20. Jul 16, 2023 at 8:48 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    By the way, I removed the TRD sway bar as well as it was now hitting the new leaf packs. I don't think I will use it anymore but I'm curious if anyone knows if longer end links are available?
    CaptRussia253 likes this.
  21. Jul 16, 2023 at 9:20 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Looks good.
  22. Jul 16, 2023 at 11:43 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    They are available, I'll see if I can find a link for you. If I do, I might be interested in yours - someone here has a front and rear TRD swaybar set I was interested in, but his links were missing, so this could complete the set, hmm
  23. Jul 16, 2023 at 3:24 PM
    It shouldn't be hitting.
  24. Jul 16, 2023 at 3:50 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    I was pretty tired when I tried fitting it the other day so it might still work. When I tried it, the end links couldn't reach unless the bar was rotated upward so it was touching the leaf on each side. Maybe I'll take a closer look.
  25. Jul 16, 2023 at 4:02 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Went and had my buddies at the dealer smoke test the evap system so we can find the issue. Now to order the parts and fix. Also did a drain and fill on the trans.
  26. Jul 16, 2023 at 5:03 PM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Changed the oil and spark plugs,
    Installed AJT trim (didn't do the HVAC or 4wd knobs)
    , and gave my audio a cleaner low end punch.
    PXL_20230715_173646507.jpg PXL_20230715_174602643.jpg PXL_20230715_173846363.jpg
  27. Jul 16, 2023 at 5:57 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    We’re you still able to use your air bags?
  28. Jul 16, 2023 at 6:18 PM
    CaptRussia253
    Ruslan
    Look at all that travel!
    How much was drained out?
    Tripleconpanna likes this.
  29. Jul 16, 2023 at 6:35 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I think he said 4-5 but I wasn’t really paying attention lol
    CaptRussia253[QUOTED] likes this.
  30. Jul 16, 2023 at 6:53 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Got droop bro?
