Secondary Air Injection Pump Question
Discussion in '2nd Gen Tundras (2007-2013)' started by ICECOLDBEER, Jul 13, 2023.
  1. Jul 13, 2023 at 8:54 PM
    ICECOLDBEER
    ICECOLDBEER [OP] New Member
    2009 Toyota Tundra TRD Off Road 5.7 4x4 Double Cab
    A couple months ago I got a check engine light so I scanned it and it was the classic secondary air injection pump code which from reading on here I knew one day would come. I believe it was valve stuck closed. So I thought good I don't need that emissions crap (no testing here) and just kept on driving. What I am wondering is if I am living on borrowed time? because I have read that some peoples trucks got put into limp mode when their pumps/valves stopped working.
    Has anyone successfully driven their truck long term without fixing them or installing the bypass kit? Would be nice to get the check engine light turned off but if its going to work fine whatever keep on trucking.
  2. Jul 14, 2023 at 7:36 AM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    Have had a bypass kit on an 05 Sequoia for a couple years. It’s the cheap one a guy sells on a Tacoma forum. We put it on when things were working and no issues to date. Not sure how having codes changes things for you. Early on we had the SAI go out and immediately place the rig in limp mode, it was fixed that time, the bypass put on much later as a preventative measure.
  3. Jul 14, 2023 at 8:41 AM
    EmergencyMaximum
    Have you checked if yours qualifies for a recall? I had mine repaired by toyota and even had a rental taken care of.
    2010 4.6L v8 2wd
    Went into limp mode.
    ICECOLDBEER[OP] likes this.
  4. Jul 14, 2023 at 10:00 AM
    art64
    art64 New Member
    You can get a bypass kit from Hewitt-Tech that will completely bypass the sai. Comes with a module, harness, plates. There are thread on the kits on this forum. I like the complete bypass-no need to touch the sai except unplugging wires . Unless the valve is stuck open, you can just leave it the way it is and install the kit.
  5. Jul 14, 2023 at 4:58 PM
    EmergencyMaximum
  6. Jul 14, 2023 at 7:03 PM
    ICECOLDBEER
    Thanks! Interesting mine is a 2009 only have just over 100k kms. I think that would put me over the 10 year mark? I will see what the local dealer says.
  7. Jul 14, 2023 at 7:10 PM
    EmergencyMaximum
    Well, if you're liberal on wording interpretation, it could mean warranty is extended **AFTER** repair is done, but before it doesn't matter, since it's a recall and should be initially performed regardless of miles..
    After all, if it were air bags or some other safety problem, they wouldn't tell you "we can't repair them, since you're over miles". A recall typically doesn't have mile limit or expiration.
