Shake hands with Danger- WAY over load rating
Discussion in 'General Tundra Discussion' started by DeadCATPatrol, Jul 14, 2023.
Thread Status:
Not open for further replies.
  1. Jul 14, 2023 at 1:24 PM
    DeadCATPatrol
    DeadCATPatrol [OP] New Member
    Logan
    Snowmass Village, CO
    Tundra TRD Double cab 5.7L
    2.5 in strut spacer and 1 in rear block 35/12.5 on stock TRD rims no wheel spacer
    Doing a fence job and needed to pick up the concrete for the posts, got a pallet (40 bags) of 80lb bags and didn’t have a trailer so it was time so see what my baby can really do. I have airbags in the rear and they were aired to 70psi. Also my custom flat bed definitely weighs more than a standard bed so I’m figuring close to triple the rated haul capacity. It did it, but next time I’m having the concrete delivered.
    Taco-Spike likes this.
  2. Jul 14, 2023 at 1:26 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That was not the best idea you have ever had.
  3. Jul 14, 2023 at 1:27 PM
    Taco-Spike
    Two Trucks
  4. Jul 14, 2023 at 1:42 PM
    That back tire is crying. Those (assuming) LTs are good for 3400# each and they were likely maxed out. 3600# rear axle weight on these with another 3200# of crete. Wowza. Rear axle GAWRR of 4200#.
    Seafury and ZappBrannigan like this.
  5. Jul 14, 2023 at 1:44 PM
    AZBoatHauler
    So.Arizona
  6. Jul 14, 2023 at 1:52 PM
    MattAK
    MattAK Headin' for the hills
    Alaska and Utah
    '19 SR5 DC White
    Valhalla Cat Plates, GCS Cooler, Dobinsons, RAS
    I admire your bravery for this post as you had to know you would get rightfully roasted. Renting a trailer for a day would have been a much better idea and safer for the general public you were near to.
  7. Jul 14, 2023 at 2:07 PM
    DeadCATPatrol
    Logan
    Agreed.
    Seafury likes this.
  8. Jul 14, 2023 at 2:10 PM
    DeadCATPatrol
    Logan
    Your assumption is correct, I believe they’re 6ply. I think I got away with murder today, never doing anything that sketchy again. Looking into getting an old 7.3 for work truck
    Seafury and KNABORES[QUOTED] like this.
  9. Jul 14, 2023 at 2:20 PM
    EmergencyMaximum
  10. Jul 14, 2023 at 2:27 PM
    Rockwell
    Rockwell New Member
    New Jersey
    2021 Tundra Crew Max SR5
    Oh yeah, you're definitely gonna wake up The Safety Committee on here with that post. Don't worry, eventually it will be deleted. As me how I know!
    Glad it all worked out for you.
  11. Jul 14, 2023 at 2:29 PM
    I stand corrected, those are the 116t P rated tires with a capacity of 2760# each.
    Seafury likes this.
  12. Jul 14, 2023 at 2:29 PM
  13. Jul 14, 2023 at 2:31 PM
    CTundraForMe
    CTundraForMe New Member
    Ouch.
    Home Depot would charge $80 to deliver it on a truck much more capable than yours!
Thread Status:
