  1. Jul 13, 2023 at 11:16 AM
    ghott86
    ghott86 New Member
    VA
    ‘21 Super White SR5 CM 4x4
    I just used the vent/phone mount (SKU: TFEN-VMAS1-MG1). The magnet on the TackForm is plenty strong for the SG3…and the SG3 comes with a magnet that sticks on the back of it.
    Also - no engine oil temp in the SG3. I mostly got it to monitor trans temps.
    bulldog93 likes this.
  2. Jul 13, 2023 at 11:37 AM
    Thanks!!
    ghott86[QUOTED] likes this.
  3. Jul 13, 2023 at 11:39 AM
    Just installed the Speedometer calibration unit. I'll test it on the way home from work.
    AggiePhil, Tundra-XP, reywcms and 4 others like this.
  4. Jul 13, 2023 at 11:41 AM
    Just installed it. I set the stock size and the 295's and it added the inch measurements. I'll see how close it is on the way home.
  5. Jul 13, 2023 at 12:28 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    I started with my cat plate. It was the biggest need for my truck.
  6. Jul 13, 2023 at 12:55 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    New steering wheel and rims and tires
  7. Jul 13, 2023 at 1:00 PM
    DirtyMike5
    DirtyMike5 New Member
    Baton Rouge
    I love budget builds! How do I go about getting these OEM "Broken tab" headlights?
  8. Jul 13, 2023 at 1:03 PM
    Taco-Spike
    Two Trucks
    Is it really that big in person?
  9. Jul 13, 2023 at 1:59 PM
    1Wayout
    1Wayout New Member
    New topper and Cap Pack Sport installed.
  10. Jul 13, 2023 at 2:06 PM
    YotaMan
    Colorado Springs
    2021 Platinum
    Wide angle lens is my guess. Same size as OEM
  11. Jul 13, 2023 at 2:14 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I put in old tire size as the stock TSS wheel/tire combo (converted to standard) then 37x12.5r18 and I'm off by 5-7 mph.
  12. Jul 13, 2023 at 2:23 PM
    I was off 4-5 mph and on the way home the speedo and GPS on my radar detector were reading the same. Waze was 1 mph off from that so I'm close. I just need to get lighter traffic so that I can set the cruise and let is settle. I did set the cruise at one point at 75, and the speedo said I was doing 76.
  13. Jul 13, 2023 at 2:50 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I took a drive then connected to the module and it showed the old tire size on my door jamb for some reason. So I put in the TSS wheel spec again to see what kinda gap there is now.
  14. Jul 13, 2023 at 3:39 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Taco wheel or aftermarket?
  15. Jul 13, 2023 at 4:51 PM
    coTony
    Tony
    Montrose, CO
    Do you know how to reset those calibrators (I have Rough Country) back to zero? I set mine originally in 2020 with 35's and now I just put 37's on last Thursday and need to do it again. I knew my OEM tire size, stock gear ratio and new tires and gears but it took it from 1.3 something to .95 something, wrong direction. Then I tried the other methods and each time the scale factor would change but only a little and the drive differences in GPS were the exact same. Perhaps the little amount the numbers were moving it was only a fraction of a mile. I got bored real quick with having to go back home to make an adjustment because you cannot use it without an internet connection.
    I read where someone (forgot who, a lot of reading lately) was adjusting the before tire size to help get there so I guess I can try that. Wish I could pull over, make a change and drive, rinse and repeat
    texasrho83 likes this.
  16. Jul 13, 2023 at 5:03 PM
    That looks great. :thumbsup:
    BR73, biebs96 and IsaiahCanada like this.
  17. Jul 13, 2023 at 5:30 PM
    I think there was a reset option when you connect the laptop to the module.
  18. Jul 13, 2023 at 5:43 PM
    AZTundra
    Paul
    Phoenix, AZ
    No ability to connect via hot spot and adjust on the side of the road? Or am I thinking about it wrong? I've got the hypertech unit which has been sitting in the box for over a year now. I need to make some time and correct my speedo too.
    Henry1jg, AggiePhil and texasrho83 like this.
  19. Jul 13, 2023 at 6:12 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I turn on my hotspot (phone) and get to adjusting.
    Henry1jg and AZTundra like this.
  20. Jul 13, 2023 at 6:12 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    There is.
    Tundra234[QUOTED] likes this.
  21. Jul 13, 2023 at 6:30 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Similar to my cellphone mount (Offroam).
    mgm16trdpro likes this.
  22. Jul 13, 2023 at 6:31 PM
    Do you have any vibrations? I have some with the Tackform.
  23. Jul 13, 2023 at 6:56 PM
    Azblue
    The Dirty T ( ^_^)_且
    TWSS
  24. Jul 13, 2023 at 6:59 PM
    Taco-Spike
    Two Trucks
    :hattip:
  25. Jul 13, 2023 at 7:09 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Negative.
  26. Jul 13, 2023 at 7:13 PM
    I wonder how I can get rid of the shakes. The vent moves slightly....I'll hold my hand on it in the morning and see what happens.
  27. Jul 13, 2023 at 7:47 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Her response was, 'that doesn't look anything like the picture'...
    bulldog93 and Azblue[QUOTED] like this.
  28. Jul 13, 2023 at 8:07 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    Hair of the dog? :notsure:
    MatthewPTguy, Mike59, wiltech and 4 others like this.
  29. Jul 13, 2023 at 8:26 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Is it the whole mount or just the part holding your phone?
  30. Jul 13, 2023 at 9:00 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Not a fan of oversized rims but god damn those look good!!
    YotaMan[QUOTED] likes this.
