35's on stock suspension
Discussion in 'Wheels & Tires' started by Blackout_Tundra, Jul 1, 2023.
  1. Jul 1, 2023 at 7:50 PM
    Blackout_Tundra
    Blackout_Tundra [OP] New Member
    2016 Black TRD off road
    line-x bed, line-x grill, blacked bumpers, debadged, weathertech deflectors, weathertech mats, other random shit like chains to pull out fords.
    Hello. Just wanted to throw this out since I couldn't find much of anything on it. I had my new tires, and waiting on coilovers. Was told they wouldn't fit, would have problems etc. This wasn't hard at all and it's been AWESOME. Tires are 285/75/r18 duratracs. It's a 35.1 x 11.3 tire, so a true 35 unlike most 295/70/r18s.
    What I did was spaced the front bumper less than 1/2 an inch (didn't even need to), don't have a skid plate at the moment (totalled mine, but you would need to trim it), and nothing else. Barely rubs on rear mudflap before full crank in reverse, but not full crank. Could easily modify, replace, or remove that flap but i don't care.
    Haven't needed to take the tires off road yet and will see how they do in the winter but they absorb potholes and ride much more stable than my ko2s did on road.
    Here's some pics:
    Sleeper16plat, ZPhilip, ATV25 and 3 others like this.
  2. Jul 2, 2023 at 5:23 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Looks good!! The duratracs fit on mine as well. I just had to remove the little “mud flap from the front as it would rub in reverse.
  3. Jul 13, 2023 at 1:18 PM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    will you post a follow up when the coilovers are installed? which ones did you go with and what height setting?
