Ordered a Rough Country CAI; need to vent the hood.
Discussion in 'Performance and Tuning' started by MountainMan, Jul 12, 2023.
  1. Jul 12, 2023 at 1:54 AM
    MountainMan
    MountainMan [OP] New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
    I ordered the Rough Country Cold Air Intake kit for $150.
    Now, I have been around the block a time or two and have been modifying, customizing, and making vehicles faster for 40 years.
    I know all the pros and cons of CAI systems and I noticed that Rough Country's kit really didn't bring in any more cooler air.
    It creates a nice sealed area under the hood for the open element filter, but no way to get more air into the filter. My plan is to find a small functional scoop that will fit over the sealed area and allow cooler air to be drawn directly into the filter.
    The factory system draws in air from the fender. I'm hoping that cutting a hole into the hood and adding a cowl induction style scoop will draw cooler air into the intake and in greater amounts.
    I am fully aware that the most HP gains I could get from all this trouble is maybe 3-7 hp. But, it will sound cool when accelerating, and being an old hot rodder, there is the satisfaction in making it my own.
    Tried finding a carbon fiber small scoop on Amazon and no luck. Anyone run across a scoop around 6" wide, a foot long, and 2" high with carbon fiber finish?
  2. Jul 12, 2023 at 2:39 AM
    MountainMan
    2021 1794 Edition
    Bought this little thing for under $20. Will be interesting to see if it works out.
  3. Jul 12, 2023 at 2:40 AM
    2mchfun
  4. Jul 12, 2023 at 2:53 AM
    2mchfun
    Depending on the year model you have, there are model years that have larger air boxes than others which still fit and bolt right in.
    Hbjeff likes this.
  5. Jul 12, 2023 at 5:06 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    You could add the stillen pipe to your box. I just did this with my Prospeed box and it made a significant difference in IAT temps.
    TRDblvd, TX210Tundra, biebs96 and 7 others like this.
  6. Jul 12, 2023 at 5:09 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    This has potential to be the best thread in a while. For me.
    Black Wolf likes this.
  7. Jul 12, 2023 at 5:41 AM
    2mchfun
    Are those secondary air injection filters I'm seeing? I have bought a set of filters already, but haven't got around to investigating what inside diameter size the stock connection is. Do you by chance know or have a memory of the connectors you used?
    reywcms[QUOTED] likes this.
  8. Jul 12, 2023 at 6:00 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yes I’ll pm you
    2mchfun[QUOTED] likes this.
  9. Jul 12, 2023 at 6:33 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    This and SABM...all the air flows...lol
  10. Jul 12, 2023 at 6:38 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yes exactly lol I also have the sabm. Just for reference in data.
    Stock prospeed box- 60*+ above ambient
    Sealed prospeed box- 30* above ambient
    Sealed prospeed box and stillen tube- 10*-14* above ambient
  11. Jul 12, 2023 at 7:12 AM
    Vizsla
    Vizsla 2 = 2.5
    Have you checked the iat vs. ambient temperature? If your highway cruising iat is ambient or close probably not gaining much, slow/stop and go driving heat soaks the sensor and tube between the filter and throttle body skewing the reading, so need to consider that. Recommend checking iat vs. ambient before starting while cold to check for a delta first. Was able to reduce or at least delay my iat temp from 10-15, down to 5-10 degrees above ambient during slow/stop and go by copying @reywcms heat mitigation tape on the intake tube. Cruising iat is ambient. Please post/share whatever you come up with when finished.
    2mchfun, HulkSmurf14 and reywcms like this.
  12. Jul 12, 2023 at 7:23 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    The tape definitely helps especially in delaying heat soak like you mentioned. I'd also recommend a few layers.
    2mchfun and HulkSmurf14 like this.
  13. Jul 12, 2023 at 7:24 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Gooooooold....and silver too! Ha! Fashion WITH function!
    2mchfun and reywcms like this.
  14. Jul 12, 2023 at 9:23 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Sounds high for sealed box. Extra heat from supercharger?
    My fully stock air box I typically see 2*-5* difference while moving. While stopped or slow, I've seen at most about 40* difference on hot summer day (>90* outside).
  15. Jul 12, 2023 at 9:25 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    It’s not nearly as sealed as the factory box. Sealed meaning more sealed than it was but there’s still gaps etc. Sealed with foam etc. Also the filter is cone style which definitely doesn’t suck pure sealed air like the factory box from the fender
  16. Jul 12, 2023 at 12:49 PM
    MountainMan
    2021 1794 Edition
    I thought the RC box sealed against the hood. If not, then putting a fresh air scoop over the intake will likely just cause all the hot air under the hood to be drawn to that area for venting, which is the exact opposite of what you want.
    The thermal tape is a great idea and I'll definitely use that. I've used it before on an F250 system.
  17. Jul 12, 2023 at 5:48 PM
    thealey
    thealey New Member
    Tyler
    Port Orange,FL
    2017 Toyota Tundra SR5 CrewMax XSP
    Build List: https://1drv.ms/b/s!Aq_KNysdW_0UmkIDSo7_prq_6418
    Looking at getting some tape, about how much did you use on the intake? And would you recommend 1.5” or 2” wide?
  18. Jul 12, 2023 at 6:05 PM
    biebs96
    PA
    I really like this piece. I see it incorporating nicely with my k&n cold air.
    Where did you order it? It’s not listed on stillen, if it is, I do not see it.
  19. Jul 12, 2023 at 6:22 PM
    thealey
    thealey New Member
    Tyler
    Port Orange,FL
    I believe he said that you have to email them to buy it
  20. Jul 12, 2023 at 6:24 PM
    biebs96
    PA
    skimming through. Must have missed that part. Thank you.
  21. Jul 12, 2023 at 6:38 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I did 2” but you’ll need to cut it down to fit the curves etc. There’s a few videos on YouTube on how todo it so it’s clean.
    The stillen tube is not listed but they’ll sell it separate when you contact them.
  22. Jul 12, 2023 at 6:45 PM
    coTony
    Tony
    Montrose, CO
    The boxes are bigger but the air input from the fender is what it is and that is where "more" air will result. Getting a larger opening into the air box is the key not the size of the box
    Saltyhero13 and reywcms like this.
  23. Jul 12, 2023 at 6:56 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
  24. Jul 12, 2023 at 7:03 PM
    2mchfun
    Until your filter begins to become filled with filtered debris. Then does the size of the filter not matter and allow for more air to flow longer? Pretty sure there is a reason to upsize.
    coTony[QUOTED] likes this.
  25. Jul 21, 2023 at 1:06 AM
    MountainMan
    2021 1794 Edition
    Got the CAI installed. Heat tape hadn't arrived, and was on a tight schedule, so just installed it stock. The scoop is a joke. Put it on the hood with the supplied tape, and after about an hour on a dark gray hood at 98 degrees, it warped and wouldn't sit flush on the hood.
    CAI sounds awesome, but no noticeable increase in performance or mileage so far. Will have to get the tape installed next week and get back to my normal commuting schedule and see if the mileage increased.
    Install was easy and straightforward.
    TRDblvd likes this.
  26. Jul 26, 2023 at 9:37 AM
    coTony
    Tony
    Montrose, CO
    If you get that much shit in your air box then you have other problems
  27. Jul 26, 2023 at 11:09 AM
    2mchfun
    No, you seem to be missing the point. The greater the surface area, the more distribution of the debris. Which means that more air volume can flow through the bigger filter compared to the smaller one if they both have collected the same amount of debris. Basically meaning the larger filter could be changed less often. Is it worth the money? Depends on many individual factors and for me I believe so if I can get one for the right price. Time will tell.
    reywcms and coTony[QUOTED] like this.
  28. Jul 26, 2023 at 11:14 AM
    coTony
    Tony
    Montrose, CO
    Understood and yes I missed that
  29. Jul 26, 2023 at 8:57 PM
    MountainMan
    2021 1794 Edition
    Worked on the CAI some more tonight. Took the tube out and applied some decent heat tape to it. When opening the hood after it's been running a while, that CAI tube was HOT. Hopefully the tape helps things a bit.
    After a few hundred miles on it, gas mileage average actually decreased. Probably due to the increased air intake temp. Or the fact that when you stomp on it, it makes an impressive and almost obnoxiously loud sucking sound. Kinda' fun to stomp on it. I've ran CAI kits on many other vehicles, and have never had one be this loud. Luckily, it is only insanely loud when it is at WOT. Under moderate acceleration, it sounds good and turns heads. At WOT, dogs start to howl and children cry.
    prevent and reywcms like this.
  30. Jul 30, 2023 at 5:41 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    Ram air hood scoops is a great idea for forcing more air into the air filter/air box. I hope you see significant increases in power, and performance.
