Lift for Platinum w/AVS
Discussion in 'Suspension' started by Kspegar, Apr 9, 2023.
  1. Apr 9, 2023 at 10:27 AM
    Kspegar
    Kspegar [OP] New Member
    Kalei
    Bigisland, Hawaii
    2023 Tundra Platinum
    What’s my options?
    let’s see them pics !
  2. Apr 9, 2023 at 1:21 PM
    GoFast157
    GoFast157 New Member
    Lots of options for leveling kits (if that is all you need/want) as most standard front leveling pucks will work on avs trucks. Can also adjust stock rear sensor arms to increase rear height slightly.
    -Westcott has a 2" front, 7/8" rear preload collar kit.
    -Readylift has a 2" front and rear kit.
    -Rough country has a 3.5" and a 6" available.
    There might be others out there now that i haven't seen. And I know there's several companies still working on theirs.
    I started with the Westcott and it was fine. Good quality kit for the price. This rode noticeably rougher, and avs adjustments weren't noticeable with this kit.
    Decided to give the Rough Country 3.5" a shot since it offered more lift and used actual spacers under the bags in the rear as opposed to over inflating bags. This brought the ride quality back to almost stock. Avs adjustments are far more apparent as well.
    Pic is with the RC 3.5". There's lots of great info hidden in the forums if you search around. Let us know what you decide and post pictures if/when you're lifted.
    23 Platinum, PBNB and Kspegar[OP] like this.
  3. Apr 9, 2023 at 1:24 PM
    Kspegar
    Kalei
    Bigisland, Hawaii
    Very nice ! What size tires ?
  4. Apr 9, 2023 at 1:31 PM
    GoFast157
    35x12.50r18
  5. Jul 12, 2023 at 12:19 PM
    GreenArmyHands
    GreenArmyHands New Member
    Alix
    2022 Tundra Army Green 1794
    Westcott 3/1 AVS lift
    Could you confirm this lift works with 1794 AVS also? Rough Country said it won't work with AVS but works with Rear Air Ride? Aren't they the same?
    Kspegar[OP] likes this.
  6. Jul 12, 2023 at 12:23 PM
    Kspegar
    Kalei
    Bigisland, Hawaii
    Yup it works . 6” RC with Icon billet UCA
    1.5” Bora Spacers front and back
    295/65/20 Toyo RT Trail.
    2023 Platinum iforcemax with Avs and its fully functional.
    Piney likes this.
  7. Jul 12, 2023 at 12:38 PM
    GreenArmyHands
    Alix
    Can you send a link for the lift kit?
    How long did it take to install?
  8. Jul 12, 2023 at 1:04 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    AVS is the "electronic shocks", rear air is rear load leveling. Two different things
    Blufin likes this.
  9. Jul 12, 2023 at 1:19 PM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Both trucks look great with the lifts/tires & I'm chomping on the bit to follow ya all but...Yeah there's always a "but" the warranty...
    There have been a couple of people on boob tube posting about minor lifts and simple bilit leveling and have had leakage on the transfer case to axle and they only installed 2" pucks on the front and stated there warranty has gone by by due to this.
    The Toyo kit is a winner but with AVS it's a no go claimed by Toyo....
    So I'm dead In The water until Toyota makes something compatible or I say fuck it and just pull the trigger.
    I know that all said on the blabernet isn’t 100% factual but these boards hold a lot more actual truth,I really don't want to void the warranty just for very few and far between off roading adventures and to look cool,until something fails and the stealer ship tells me to go pound sand.
  10. Jul 12, 2023 at 9:15 PM
    JMitch
    JMitch New Member
    James
    2023 Tundra Limited 4x4 Hybrid
    ReadyLift just released a few other options. They have both a 3” and 6” lift in addition to the 2”. Has anyone tried these yet?
  11. Oct 19, 2023 at 9:55 PM
    planehappy
    planehappy New Member
    Do you have a part number for the kit that works with the AVS? Thank you.
  12. Aug 6, 2025 at 7:37 AM
    Akalias01
    Akalias01 New Member
    I know this is an older post but I'm curious if anyone has confirmed for sure if the 6-in lift will work on a tundra with AVS. I know there's a 3-in lift by Ready lift. I would definitely prefer a 6 in lift if possible.
