  1. Jul 11, 2023 at 10:47 AM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Bought this one off Amazon:
    https://www.amazon.com/gp/aw/d/B0BX6F1ZP9?ref=ppx_pop_mob_b_asin_title
    Install was pretty easy. Hardest part was expanding the existing hole to accommodate for slightly larger replacement. Bought a step bit and made quick work of the project. Used existing wiring but removed from the plastic connector.
    probably gonna buy at least 1 more to replace others in center console and under head unit
    Anomalos7, rdiddy5, Blowdart and 5 others like this.
  2. Jul 11, 2023 at 11:02 AM
    Damn...I should switch to a USB while I'm doing the AC conversion.
  3. Jul 11, 2023 at 11:24 AM
    Taco-Spike
    Two Trucks
    Yeah, they were replaced in the first week. Didn’t bother with the center console.
  4. Jul 11, 2023 at 12:57 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    How hard is it to remove the panel below the AC buttons now that the cigarette lighter “ports” are no longer there.
    Usually I use my thumbs in those to pull the panel off but doesn’t look like that would be an option once replacing with usb c ports
  5. Jul 11, 2023 at 1:28 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Todays lesson in don’t throw any random mounts or hardware away. Initially only used the single radium mount but after the recent stillen pipe it got in the way. So I was able to locate the secondary radium mount and got that dialed back in.
    Also ordered some front rotors and pads to hold me over until the BBK is ready since I smoked my setup this passed weekend on the trail run. Next up fixing an Evap code/drain fill the trans and hopefully tuning asap
  6. Jul 11, 2023 at 1:31 PM
    Taco-Spike
    Two Trucks
    I don't notice any difference in taking it off now versus stock. Probably taken it off several times since they have been installed
    bulldog93 and Jcmf52[QUOTED] like this.
  7. Jul 11, 2023 at 1:33 PM
    Vizsla
    Vizsla 2 = 2.5
    Adding a battery cage and bracing the mounting structure underneath.
    Personally seen 3 batteries come loose/rip out of the j-hooks on the hold down off road, 1 hit the airbag sensor mounted in front of the battery and set the bags off. Had better hooks and hold down previously, and battery was glued down with silicone lol (worked really well). Tig welding the thin metal bracket for the battery isolator to the cage was interesting, think I get carried away with anything that has a throttle pedal, end up mashing it when things go wonky.:confused: Hope to get it installed later today, and get the bracing for under it fabbed up and painted.
  8. Jul 11, 2023 at 2:05 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea, I need to figure out a much better mount for the same reason. But it'll be moved to the bed at some point but in the meantime.
  9. Jul 11, 2023 at 2:26 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’ve seen one instance of the battery coming loose and smoking the airbag sensor :anonymous:
    Is that for a 27f or are you running a 34?
  10. Jul 11, 2023 at 2:27 PM
    mountaintime
    mountaintime New Member
    Blue 18 Tundra TRD Crew
    Remote Start, Remote Tailgate Tesla Radio
    I know it is summer. But I got my heated windshield wipers installed. No more reaching out to slap the ice off.
  11. Jul 11, 2023 at 2:38 PM
    Beach Toy
    Beach Toy New Member
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    Posted this in the power tailgate lock thread also…I have a slight problem…my truck had the branded PopnLock installed when I bought it; don’t know if previous owner installed or his selling dealer. Anyway, it quit working a while back even after cleaning. It seems to be getting power at the tailgate by test light. I bought a replacement kit and tested the actuator prior to install and no joy. However, I did test both actuators directly at the battery and both function. Any ideas on this?
  12. Jul 11, 2023 at 3:16 PM
    Vizsla
    Vizsla 2 = 2.5
    :rofl: Ok, guess it’s 4 now. The rest of the forum must think we are idiots.
    24f, that’s what Walmart sells in agm for the Tundra. Saves a little weight, and keeps the battery isolator within the footprint of the original 27f for me. Not sure why/if that matters though.:notsure:
    Would be nice, but I don’t have any room in the bed for it.
  13. Jul 11, 2023 at 3:32 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    i think you forgot to tighten down your battery hold down. Lol
    RainMan_PNW and reywcms like this.
  14. Jul 11, 2023 at 3:33 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Well the forum would be right that we're idiots lol
  15. Jul 11, 2023 at 3:35 PM
    seydou
    seydou Distinguished Member
    Do you not have the windshield wiper de-icer in the windshield? What trim level do you have? Or is this the actual wiper that is heated?
    IsaiahCanada likes this.
  16. Jul 11, 2023 at 3:37 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Which tray is that from barnes?
  17. Jul 11, 2023 at 3:38 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I mean…was this even a topic for debate?
  18. Jul 11, 2023 at 3:41 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL
    BiggHertz[QUOTED] likes this.
  19. Jul 11, 2023 at 3:42 PM
    Vizsla
    Vizsla 2 = 2.5
    MedCityMoto and reywcms[QUOTED] like this.
  20. Jul 11, 2023 at 4:44 PM
    coTony
    Tony
    Montrose, CO
    Happy Birthday young man!
  21. Jul 11, 2023 at 4:48 PM
    coTony
    Tony
    Montrose, CO
    I need to be able to cut my lines and get them in the truck. I have my street being paved starting today. They will be grinding and stuff from today until Aug 1st... really? Did not realize it took that long but this could be the time I was looking for
  22. Jul 11, 2023 at 4:49 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Happy 5-0 George!
    Mike59 and Tripleconpanna like this.
  23. Jul 11, 2023 at 5:14 PM
    Thanks!!
  24. Jul 11, 2023 at 5:16 PM
    Thanks! Just fed the mosquitos while finishing up this project. The trim panel should be here in a couple of days.
  25. Jul 11, 2023 at 5:17 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    She was tight. I hit the whoops a little too hard following you, though, and apparently there was enough flex in the battery tray to let the J hook slip out. There was a fun balance between smashing my OE battery or having it tight enough to not move…
  26. Jul 11, 2023 at 5:22 PM
    Beach Toy
    SE NC
    2017 White SR5 4x4
  27. Jul 11, 2023 at 5:26 PM
    Vizsla
    Vizsla 2 = 2.5
    Lol. @BiggHertz is the poster child for needing a battery box. Nothing will hold the battery with the j-hooks on big hits. I ran around on borrowed time too long, but that silicone held my battery in place really well.:D My fried Alex managed to rip out his battery cage at T2S, but we found a nice solution for bracing the supporting structure.
  28. Jul 11, 2023 at 5:27 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    What's the effect of removing the secondary cats? Wouldn't that cause issues with the ECM?
    reywcms[QUOTED] likes this.
  29. Jul 11, 2023 at 5:30 PM
    Thank you!!
  30. Jul 11, 2023 at 5:42 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    No issues since the o2 sensors are before the secondary cats.
    Tripleconpanna and texasrho83 like this.
