Under-Bedcover Toolbox Suggestions
Discussion in 'General Tundra Discussion' started by jbcrewmax, Jul 11, 2023.
  1. Jul 11, 2023 at 9:48 AM
    jbcrewmax
    jbcrewmax [OP] New Member
    SETX
    2019 TRD Pro
    Need some advice/ideas: Wanting a toolbox in the bed under my bed cover, suspended up off the bed floor like the BakBox or Diamondback box. However, I have a RuggedCover brand tri-fold of which only flips 2/3’s (back third closest to cab doesn’t open), so was hoping I could find something that would slide back and forth along the rail, then access by sliding towards the tailgate with the first 1/3rd of the cover open.
    Has anyone seen a product like that, or created something similar? Doesn’t have to be big, only would be for holding hand tools, ratchet straps, etc. Also have a tailgate extender but I only use as needed, so not too worried about it.
    359469328_10160526448791068_243661347831_558abaee626a79fe42468ad71ccebd53be05b3e5.jpg
  2. Jul 12, 2023 at 3:43 PM
    dadrocz
    dadrocz New Member
    Ny
    23’ TRD Pro. 18’Platinum
    IMG_7927.jpg You should look at the swing case. You can get them for either side. Had 1 in my last 2 tundras. You will have to lose the bed extender though.
    1lowlife and FirstGenVol like this.
  3. Jul 12, 2023 at 3:44 PM
    Agreed. Love my swing case.
  4. Jul 12, 2023 at 4:57 PM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    So these swing covers require drilling into truck bed ?
  5. Jul 12, 2023 at 5:30 PM
    biebs96
    PA
    I used L brackets bolted into the factory cargo rail bolt holes with a board the width of the truck. Used weatherstripping on the front edge to make a flexible lip. It’s been in place, and loaded with straps, a tarp, umbrella and other crap for a few years without an issue.
  6. Jul 12, 2023 at 5:39 PM
    jbcrewmax
    SETX
    2019 TRD Pro
    This is pretty close to what I had in mind. What kind of L brackets? Fab'd yourself or like the kind used for uni-strut?
  7. Jul 12, 2023 at 5:54 PM
    biebs96
    PA
    yes pretty close to that style. I had a bunch of the brackets I acquired years ago from an old warehouse closing.
    Do you have the deck rail system in your truck?
  8. Jul 12, 2023 at 9:09 PM
    jbcrewmax
    SETX
    2019 TRD Pro
    Yes I do
  9. Jul 12, 2023 at 10:15 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It's just a few self-tapping screws.
    You'll be OK, I promise...:eek2::rolleyes:
    https://youtu.be/dh3f47KKBPE
    Doxiedad[QUOTED] likes this.
  10. Jul 12, 2023 at 10:18 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Sucks you have to open the entire cover to access it..
    With a swingcase you don't have to open the cover at all..
    It SWINGS out over the tailgate...:thumbsup:
    biebs96[QUOTED] likes this.
  11. Jul 13, 2023 at 5:33 PM
    biebs96
    PA
    this is the bracket
    I’ll look around for another, if I find a pair I can send you a set. If not, at least you have an idea of what was used.
    jbcrewmax[QUOTED][OP] likes this.
  12. Jul 13, 2023 at 5:36 PM
    biebs96
    PA
    good point. however having to open the cover to get something to use off the shelf, is most likely because the cover is going to need to be open to secure or load something.
    I still like the swing cases, but this mod was less than $5 and has worked wonderfully for years.
    GODZILLA and 2mchfun like this.
  13. Jul 14, 2023 at 8:23 AM
    jbcrewmax
    SETX
    2019 TRD Pro
    Thank ya sir for the measurements, I'll be able make something from that for sure. I'll post up my idea after I have a few days to put something together
  14. Jul 18, 2023 at 2:46 PM
    JDM42
    JDM42 New Member
    2019 Tundra DC
    SwingCase requires that you remove the tailgate anchor from each side to mount it on Gen2.5 Tundras. I don’t like losing the lower anchors. Anyone know of alternative lower anchors on/near the bed (not rails) that won’t get in the way of sliding items in/out?
  15. Jul 18, 2023 at 9:48 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    The swing case has a hole in the base to be used to put a padlock on to prevent theft in an uncovered bed.
    You can use it as a tie down anchor.
    I have anchors on my bed rail, so it wasn't an issue for me..
    Good luck..
  16. Jul 19, 2023 at 3:38 AM
    PermaFrostTRD
    Northern NY
    I didn’t like that idea either (I live in salt for 6 months) so I un-swung a swingcase and “mounted” it to the bed rail. I’m not on a NASCAR pit crew so I don’t mind rolling back my tonneau a bit to access the tools.
    The brackets I made are turds and it wasn’t until after I assembled everything that I came across Bay Area Metal Fabrication’s universal rail mounts. Ordered a couple and found they were a little short so I asked @jlee to customize some with longer lengths when he can get around to it. So when they’re finished I’ll be installing with those just to clean things up and “polish the turd” as the saying goes.
    Another shout out to @snivilous for being awesome and having a good sense of humor.
    Here’s the link to the fabrication catastrophe that brought this dumb idea to life.
    Godspeed.
    FirstGenVol and snivilous like this.
  17. Jul 19, 2023 at 7:13 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I didn't invest in stickers just for no one to run them :D
    AGonzo and PermaFrostTRD[QUOTED] like this.
