Recommendations for a water filter system
Discussion in 'Home Improvement' started by IowaGuy, Jul 9, 2023.
  1. Jul 9, 2023 at 5:48 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Where we live in AZ the city water is full of minerals and probably arsenic and other crap and we buy several gallons a week for drinking and cooking. My wife had a kidney stone a couple years ago and she blames it on the water.
    Any recommendations on a water filter system brand or type? I don't know if we need a whole house system but maybe just one for the kitchen sink. We probably use @ 3 gallons a week.
  2. Jul 9, 2023 at 6:10 PM
    Vizsla
    Vizsla 2 = 2.5
    I have this under the kitchen sink feeding the refrigerator, no separate faucet on the sink. Only water we drink, ice cubes are nice and clear also.
    https://www.amazon.com/APEC-5-Stage-Reverse-Drinking-Water/dp/B00I0ZGOZM?crid=ICGXUFRPMQOQ&keywords=apec+reverse+osmosis+water+filtration+system&qid=1688950768&sprefix=Apec%2Caps%2C180&sr=8-5&th=1
    Test ppm every month, always single digit. Best bottled water tested was 20 ppm, my tap water is 500 - 700 ppm.
    ColoradoTJ and IowaGuy[OP] like this.
  3. Jul 9, 2023 at 6:36 PM
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
  4. Jul 9, 2023 at 6:55 PM
    chrisf111
    chrisf111 New Member
    This is what I went to start with. https://www.purewaterproducts.com/model-77-countertop-water-filter
    Good company to deal with. Depending on quality of water you may want to go for a reverse osmosis system.
    Can you tell me more about how you're testing?
  5. Jul 10, 2023 at 4:30 PM
    bfunke
    bfunke Tundra Curmudgeon
    High levels of Calcium and Magnesium are primarily what makes your water hard in AZ. Two options you’ll want to look at are an RO unit under the kitchen sink for drinking and ice. You might also want to look at a water softener for your house to keep your fixtures working longer and reduce mineral buildups. There is a lot of misinformation and hype about toxic chemicals in drinking water. If you are connected to a municipal water system, ask to see the latest CCR (consumer confidence report) to see where your water is in regards to various EPA pollutant levels. If you have a well for your drinking water get it tested by an independent lab. If you live near a military installation, inquire about known plumes of TCE, PERC, Jet Fuel, MOGAS and PFAS.
  6. Jul 11, 2023 at 10:31 AM
    Prime day
    Limited-time deal for Prime Members: Aquasana 3-Stage Max Flow Claryum Under Sink Water Filter System - Kitchen Counter Claryum Filtration - Filters 99% Of Chlorine - Brushed Nickel Faucet - AQ-5300+.55 , White https://www.amazon.com/dp/B06XGZMTRH
    Limited-time deal for Prime Members: iSpring RCC7AK-UV, NSF Certified, 75GPD 7-Stage Under Sink Reverse Osmosis RO Drinking Water Filtration System with Alkaline Remineralization Filter and UV Ultraviolet Filter https://www.amazon.com/dp/B006T3HYQ0
  7. Jul 11, 2023 at 10:43 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Whole house water softener (it comes with 1-2 particulate filters), a 3-4 stage reverse osmosis for drinking water with 2-4 gallon tank under kitchen sink. Water is so clean that I use it to dilute coolant concentrate vs buying distilled water at CVS (where it could be a tap water as my water hardness meter showed once).
    Reverse osmosis system you can install yourself, not a rocket science at all.
  8. Jul 11, 2023 at 10:44 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Wife needs to drink more beer :)
  9. Jul 14, 2023 at 1:34 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
