LCA Ball Joints replacement part numbers
Discussion in '2.5 Gen Tundras (2014-2021)' started by drpheta, Jul 4, 2023.
  1. Jul 4, 2023 at 4:02 AM
    drpheta
    drpheta [OP] New Member
    Super White 2014 TRD Off-Road DC
    Can we or can we not get individual LCA ball joints from the dealer? All my searches for lower ball joints come up with previous generation Tundras.
    If not, what's the best replacement LCA ball joint available? Summit racing has AC Delco Silver and 2 versions of the Gold series ball joints. I read Moog are hit and miss.
    So, I need guidance on which ball joints I need to replace with. 175k miles, should I just replace the entire LCA assemblies? That would require new cam bolts too.
  2. Jul 4, 2023 at 4:19 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Correct, this gen doesn't have OEM part numbers for them, just the assembly. I just asked about this myself.
    Unless they're popping, they're fine.
    I plan on going with the ACDelco gold myself if the rest of the assembly is still fine when/if I need to swap mine.
  3. Jul 4, 2023 at 4:52 AM
    drpheta
    Thanks, I'm assuming the difference between these two gold ones is individual ball joint vs the lower bracket assembly with the joint?
  4. Jul 4, 2023 at 2:53 PM
    MedCityMoto
    The 45D1506 were the ones I was looking at myself. I think the 45D0150 is the upper ball joint.
    drpheta[OP] likes this.
  5. Jul 4, 2023 at 2:58 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  6. Jul 4, 2023 at 3:01 PM
    drpheta
  7. Jul 4, 2023 at 3:01 PM
    drpheta
    Ahh, thanks for that
  8. Jul 4, 2023 at 3:02 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    If you do a site search, I believe these would be OEM. Just a guess. I swapped LCA's at 135k mi.
    drpheta[QUOTED][OP] likes this.
  9. Jul 4, 2023 at 3:09 PM
    drpheta
    Oh man, my search for LCA ball joints says we had no OEM option. THANKS!!
  10. Jul 4, 2023 at 3:17 PM
    stevep0925
    stevep0925 New Member
    Trinity, AL
    19 Cav Blue Limited 4x4
    I have an ICON 2.5 lift and i have two small pin hole tears in both my front LCA balljoints...I never drive the truck unless it to camp. or to Lowes for the wife. Im looking at new ones and glad I found this post. subbed
  11. Jul 4, 2023 at 3:23 PM
    B.Ross
    B.Ross New Member
    Southern Utah
  12. Jul 4, 2023 at 3:28 PM
    drpheta
    Searched Beck Arnley and got this stating they're made in Japan.
    https://www.tundras.com/threads/lower-ball-joinnts.75142/#post-1917320
    However, this thread states it's luck of the draw, and that Moog are more consistent (which others say they're not). Ugh
    https://www.tundras.com/threads/lower-ball-joints-part-numbers.97100/page-3#post-2471926
    Man, I wish Toyota just offered the LCA ball joints themselves.
  13. Jul 4, 2023 at 5:14 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I installed a Moog in my '07 a couple weekends ago, posted a short tutorial/tricks thread in the 2G forum, but it's identical in yours.
  14. Jul 8, 2023 at 7:07 PM
    drpheta
    Ordered Beck Arnley lower control arm ball joints number 101-7653, and they are indeed made in Japan by Sankei 555. Very happy with that, because they're a highly rated manufacturer.
    $60 each ball joint is a great value as well.
    Shout-out to @B.Ross for the recommendation!
    kittyhawk, LS3, B.Ross and 2 others like this.
  15. Jul 24, 2023 at 10:12 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    what lca’s did you replace your with?
  16. Jul 26, 2023 at 3:23 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    I went with OEM.
    Someone posted a "better than kinfolk deal" link to a Toyota dealer in the South.
    $450ish for the pair.:cool:
