How to torque top nut on rear shocks?
Discussion in 'Suspension' started by trdtuna, Jul 8, 2023.
  1. Jul 8, 2023 at 10:12 AM
    trdtuna
    trdtuna [OP] New Member
    Keith
    Southern California
    2021 SR5 DC TRD 4x4 OR MGM
    IG @trdtuna
    The top of the shock shaft is very close to the frame of the bed and the shaft extends far through the nut for a deep socket to fit. So there is little space for a torque wrench. There seems to be space only for two wrenches; one to clamp on the shaft and the other for the nut.
    How can I torque this nut when I can’t fit a torque wrench and socket? Using a crowfoot attachment seems like the only option.
  2. Jul 8, 2023 at 10:19 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was thinking of a crowfoot too. Or just tighten it up until the bushing compresses out so that the outer edge is even or just ever-so-slightly greater than the "washers" that sandwich it. There's probably a much more "scientific" way to do it in that situation though.
    crikeymike likes this.
  3. Jul 8, 2023 at 10:25 AM
    trdtuna
    Keith
    Southern California
    IG @trdtuna
    That’s a good approach.
    I ended up measuring the length from the top of the shaft to the nut of the installed stock Bilstein 4600s and matching that onto the Bilstein 5100s that I installed. It measured to 3/4”. Both shocks are nearly the same length. It was to me the logical approach with the tools that I have.
    Wynnded likes this.
  4. Jul 8, 2023 at 10:27 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sounds like a good idea, then check up on them in a few days!
    trdtuna[QUOTED][OP] likes this.
  5. Jul 8, 2023 at 10:32 AM
    trdtuna
    Keith
    Southern California
    IG @trdtuna
    That’s the plan. :)
    Wynnded likes this.
