Is it better to get the whole control arms or ball joint.
Discussion in '2nd Gen Tundras (2007-2013)' started by CurtisL, Jul 5, 2023.
  1. Jul 5, 2023 at 12:44 PM
    CurtisL
    CurtisL [OP] New Member
    Curtis
    2008 Toyota Tundra LTD
    2 inch lift, 22s
    My 2008 truck is a little chirpy when I go over certain bumps. It’s not really a squeak, it’s more like a chirp. It only makes noise when I go over something that makes the suspension flex (like speed bumps) No noise is present when hitting regular bumps or potholes. It’s also not consistent, some days I can go over a speed bump and not hear anything strange. I’m not 100% sure if I should replace the LCA, UCA or both. I narrow it down to the ball joint. Considering how long the Toyota part last, I would like to get a new set and just want to make sure if that’s what I really need before spending the money.
