Front Driver Wheel Speed Sensor C0205
Discussion in '2nd Gen Tundras (2007-2013)' started by Apollothetundra, Jun 30, 2023.
  1. Jun 30, 2023 at 5:04 PM
    Apollothetundra
    Apollothetundra [OP] New Member
    Trevor
    07 Super White 5.7l V8 337,000
    I was recently changing out my lower control arms and I somehow managed to break the driver front wheel speed sensor. Drilled out the rest of it and purchased a oem sensor and plugged it in . I have techstream so I deleted all codes and it came back with dash lights flashing and C0205 Code Popping up . Not sure where to go from here any help would be much appreciated :)
  2. Jul 5, 2023 at 11:29 AM
    Apollothetundra
    Trevor
    Update tested wiring harness to see if there was a cut or pinched wire . That checked out , hooked up techstream and looked at active data all wheel speed sensors are reading the same speed . Also checked 40Amp fuse and it was still good. Where do I go from here ? Have deleted the codes multiple times with techstream and even disconnected battery .
