Rack and Pinion Replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by BigdaddyII, Jul 3, 2023.
  1. Jul 3, 2023 at 12:34 PM
    BigdaddyII
    BigdaddyII [OP] New Member
    South Louisiana
    2019 Ram 1500
    I am looking at replacing the steering rack on my truck. Discovered a leak while replacing what I thought was a bad inner tie rod end. Turns out the slop is in the rack itself. I already have a new rack ordered (not rebuilt) and I am working on getting excited about replacing it lol. My question is about the fluid. The manual specs Dextron II or III (whichever is cheapest I guess), but I have no clue how much to buy and have ready. I know a couple quarts will cover reservoir and pump drain and fill, but how much does the rack itself take?
  2. Jul 3, 2023 at 1:03 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    This is the correct fluid. https://www.tundras.com/threads/oem-power-steering-fluid.108836/#post-2822608 the whole system only takes 2qts but I'd get 3 just incase.
  3. Jul 3, 2023 at 1:13 PM
    2mchfun
    How many miles on the truck? Don't seem like a 18 should be needing a new rack already.
  4. Jul 3, 2023 at 2:25 PM
    BigdaddyII
    South Louisiana
    2019 Ram 1500
    175,000
    Just had a timing job and water pump done due to a failed tensioner. I guess this is the average mileage you have to put a little into it to go another 175,000 lol
  5. Jul 3, 2023 at 3:23 PM
    2mchfun
    Yeah that's a few more miles than I expected. Guess you drive the beast pretty regularly. Nothing wrong with a few repairs at that mileage and age combined. Good luck with the repairs!
