Increase power/torque for towing
Discussion in 'Towing & Hauling' started by Reddjackson, Jun 21, 2023.
  1. Jun 21, 2023 at 1:49 PM
    Reddjackson
    Reddjackson [OP] New Member
    2016 TRD Tundra
    Looking for best way of increasing power/torque for towing for my 2016 Tundra 5.7 TRD Off Road 4X4.
    Towing in low altitude in tow/haul is OK, but towing in altitude is a PITA with horrible gas mileage…other pickup’s with diesel blow my doors off. Anything I can do for this? Don’t want to give up my Tundra, rather improve it.
    Thanks
  2. Jun 21, 2023 at 1:57 PM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    I’m no help. I’ve never raced anyone while I was towing my trailer.
  3. Jun 21, 2023 at 2:03 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  4. Jun 21, 2023 at 2:04 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  5. Jun 21, 2023 at 2:04 PM
    e30cabrio
    Silver17[QUOTED] likes this.
  6. Jun 21, 2023 at 2:05 PM
    Silver17
    Eastern PA
    You can call me ninja.
    e30cabrio[QUOTED] likes this.
  7. Jun 21, 2023 at 2:09 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Long tubes and a tune.
    Saltyhero13 likes this.
  8. Jun 21, 2023 at 2:12 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Supercharger is the only real solution, you'll still get absolutely horrible mileage though.
    GODZILLA and Silver17 like this.
  9. Jun 21, 2023 at 2:20 PM
    CTundraForMe
    CTundraForMe New Member
    Try using premium fuel a few times and see happens?
  10. Jun 21, 2023 at 2:30 PM
  11. Jun 21, 2023 at 2:46 PM
    Reddjackson
    2016 TRD Tundra
    Thanks for all the replies…waiting for a Tundra diesel…yeah, good luck on that
    ColoradoTJ likes this.
  12. Jun 21, 2023 at 3:20 PM
    Silver17
    Eastern PA
    While you will never get diesel fuel mileage, a supercharger will get you similar performance within the limits of the tundras tow rating. I think it’s easier than the diesel though as far as maintenance, DEF, emissions equipment failures, etc. so it’s all a tradeoff. I’m pretty sure my tundra could pull my 7k trailer 0-60 as fast as my pops LB7 duramax could do it not towing anything. Now granted the power outputs of HD diesels have doubled since the LB7. I’d also get 8mpg pulling it on a trip where as his would probably get 15mpg.
  13. Jun 21, 2023 at 3:26 PM
    A SC is also way more daily driver friendly. Modern diesels are not.
  14. Jun 21, 2023 at 6:14 PM
    centex
    centex New Member
    Forced induction and gearing are the only ways to actually gain improvement for towing. Tunes, exhaust, intake, not worth it. Step up gears or bolt on boost.
    Saltyhero13 and texasrho83 like this.
  15. Jun 21, 2023 at 6:15 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Swap those gears.
    nasher75 likes this.
  16. Jun 22, 2023 at 8:52 AM
    e30cabrio
    I have new Doug Thorley Long Tubes for sale, getting closer to installing as they sit.
  17. Jun 22, 2023 at 9:18 AM
    art64
    art64 New Member
    Re-gear it. It doesn't require high octane fuel. I don't know what size tires you have now. Lowest gear available is 5.29. Downside: top speed is reduced, speedo will need re-calibration. Upside: no need for high octane fuel.
  18. Jun 22, 2023 at 11:00 AM
    snivilous
    SW UT
    Top speed is reduced, but that can be fixed with a tune. Speedo doesn't get affected since the speedometer data is pulled from the hubs.
    texasrho83 and ColoradoTJ like this.
  19. Jun 22, 2023 at 1:29 PM
    You don't want a small diesel in your tundra....trust me. Look at all the other manufacturers that have put a small diesel in a 1/2 ton truck. How are they doing today? Most are discontinued or poor performance towing (great on fuel economy).
    Take the Nissan Titan XD for example. A modern diesel that lost to its gas counterpart on the tow tests. That's embarrassing (think the HP 3.5 EB also beat the 3.0 diesel). Then the cost. For about the same amount of money, one can buy a domestic 3/4-1 ton and have all the power and tow ratings one would need.
    Since you live on the west coast, your options are more limited. A SC is the best option in my opinion if upgrading isn't an option (and money isn't that much of a concern either).
  20. Jun 25, 2023 at 7:30 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    We tow a 25’ Grand Design travel trailer and have had great luck with the Tundra.
    34” tires
    5.29 gears
    Tuned
    I town in 5th gear on flat ground.
    I drop to 4th as soon as I start climbing hills. At 60 mph, that puts me near the 3,000 rpm range. That’s where my peak torque is made after tuning.
    If the hill is steeper than I can pull in 4th, I’ll drop to 3rd and hold 55 mph. Plenty of power to accelerate, but there is no point. Other than bigger passes, I’m rarely in 3rd.
    Since tuning, I never use Tow/Haul.
    I get
    Close to 8 mpg towing.
    It’s not a 1-ton diesel. It’s a light duty 1/2-ton gasser! Gotta remember that part…
    texasrho83 and Terndrerrr like this.
  21. Jun 30, 2023 at 5:49 PM
    Reddjackson
    2016 TRD Tundra
    Thanks everyone, I’ve decided to go with a Supercharger, more affordable than a diesel…AND, I really love my Tundra, can’t bear to sell it…no can do.IMG_0308.jpg
  22. Jun 30, 2023 at 6:34 PM
    Silver17
    Eastern PA
    Good choice in my opinion, you will love it. Mine pulls my 32’ TT like a champ. Whatever supercharger you go with, most of us that have them would recommend making sure you have adequate fuel injectors and fuel pump as well has a custom tune. Hit the group up for more info if you need it in the general supercharger thread linked above.
    ATV25, snivilous and Saltyhero13 like this.
  23. Jun 30, 2023 at 6:38 PM
    18" TRD Off Road Wheels
    Don't go over 65 and you'll get better mileage and have a better tow experience. Trying to keep up with the idiots towing at 80 is... well... trying to keep up with idiots. Slow is smooth, and smooth is fast.
    Jaypown, ZPhilip, landphil and 3 others like this.
  24. Jun 30, 2023 at 6:45 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Great choice! You’ll love it!
  25. Jun 30, 2023 at 7:34 PM
    centex
    centex New Member
    It’s always a good idea to add more stress and heat during towing instead of using mechanical advantage.
  26. Jul 1, 2023 at 4:21 AM
    Silver17
    Eastern PA
    Unless maybe you’re towing at full throttle everywhere you go with a max load trailer hooked up that’s not a concern in my experience. I’ve monitored all temps towing with and without a supercharger and have noticed no increase in temperatures. The tundra cooling system is pretty good. It just makes acceleration more effortless and maintaining speed easier on hills. If anything the transmission runs cooler because the torque converter lockup is dependent on the throttle position. It generally takes less throttle to maintain speed so the converter stays locked more often on slight inclines and cruising. I also have stock gears and 34s.
  27. Jul 1, 2023 at 6:59 AM
    Retired...finally
    I only seem to notice the problem at the foot of the hill. The further up I go, the more power it seems to have. Yes, removing that heavy fuel from the tank makes a difference.:anonymous:
    landphil likes this.
  28. Jul 1, 2023 at 7:36 AM
    centex
    centex New Member
    Adding boost adds heat and stress. There’s no way around it. Adding mechanical advantage doesn’t. Can you tow with boost? Sure. Doesn’t change the fact that it’s additional heat and stress going into the engine on top of the stress and heat of towing.
    I to have stock gears and 34’s and tow and the last thing these trucks need is power. They need gears.
    texasrho83 and Chad D. like this.
  29. Jul 1, 2023 at 7:51 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    Gears and a tune…. Gears for that mechanical advantage, and the tune to make it all play nice. You can also cure those stupid TCC unlocking issues with a good tuner.
    We’re headed out for a two week trip with our 25’ TT in about two hours. 34” tires, 5.29s, and HP tuned. I tow in 5th on flat ground, and bump to 4th in the hills. While more power is always fun, I have no trouble maintaining highway speeds while towing here in the hilly PNW. If I can’t maintain at least 55 up a hill, it’s typically because of the corners.
    texasrho83 likes this.
  30. Jul 1, 2023 at 7:53 AM
    Silver17
    Eastern PA
    Meh, I respectfully disagree. It’s only added heat and stress if you pushing it harder than you should be while towing. Not saying gears won’t help because sure they will, but it’s not the same. OP wants more power for towing at elevation, and he has stock sized tires. He says it’s not enough. The only way to make up for the horsepower percentage loss from lack of atmospheric pressure at elevation is to increase the pressure and therefore power via boost. I’ve yet to see it cause a problem for anyone. Plenty of dudes on the boosted FB page with 200-300k boosted miles towing frequently with no problems.
    Terndrerrr and ATV25 like this.
