Is 330k miles too many to buy?
Discussion in '1st Gen Tundras (2000-2006)' started by ck90, Jun 29, 2023.
  1. Jun 29, 2023 at 8:49 PM
    ck90
    ck90 [OP] New Member
    2006 DC 4x4
    I'm looking at buying a 4.7L 2004 double cab tundra, and I'm trying to decide - is 330k miles too many?
    It's been well maintained and has a lot of new suspensions parts. The frame is rock solid. Engine and transmission are original - theoretically it runs great and doesn't burn oil. The asking price is around 6k
    Just trying to decide at what point it's too many miles.
    At what point do people typically see more serious engine issues (bad compression, burning oil, etc) or transmission issues/failures come up? I know typically the frames go first, and that people always say they go forever and not to worry about it, but trying to decide if this would be worth considering - I feel like in a lot of cases if it's highway miles and the fluids were changed this one is about as likely to keep going as anything else, even with substantially less miles, but I'm not sure.
    Also, even if the engine and transmission are fine, I don't want it to turn into a cash pit - I do almost all of my own work though, so repairs would be cheaper, but still can add up, or be annoying.
    Thanks for the help
    Metro14536 and JasonC. like this.
  2. Jun 29, 2023 at 8:59 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    shifty` and Metro14536 like this.
  3. Jun 29, 2023 at 9:10 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Sheeeeeeit. 330K, she is just breaking in.
    Metro14536 likes this.
  4. Jun 29, 2023 at 9:36 PM
    Casper421
    In the woods
    06 DC
    My boss bought his 03 sequoia with 396k miles. If he didn’t buy it, I was going to. The million mile tundra had a 4.7. These engines and transmissions run forever if properly maintained. It all depends on the po’s maintenance and willingness to invest money along the way on everything else. $6k is kinda steep, except if it’s a west coast truck.
  5. Jun 30, 2023 at 9:37 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    You sound like you’re well informed and if capable doing your own work then the only reason not to buy is if the cash savings of buying a 330k rig don’t add up when compared to the 200k mile rigs around your local area.
    I personally wouldn’t hesitate if the history, maintenance and seller were on point.
  6. Jun 30, 2023 at 9:44 AM
    Nope.
    txagg likes this.
  7. Jun 30, 2023 at 9:55 AM
    At 330k miles I think you should expect to set aside money for replacing old parts. I think it could still be reliable for you but because of age and miles it's likely going to need some work.
    Do you know when the timing belt was most recently replaced?
    Jack McCarthy likes this.
  8. Jun 30, 2023 at 9:55 AM
    2mchfun
    If mostly highway miles, snatch it up. You can get a good idea by looking at wear on the seat, brake pedal rubber, door paint around handle, door latch wear, seat belt, etc. Use good ol'common sense.
  9. Jun 30, 2023 at 11:49 AM
    Mr Badwrench
    Mr Badwrench New Member
    330k is a lot. If it drives well, shifts smoothly and doesn't leak, it might be worth it. 6,000 bucks doesn't buy much these days! :goingcrazy:
    Tundrastruck91 likes this.
  10. Jun 30, 2023 at 1:28 PM
    Aerindel
    Aerindel New Member
    Montana
    I sure hope not. ;) it's what I have on mine.
  11. Jun 30, 2023 at 2:02 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    You can always put 6k down on a new Tundra ...
    Indeed. It's basically free compared to the cost of a new truck.
  12. Jun 30, 2023 at 2:16 PM
    Do your own work and truck has been well maintained? You’re good.
    Only issues with the 02 are weak planetary gears so keep it out of overdrive when towing and sometimes you’ll get a weld crack manifold exhaust leak. Annoying but not the end of the world. If you’re up for a challenge you can install aftermarket headers and let us know about your nightmare…I mean experience.
    Just change the oil religiously especially if you do a lot of short trips (which is the worst since moisture doesn’t burn off and you can get sludge buildup). Changing the oil at least twice a year using synthetic will help to minimize it.
  13. Jun 30, 2023 at 2:33 PM
    Aerindel
    Aerindel New Member
    Montana
    We all see the kind of posts in the 3rd gen section....I'd put $6K into fixing my truck any day over buying a new one.
  14. Jul 1, 2023 at 12:23 PM
    artsr2002
    'Yonder
    Well yeah I would too since the Turd gens are fugly. :D
    Aerindel likes this.
  15. Jul 1, 2023 at 2:49 PM
    Aerindel
    Aerindel New Member
    Montana
    IMO, 2nd gens are the ugliest....followed by 3rd gens.
    PastorGman and SharkDog like this.
  16. Jul 2, 2023 at 11:56 AM
    Tundrastruck91
    Ugly is the new thing with the in crowd //lol .. let's all enjoy getting well over 300k miles. The people with double that on original engine and trans is just awesome.
  17. Jul 2, 2023 at 10:22 PM
    artsr2002
    'Yonder
    I'm halfway to mine breaking in. 140somethingandchangeK
