Wheel swap question
Discussion in '3rd Gen Tundras (2022+)' started by scruff1221, Jun 29, 2023.
  1. Jun 29, 2023 at 6:57 PM
    scruff1221
    scruff1221 [OP] New Member
    2022 Tundra Trd Off-road
    Quick question
    currently in a trd off road looking to swap to this wheel package below
    should be no issues going from 18 to 20” correct
    do I need to calibrate speedometer and the tps on the new wheels to my truck?
    no too familiar with the process
  2. Jun 29, 2023 at 9:05 PM
    worksjo
    worksjo New Member
    2023 Tundra SR5 Off Road
    You need to know the tire sizes not just the wheel size to know if there will be a circumference difference (which is what would throw off speedo). It takes quite a difference in size to make a much of difference in speedometer.
    I use this site when I want to compare tire sizes and what the net result will be.
  3. Jun 29, 2023 at 9:40 PM
    23tundra75002
    23tundra75002 New Member
    Dallas
    2023 Tundra Platinum in celestial silver
    Your stock tires on the OR 18” are 265 70 r18.
    The 20” TRD OR tires are 265 60 r20.
    There is barely any difference at all between the two setups. Your basically trading tire sidewall for rim.
  4. Jun 30, 2023 at 7:34 AM
    BTP4x4
    BTP4x4 New Member
    Billy
    2023 Black Tundra
    I'm basically looking to do the inverse. Switch out my factory 20's for 18's. Where you located?
  5. Jun 30, 2023 at 7:41 AM
    scruff1221
    Why is that bud?--I am in LA--Where are you?
  6. Jun 30, 2023 at 12:11 PM
    BTP4x4
    BTP4x4 New Member
    Billy
    2023 Black Tundra
    Houston, I spend a good amount of time on the beach and in the woods so I want more sidewall for roots, rocks, and curbs lol.
